Enabling USB Keyboard/Mouse to Power On Laptop - BIOS Settings Unavailable
budrysek 47208 6
  • #1 6763647
    budrysek
    Rate: 25
    Hello. I can only turn it off from the usb keyboard and I need to turn it on. I use my laptop at home as a PC, it is connected to a 20 '' monitor and the laptop itself is closed and I have to open it every morning to turn it on. I did not find any settings in bios.
  • #2 6763680
    Dragas
    Help: 76
    Rate: 197
    I am 99% sure that you cannot turn on your laptop and desktop other than by pressing the POWER button!
    regards Krzysztof
  • #3 6763718
    sonyq
    Rate: 18
    If you so want to turn on the computer from the keyboard. Convert the micro-contact from the power button to some of the buttons on the keyboard that are mirrored. for example shift or whatever suits you.
  • #4 6763721
    underground
    Rate: 16
    Sure you can, it depends on the motherboard ;)
  • #5 6763805
    budrysek
    Rate: 25
    regards Krzysztof
    you're wrong. In the previous compilation on MSI in bios, I had the Keyboard / Mouse Wake up options - any key on the keyboard or mouse turned on the computer
  • #6 6771746
    misiupan
    Help: 257
    Rate: 441
    Laptops also have a sleep key, most often FN + some key, e.g. in my F12 computer, in others I do not know.It is best to set the elevator so that if you do nothing, the computer will enter, moving the mouse wakes it up or the combination FN + some key
  • #7 6772956
    olfork
    Help: 42
    Rate: 39
    In addition to the typical sleep state, as Duffle says, some boards have the option to turn on the computer with a key (sometimes even a sentence or password). If you do not have such a possibility, you are left with only unreasonable ideas (see above).
The discussion revolves around the inability to power on a laptop using a USB keyboard or mouse, with the user seeking BIOS settings to enable this feature. Responses indicate that while some motherboards support keyboard/mouse wake-up options, many laptops do not. Suggestions include using a micro-contact modification to repurpose a keyboard key for power on, utilizing sleep states with specific key combinations (like FN + a designated key), and confirming whether the laptop's BIOS has the necessary settings. The conversation highlights the variability in capabilities based on motherboard and BIOS configurations.
