AUTOCAD 2018 - Export PDF with Original Dimensions: A2 Paper, 1:50 Scale & Print Settings
siwykonik 8751 4
  • #1 16805786
    siwykonik
    Rate: 11
    While creating a project in autocad, I ran into a problem while printing it. Namely, I don't know how to export it to PDF so as to keep the original dimensions. The design should be printed on A2 in 1:50 scale. In the printing options, I probably clicked everything and nothing helped.
    Could someone explain how to skillfully set such scaling? In the attachment I am uploading the project file (autocad-2018 version)
    • BO Typowa kondygnacja.7z (39.03 KB) You must be logged in to download this attachment.
  • #2 16805904
    kindlar
    Help: 919
    Rate: 1622
    Have you used PDFcreator?
  • #3 16805934
    siwykonik
    Rate: 11
    No, it's some kind of external program \ extension?
    Use viewports to set AutoCAD PDF scale
    #4 16806140
    KrisNext
    Help: 5
    Rate: 110
    To print in pdf format, you use the export to pdf command or any other pdf printer you have installed on your computer, e.g. bio pdf
    As for scaling, it is done using viewports. In order not to write too much, you have a link here where it is well explained.
    http://materialy.wb.pb.edu.pl/marekmotylewicz...ia-arkuszy-wydruku-w-AutoCAD-m.motylewicz.pdf
    By the way, introducing colors and line thickness in your drawing will definitely improve the clarity of the whole and the scratch will look more professional.
  • #5 16806336
    siwykonik
    Rate: 11
    Thanks for these materials, I was looking for such a tube. So far I solved the problem superficially and printed it as yes, because I need it quickly. Thanks gentlemen, greetings and closing.
