Whirlpool ADP4739SI Dishwasher Error F6: Programmer Damage & Triac Testing Queries
Piotr520 6294 9
How can I diagnose a Whirlpool ADP4739 dishwasher that fills, then drains after about 2 minutes and shows error F6?
The symptom may actually point to an Fb error rather than F6, so the first thing to verify is the exact code and then check the hydrostat/OVI sensor in the bottom filter area, which should be a transparent plastic part that can be cleaned gently with a cloth [#16855377][#16855246][#16855288] If it is Fb, the likely fault is the switching valve/pump diverter valve assembly, not the main programmer, and it may need replacement [#16855456] That valve can fail because of a leaking shaft seal, which can affect the microswitch and operation; for a non-specialist, replacing the whole valve is the easier and safer option [#16855500] Since the microswitch was already tested and found working, the remaining checks should focus on the hydrostat/OVI sensor and the diverter valve assembly [#16855246][#16855288][#16855500]
  • #1 16855171
    Piotr520
    Help: 68
    Rate: 243
    Hello everyone.
    There is a problem with the Whirlpool ADP4739 dishwasher. The dishwasher draws water and, after about 2 minutes, drains and displays error F6. The programmer has found damage to the programmer. After opening the programmer, at least visually you cannot see any burned elements or paths. I checked the triac No. 1 (ACS 1086S S844) with a multimeter and they do not show short circuits. As for Triac No. 2 (ACS 120 07S), I'm not sure it's functional. When checking the multimeter I have set the circuit continuity (note). When I put the minus to the G foot and the plus to the T2, it is conduction as with triacs No. 1 but without taking the minus probe from G and by placing the probe to T1, there is conduction as if the triac was turned on. This phenomenon does not occur if I apply a plus probe to the G foot. It also does not occur with triacs No. 1. As for triac No. 3 (RNM P2F), it conducts in every position, but it is possible that without desoldering the measurements are incorrect and after the determinations I am not sure if it would be a triac. The resistors are all checked and hold resistance as normal by designation.
    Checked micro switch on the water distributor valve in working order.
    I am not an electronics specialist, so please be forgiving. What else and how can I check?
    Regards.
  • #2 16855246
    glyfin
    Hello, check the hydrostat
  • #3 16855271
    Piotr520
    Help: 68
    Rate: 243
    How? Is there any resistance testing?
  • #4 16855288
    glyfin
    If I'm not mistaken, there is an OVI sensor, it acts as a hydrostat, I am in the place of the filter at the bottom of the dishwasher, try to clean it only with a cloth, it's something transparent, plastic
  • #6 16855415
    Piotr520
    Help: 68
    Rate: 243
    Micro switch tested and functional. This was a friend's dishwasher and I asked if it was sometimes just a Fb error because from the symptoms and description of another dishwasher 2 minutes matches Fb.
    I am adding a description
    • 74_15_1.pdf (490.99 KB) You must be logged in to download this attachment.
  • #8 16855469
    Piotr520
    Help: 68
    Rate: 243
    Is it possible to check this valve without taking it apart? I remember when I was checking the micro switch there were probably two diodes and under this metal frame I think the winding.
  • #9 16855500
    nares
    Home appliances specialist
    Help: 1521
    Rate: 3394
    This valve has a seal on the shaft and is often water permeable, which also contributes to incorrect operation. So, you have to replace the microswitch and sealant (it's hard to get it).
    It is easier and safer for a layman to replace the entire valve - you need to look for the cheapest on the network.
  • #10 16857302
    Piotr520
    Help: 68
    Rate: 243
    It is unlikely to be the fault of this valve. I undressed it as I was checking the micro switch. Dry inside, no sign of water ingress.
The Whirlpool ADP4739SI dishwasher is experiencing an F6 error, indicating potential programmer damage. The user has visually inspected the programmer and found no obvious damage, but is uncertain about the functionality of Triac No. 2 (ACS 120 07S). Other users suggest checking the hydrostat and the OVI sensor, located near the filter, as they may contribute to the error. There are discussions about the possibility of an Fb error, which could change the troubleshooting approach. The valve associated with the error may need replacement, but the user has already inspected it and found no signs of water ingress. The conversation emphasizes the importance of testing components like the micro switch and valve for proper functionality.
