Samsung WF60F4E0W0W Washing Machine Error 5E: Daily Wash Program Stuck, Door Lock & Filter Issues
Sklepviking 5154 2
  • #1 17112916
    Sklepviking
    I have a problem with the model of the washing machine on the program (daily washing) at 34minutes stops working and does not want to spin. After a moment of standing, the 5E warning (i.e. dirty filter) is activated, the filter is cleaned. The washing machine continues to do the same. And he doesn't want to release the door lock after turning off. Anyone have any idea?
  • #2 17114861
    karol5608
    Help: 109
    Rate: 319
    You need to "walk" check where the cables from the tacho enter the module and carefully check the components on the way to the processor. As a rule, there is also a resistor divider there.
  • #3 17116686
    wiesiekmisiek
    Help: 259
    Rate: 525
    Sklepviking wrote:
    I have a problem with the model of the washing machine on the program (daily washing) at 34 minutes stops working and does not want to spin. After a moment of standing, the 5E warning (i.e. dirty filter) is activated, the filter is cleaned. The washing machine continues to do the same and does not want to release the door lock after it is turned off. Anyone have any idea
    Error 5E in Samsung washing machines is water is not poured from the washing machine tank. The error is signaled when after some time (they wrote that 10 min) from the start of water drainage, the sensor frequency corresponding to the water level is 25.5 kHz or less.
    The reasons are:
    1.) Clogged drain system from the bathtub to the pouring hose (all along the way) to be checked.
    2.) Drain pump performance too low due to blockage, wear.
    3.) Dirty or malfunctioning hydrostat system or broken connection to the module
    4.) Track damage on the module.
