Code F47 Whirlpool ACM 703 BA: Induction Plate Display Error - Connection & Troubleshooting Guide
krystian2 69001 6
  • #1 7279533
    krystian2
    Rate: 82
    Hello, after connecting a new whirlpool induction plate, the F47 code appears on the display. The plate is connected according to the diagram in the manual and the rating plate, phase conductors to terminals L1 L2 L3, protection to Pe and neutral to N1 bridge N2 What does this code number mean? Please help
    eeban
    Home appliances specialist
    Help: 385
    Rate: 1497
    call the service board under warranty!
  • #3 7283672
    krystian2
    Rate: 82
    Thanks for the answer, the instruction gives the same. I mean the marking of this code, is it, for example, an incorrect connection and whether you can delete the error yourself. One more thing, I know it may be strange, but this is the only thing that comes to mind, does the sequence of phases when connected matter?
    mrhari
    Help: 835
    Rate: 3239
    In this case, the sequence of the phases does not matter. This error can occur when one phase is missing, it also means a problem in internal communication between modules, that's the theory.
    Go ahead!
  • #5 7284030
    krystian2
    Rate: 82
    Thanks a lot for that. This error pops up first on the burners on the right and then on the left side of the CD and blinks all the time at all. Another question is whether usually SEP E up to 1 kV is enough to enter in the warranty or not enough for the service to take into account
  • #6 7284259
    eeban
    Help: 385
    Rate: 1497
    enough
  • #7 7526983
    krystian2
    Rate: 82
    The fault in the display of f47 was due to the lack of one of the phases. This type of induction hob works on two phases. On one of the phases there was a wire break in the power cord. The fault is difficult to locate because nothing came out during the measurements, the voltage was on
    disc position no longer. Defect removed, replacement of the power cable, I was too busy and without service. Thank you for your help
The discussion revolves around the F47 error code displayed on a Whirlpool ACM 703 BA induction plate after installation. The user connected the device according to the manual but encountered the error, prompting inquiries about its meaning and potential self-resolution. Responses indicate that the F47 code typically signifies a missing phase or internal communication issues between modules. It was clarified that the phase connection sequence does not affect the error, and one user resolved the issue by replacing a faulty power cable that had a wire break. Warranty considerations regarding the SEP E rating were also addressed, confirming that it is sufficient for service claims.
