The keyboard and mouse do not work on the windows 7 login screen
Wiktor.K 8562 16
How can I get the keyboard and mouse working again on the Windows 7 login screen after reinstalling the USB port drivers?
Use a PS/2 keyboard or mouse to get back into Windows and then roll back the USB controller driver that was updated [#16235450] [#16235831] If PS/2 input is not available, boot from the Windows installation disc and open the recovery/restore options to repair the system [#16235544] [#16235653] If you can access Device Manager, choose to restore the previous version of the USB controller driver you changed [#16235831]
  • #1 16235440
    Wiktor.K
    Hello and immediately in saying that I am new as a bad category, please transfer. Yesterday I accidentally reinstalled the USB port drivers and it was late I got tired I turned off the computer and in the morning I was surprised when I wanted to log in to the desktop the mouse and keyboard did not respond to movements / buttons only in the BIOS work and otherwise I can not do anything please help .
    Ps. In safe mode also do not work
  • #2 16235450
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Do you have the option of connecting a mouse or keyboard under ps / 2? Then you could use, for example, system restore or install other / proper drivers.
  • #3 16235523
    Wiktor.K
    I have this input but I would have to get a keyboard or a mouse
  • #4 16235544
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    You can also try to boot from the Windows installation disc and select the restore options there.
  • #5 16235549
    dzimen11
    Rate: 8
    If the mouse and keyboard do not work, try changing the bios settings. What Bios do I have? Because I know that some bios have USB keyboard and mouse settings to work properly. If I don't have any settings, change the USB port because the computer may not read the device from it.
  • #6 16235573
    Wiktor.K
    I was poking something in Bios but nothing came of it and I don't know if it is a version but it gives E7996IMS.250
  • #7 16235588
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ dzimen11 the author wrote that it stopped working after the change of drivers, so it has nothing to do with the bios, and the options you write about are for USB keyboard and mouse support.
  • #9 16235619
    Wiktor.K
    It's all still on
  • #10 16235626
    dzimen11
    Rate: 8
    Wiktor.K wrote:
    It's all still on
    Enter safe mode and reinstall the keyboard and mouse driver there or look at the link I gave. Or maybe you had some update at that time because maybe it caused an error?
  • #11 16235632
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ dzimen11 did you read the author's first post at all?
    I especially recommend:
    > I accidentally reinstalled the USB port drivers yesterday
    and:
    Everything you need has already been given, without the ps / 2 keyboard or restoring with the help of the disc the author will not fix anything.
  • #12 16235638
    Wiktor.K
    I was still waiting for updates but I was not at that time aha and did not write an important thing I have a password protected desktop and in the login window the mouse and keyboard drivers will probably not install
  • #13 16235641
    dzimen11
    Rate: 8
    and:
    I'm sorry I didn't read the last one.
  • #14 16235653
    310artur
    Help: 980
    Rate: 670
    Nothing else - either mouse or keyboard on PS2 or try to boot the PC from the Windows installer and choose restore.
    If you get a mouse or keyboard then you can still enter the control panel - troubleshooting - hardware and sound. You will do an automatic repair. For me on Win10 I did in a situation like yours having only a PS2 keyboard and surprisingly automatic repair worked.
  • #15 16235664
    Wiktor.K
    I found such a keyboard with PS2 but I don't want to work if it doesn't work, I'll just look for a new one somewhere
    Added after 42 [minutes]:
    Even before I close the topic after logging in to the desktop I have a problem installing the mouse and keyboard drivers
  • #16 16235831
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    They should install themselves.
    In the manager, choose to restore the previous version of the usb controller driver whose drivers you previously updated.
  • #17 16236499
    Wiktor.K
    Okay, everything works, thanks for closing the topic
The user experienced a failure of the mouse and keyboard to function on the Windows 7 login screen after accidentally reinstalling USB port drivers. Despite the devices working in BIOS, they were unresponsive in safe mode and during login. Suggestions included using PS/2 connections for the keyboard and mouse, booting from a Windows installation disc to access restore options, and checking BIOS settings for USB support. The user later found a PS/2 keyboard, which resolved the issue, allowing the installation of the necessary drivers.
