Nc+ Decoder Issue: LNB Shorted, Signal Loss in Both Converters - Possible Trail Hit?
cyborg50 30303 6
  • #1 16730025
    cyborg50
    Rate: 14
    Hi.
    Today, in my nc + decoder, my parents' picture died and both converters lack signal strength and quality. The NLB short circuit error appears.
    The installation has been working for over 2 years without problems, today nothing has been done. The converter is dual (i.e. 2 cables from one) :)
    After unplugging the converter and decoder, the cables do not have a short circuit.
    Is it a good idea that the trail hit the converter?
    Wojtek
  • #2 16730046
    sosarek
    Help: 9320
    Rate: 15532
    cyborg50 wrote:
    the cables have no short circuits.
    How checked?
    You can replace the converter, check the plug making.
    Z
    Pka, Poznań, 60-850
  • #3 16730284
    maksar
    Help: 177
    Rate: 1030
    You combine well.
  • #4 16730318
    LeDy
    Help: 1990
    Rate: 2938
    I have not encountered a converter damage that makes it short circuit. Combining so bad. Sooner, water somewhere rusted and I found that the short circuit was in the decoder head. (Rust, pieces of rust torn off)
  • #5 16730445
    cyborg50
    Rate: 14
    I also thought that water or what. But I turned it dry. According to me, it is suspected that 2 separate cables will hit the trail at the same exact moment. Tomorrow I will try to replace it with some other converter and see what will happen.
  • #6 16730450
    sosarek
    Help: 9320
    Rate: 15532
    TWIN in the will of accuracy.
    Z
    Pka, Poznań, 60-850
  • #7 16731704
    cyborg50
    Rate: 14
    I replaced the converter, everything works, thank you for your help
The discussion revolves around an issue with an Nc+ decoder where the user experienced a loss of signal strength and quality, accompanied by an LNB short circuit error. The installation had functioned without problems for over two years. The user suspected that a trail hit might have affected the dual converter setup, as both converters were showing issues simultaneously. Responses suggested checking the connections and considering water damage as a potential cause. Ultimately, the user replaced the converter, which resolved the issue.
