Opel Corsa D 1.2 2008: Starter Not Turning, Relay Ticking, No Errors in Computer
speedpawel 9666 3
  • #1 16171904
    speedpawel
    Rate: 20
    Hello, I need help, I have a corse d 1.2 petrol from 2008 that refused to cooperate. The problem is that the starter does not turn after crossing the key, you can hear the relay ticking. I checked the fuses, they are good relays, I swapped places with zero reaction. I will add that the corsa normally fires after giving a plus to the starter on this thin red cable. There are also no errors in the computer, I do not know what to do next. Can someone advise something ???
  • #2 16171959
    leinadzs
    Help: 61
    Rate: 143
    you need to review the entire circuit of the starting system, including the ignition switch
  • #3 16172081
    speedpawel
    Rate: 20
    I also looked into the ignition switch yesterday. After crossing the key, I looked with the indicator light in the start-up position, a plus on one cable appears. And there is a possibility that the immobilizer has blocked the starter
  • #4 18208887
    kameleon1983
    Rate: 51
    Buddy, you dealt with this problem, what was the cause?
    I have the same symptoms, the corsa d 1.2 from 2014 does not spin the starter. Briefly applying voltage to the starter, it ignites.
    Fuses approx.
