Time during which the battery is discharged by the hazard warning lights
vip03 33968 7
  • #1 6901707
    vip03
    Hello, I have a Ford Mondeo. I have a 60Ah battery there and I have such a problem that the emergency lights turned on quickly (about 2 hours) discharged his battery. I would like to add that I listened to the radio, but the radio itself could play for a long time, even all night long and the battery practically did not discharge at all, and after turning on the hazard lights, it took about 1 or 2 hours. Is it normal and how many approximations should we put such lights on without discharging the battery?
  • #2 6901804
    mb3
    Help: 8
    Rate: 82
    Count yourself how much it should be. Suppose exaggeratedly that one bulb is 15w and there are six of them, and the radio was using 40w (also exaggerated). It gives us about 130W of consumption, i.e. about 11A, 60Ah: 11 gives us over 5 hours of battery operation. So the whole thing was definitely too short because the consumption was counted with a large margin on the plus.
  • #3 6901878
    vip03
    but in fact, it was practically one night that the radio was playing and only on the second night I added emergency ones, although I think that the emergency ones flashed quite quickly, so maybe it also had some effect. I have just checked and it turns out that the directions are 21 W one bulb, so I think I already have an answer now 6 times, it gives about 120W plus the radio that was already playing all night and then another and these 2 hours, I mean that it is emergency together with the radio turned on and then it lasted these 2 hours because the radio itself was playing earlier. Thank you for the reply :) Ps. means, however, such emergency ones are not so economical for the battery and can discharge it quite quickly.
  • #4 6902075
    gimak
    Help: 614
    Rate: 1678
    Yes, to be precise. The power of the direction indicator bulbs on the corners of the car is 21W, while in the 2 side indicators they are probably 5-10W.
    The hazard lights come on periodically, so they consume 40-50% less energy than if they were lit continuously.
    As for the radio, when it sounded with full power, that it was throwing the kennel (another thing when you can listen to something like that), it also milked the battery nicely then - almost like an emergency.
  • #5 6903180
    wopor
    Level 32  
    Help: 175
    Rate: 705
    hello, assume that the emergency power is 90W, periodic operation 50% gives 45W + radios will be about 40W you have 85-90W in total, which gives about 7.5A, with 60Ah battery it gives from a fully charged battery max 7h, but if you give the burner with the radio, and 2h may not be enough, good luck
  • #6 6903395
    eltron
    Help: 36
    Rate: 161
    Count yourself how much the starter needs to start, because it will not even turn when undercharged. The battery must be at least half functional. What if it's diesel? it's more than half because it's 60.
  • #7 6927329
    wsuder
    Rate: 26
    yet the glow plugs which consume about 60A before starting for 10 seconds and when spinning the engine with 20: 1 compression, they do not go out either, the battery probably is not straight from the store, and charging with an alternator ensures topping up of max 90% capacity, the emergency ones work in a cycle of 50 50, but there are also losses when starting the 100w circuit. the radio may have an additional amplifier for the bass speaker. - unfortunately, there is no excess energy in diesel with such a small battery. Currently, to my surprise, in diesel vans /e.g.espace/ the alternator has 1000watt and is water cooled and the battery is 92 ah.
  • #8 6927366
The discussion revolves around the battery discharge issue experienced by a Ford Mondeo owner when using hazard warning lights. The user reported that the emergency lights drained the 60Ah battery within approximately 2 hours, despite the radio being able to play for a longer duration without significant discharge. Various responses analyzed the power consumption of the hazard lights, estimating it to be around 90W when accounting for the bulbs' wattage and the radio's usage. It was noted that the hazard lights consume energy intermittently, which could lead to quicker battery depletion than anticipated. The consensus suggests that while the radio can operate for extended periods, the combined use of hazard lights and radio can significantly impact battery life, indicating that emergency lights are not very economical for battery usage.
