LNB Short Circuit: Identifying & Resolving Signal Loss from Antenna to Socket (N) Connection
kermito83 115223 10
How can I find and fix the short circuit or wiring problem that makes my LNB show "SHORTED" when I connect the antenna signal through wall sockets?
The short is most likely in the wall sockets or coax wiring, and for satellite TV you need RTV-SAT end sockets rather than ordinary TV-RADIO sockets, because only the SAT socket passes the LNB feed correctly [#6944665][#6948599] Disconnect the cable from the converter/LNB and check the other end with an ohmmeter to see whether the center conductor is shorted to the shield [#6944244][#6944251] If you do not have a meter, you can test continuity by putting batteries on one end and a bulb on the other end; if it lights, the cable is continuous [#6948599] Trace the wiring socket by socket for any break or short, because one bad socket can kill the signal even if the rest look fine [#6948483][#6949363] Replace any incorrect or faulty sockets with SAT end sockets and make sure the wiring is continuous from the antenna to the tuner [#6944665][#6948599]
  • #1 6944239
    kermito83
    Rate: 15
    I have a problem because I wanted to put the signal from the antenna from the N into the socket and pick it up in the other room from the socket (so that I did not have to pull the cable) the antenna and the signal were set up nicely so that I could be sure that it is well positioned, but when I plug in the sockets, it pops up I will add "LNB SHORTED" that I dismantled the sockets and tried to shorten the socket and nothing helped. I would like to add that earlier in the apartment (the previous owner) there was a cable cable, but from what I can see, the cable on the cage is cut off. I don't know what to do about it :?:
  • #2 6944244
    supermach
    Help: 46
    Rate: 93
    Unplug the cable from the converter and check at the other end if you really do not have a short circuit.
  • #3 6944251
    edberg
    Level 30  
    Help: 133
    Rate: 117
    You have a short between the center line and the screen. Check with an ohmmeter without connecting the devices, maybe there are cable TV filters that give a short circuit for the DC component (voltage supplying the converter)?
  • #4 6944265
    kermito83
    Rate: 15
    I will add that I am doing it for the first time in my life :) how do i check it?
    But why is everything ok when I connect directly from the antenna?
  • #5 6944665
    dzac4
    Level 36  
    Help: 236
    Rate: 229
    And what are your sockets? TV-RADIO for sure!
    And here it gets short-circuited!
    You must have RTV-SAT end sockets.
    Check the cable as those colleagues have already described.
  • #6 6944770
    kermito83
    Rate: 15
    and how to distinguish them ??
  • #8 6948483
    kermito83
    Rate: 15
    yesterday I struggled with the sockets and it turned out that in the third room there was a short circuit in the socket. The short circuit is gone, but the signal is not there, I do not understand it.
    Is this due to the fact that I have to change the sockets for the satellite TV to those with a screwed input or maybe the sockets are not connected to each other? But on the other hand, if they were not connected, the short circuit in the third room would not matter to the rest ... I don't know, but that's what I came up with. How can you check if the sockets are connected to each other, e.g. two specific sockets? I would like to add that by briefly twisting the cables from the socket (all were unscrewed) nothing helped and there was no signal.
    telrad
    Help: 30
    Rate: 47
    The easiest way in your case is to connect the batteries at one end and the light bulb at the 2nd end and you will see if they are connected. You won't do anything without even the simplest equipment. Buddy kermito83 if you don't know it, ask a friend or some electrician, it will help you because it's a waste of your time.
    Only such a socket ensures the transmission and connection of the satellite signal from the antenna to the tuner.
  • #10 6948996
    dzac4
    Level 36  
    Help: 236
    Rate: 229
    An electrician in this case can do harm, not help!
    There are SAT-TV installers for such cases and it is best to go to one and ask for the service.
    I can see that even these hints did not get you anywhere or you are so dumb.
    I wrote once to replace the sockets and you still yours.
    The cow is smarter and does not offend anyone.
  • #11 6949363
    supermach
    Help: 46
    Rate: 93
    Do you have at least an ordinary "digital" multimeter?
    If I were you, I would look "by the thread to the ball" where you still have a break / short circuit, and after eliminating them, I would "pin" the wires from the antenna to the tuner so that they would constitute a "continuous" circuit (of course, taking care to "short-circuit" :) ). As if other cols were "snappy" :) , write to me at PW.
    Good luck.
The discussion revolves around troubleshooting a "LNB SHORTED" error when connecting an antenna signal through sockets in a home setup. The user initially set up the antenna correctly but encountered signal loss when attempting to connect it to sockets in another room. Responses suggest checking for short circuits using an ohmmeter, ensuring the correct type of sockets (RTV-SAT) are used, and verifying the connections between sockets. A method to test socket connectivity using batteries and a light bulb is recommended. The user also faced a short circuit in one socket, which was resolved, but the signal issue persisted, leading to further inquiries about socket compatibility and connection integrity.
