How to Enhance Contrast and Clarity of a PDF Document for Printing?
karina 23804 4
  • #1 2014018
    karina
    Help: 21
    Rate: 41
    As in the subject - I have a document in pdf format that I need to print. However, it has very poor quality.
    And here is my question - is there any option, e.g. in Adobe Acrobat, to improve the contrast of the above-mentioned document, so that the print becomes clear.
  • #2 2014040
    jiwaniuk
    Help: 142
    Rate: 145
    You can do it like this:
    1. In Adobe Acrobat, save the document in a graphic format (or perhaps in some other converter). There will be one file per page.
    2. In the graphic program, combine with the graphics (e.g. in InfranView).
    3. Create *.pdf again in Adobe Acrobat.
    Perhaps newer versions of Acrobat already have this feature in them. I have access to AA 5.0 and this one does not.
    I greet everyone
    janek
  • #3 2040641
    karina
    Help: 21
    Rate: 41
    I did not sharpen the document. I left it as it was. I adjusted the print quality in the printer properties and everything is OK.
    Please close the topic.
  • #4 2040672
    grzegorzsawczak
    Help: 18
    Rate: 14
    Some PDFs have print quality limitations. You can get rid of them, but the road is not easy.
    If you have ACROBAT Pro... then open the document and save it with a different name, but remove the security before saving.
    Regards.
  • #5 2040681
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3826
    :arrow: ...then why didn't you lock it up buddy karina :?:
    :arrow: SHUT ME UP How to Enhance Contrast and Clarity of a PDF Document for Printing?
    Now you can do it yourself :D you should even do it yourself :!:
