Whirlpool ADP 6949 C WH Dishwasher: Error F5, Heater Replacement, Service Code 8511 763 10990
bartefficom 14118 9
What is the most likely cause of the Whirlpool dishwasher F5 error when the circulation pump only works after tapping, and should the pump or the whole dishwasher be replaced?
The most likely cause of the F5 error is a worn circulation pump/impeller with too much clearance, so the rotor occasionally binds and tapping the pump temporarily frees it [#16584921] The behavior described by the opener matches that diagnosis: the dishwasher starts after tapping the pump housing, then fails again under load, so the circulation pump assembly is the first part to replace [#16586920] After fitting a new pump, the machine still showed unstable starts and only worked again after repeated tapping, which suggests the pump/motor assembly was still marginal or not fully cured by the replacement [#16593340] In the end, after several more washes and tapping at the right moments, the unit became usable again, but the motor “howls” a bit, so the thread leans toward a worn pump rather than a clearly proven controller fault [#16632443] The discussion does not confirm the module as the root cause; it only leaves open the possibility of additional electronics damage if a new pump does not solve it [#16632443]
  • #1 16584589
    bartefficom
    Rate: 10
    Hello everyone,
    Dishwasher Whirlpool ADP 6949 C WH model 8511 763 10990 service code.
    Last year you came from the service and replaced the heater, then the error Fb (or F6) was displayed, I was laughing that the dishwasher was not connected to the internet and I was hacked by Facebukowcy household appliances. But to the point he replaced the heater but after a few weeks this error again.
    He arrived as part of the complaint, replaced the heater, tapped the electronic module with the screwdriver handle (this was to help the transmitter to be stuck together) and announced that the module should be replaced (PLN 500). After timid protests, he said that it would work, but it no longer guarantees the next heater replacement because it is the module's fault. Fortunately, he said which contactor (I exchanged and calm). The whole module 500 contactor 20 PLN. At the same time I asked about this error Fb said that 95% of cases are overdrive (PLN 200). Some rummaging in this forum and someone wrote moisture and rotten microswitch (PLN 2). I had a good few seconds of fun with the soldering iron and again peace for a few months.
    But recently, a few days ago, the stairs began:
    - F5 error is displayed squeaks and does not wash;
    - The NCT sensor is on the network or the washing arms are not rotating (pump, flow sensor);
    - Reset, inserted washing and miracle works flawlessly, but only until the next day;
    - I disassemble the dishwasher, check the contacts, start the washing pump rotor if it is not blocked, put it together, again a miracle (doing rinsing);
    - I start the washing program, the water pump does not start the washing pump (the valve motor can be heard) and F5;
    - I dismantle contacts again, OK transitions, I disassembled the OK washing pump, OK pump relay on the module, I assembled;
    - Magic ;) completed the rinsing program, activating the ECO program (95% previous use) performs 3/4 of the program and again error F5;
    - Mr. on the service, based on the description, says module or pump (I will replace it, but 500 PLN module or 370 PLN pump), and I am no longer strong
    - I don't know if more elements will fall :)
    - The pump is EC (electronically commutated) it comes with 230V power supply and three cables from the driver which is on the electronic module controlling the entire dishwasher, from what I noticed in the pump is a pile of electronics including 6 large transistors and a large capacitor and several chips.
    I suspect that the contactor feeds to the power supply on the 230V pump, the power supply provides crafted voltages to the coil of the rotor, which gets the voltage decided by the driver on the module and sends control signals to the pump with three cables (maybe variable speed support is even implemented). The pump was manufactured by Blackmann (model VSM E1 SWB).
    Advise Ladies and Gentlemen, is it still worth fighting or give yourself a break and look for a new dishwasher? Is aware of the planned aging policy for the product. But if someone can discover a countdown timer in the control module and reset the indication for "first use" then I will gladly use ;) Or maybe it is this power supply at the pump or driver on the module is already falling and you need to replace something. I count on help.
    Greetings to all
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3387
    There is probably too much clearance on the pump impeller, hence its occasional blocking.
  • #3 16584938
    bartefficom
    Rate: 10
    Hmmm, I dismantled the entire pump in the rotor part (the electronic part is rather undassembled).
    The whole works wet.
    There are two hard metal sleeves for bearing there.
    They didn't look like they were worn out.
    On the rotor and the outer winding, one can see traces of something scratching the surface, but it can be that something has once gotten between and scratched.
    Certainly it hasn't ripped off the plastic in which the rotor is flooded.
    It turns loose in my hand and nothing scrubs.
    nares
    Help: 1515
    Rate: 3387
    bartefficom wrote:
    On the rotor and the outer winding you can see traces of something scratching the surface
    Warm, getting warmer ;)
  • Tapping pump housing temporarily clears F5 error
    #5 16586920
    bartefficom
    Rate: 10
    Yesterday I tapped the pump housing with a rubber blunt tool :D and the entire rinsing program started.
    After inserting a full wash, she stood at exactly the same time as a few days ago at 1:10 to the end of the wash and of course F5 error.
    Reset tapping again and the entire 40 minutes fast program was painless.
    I ordered a new pump. It should be today or Monday.
    Swap and let you know if it helped.
  • Suspected overload valve causing intermittent pump stalling
    #6 16593340
    bartefficom
    Rate: 10
    The pump (new) works but I had to change the O-ring from the old pump.
    I translated the O-ring because the one at the pump was old and cracked and, moreover, slightly thinner
    Unfortunately, I can't trumpet my success because it comes with strange breaks. As if she would stutter from time to time.
    In addition, as I was concerned, I opened the door and closed it again, it did not resume work and error F5 was displayed. What could be the reason ?!?
    I'm sure I assembled it correctly.
    The only thing that gives me peace of mind is that tapping the turbine brings improvement (means the pump starts) but works very unstable.
    Now I removed all possible plastics and gaskets, cleaned from various shavings (although there was not much) and let go with the cleaning agent full cleaning (SOMAT).
    If that doesn't help, I'm waiting for suggestions?!?
    Greetings to all
    Ps Could this be a crazy overload valve? In my opinion, it only directs water to 1 or 2 washing arms (dual zone operation).
    peter falk
    Help: 1158
    Rate: 3362
    What oring and what is it about? What did you combine with the new pump?
    nares
    Help: 1515
    Rate: 3387
    bartefficom wrote:
    Pump (new)
    For sure? ...
  • #9 16594026
    bartefficom
    Rate: 10
    SOMAT did not help ;)
    New bank pump (I suspect that storage chair 04.2014 BLDC checked).
    There were no signs of use, only this O-ring I suspect that old age had caught up with him.
    Sealing O-ring OE 82 mm, between pump motor and turbine.
  • #10 16632443
    bartefficom
    Rate: 10
    After a short break.
    You can say I gave up :D
    It is a pity to invest in "planning an aged product" ;)
    After several washes with the turbine tapping - at strategic times of washing - the unstable behavior of the washing pump motor gave way.
    I twisted the dishwasher and for now it washes and works, so partial success.
    Then the engine "howls" a bit.
    But I decided that PLN 200 for the pump motor was the last money I spent on it.
    It now works until you "whip" any part and replace it with a new dishwasher.
    It is possible that:
    - in the controller there is such a program counting the life time (generating random problems later);
    - the controller is individually calibrated to the mounted engine (although I do not know what they would be different);
    - another power supply was used in the engine electronics;
    - the control module has also been damaged (probably only the manufacturer can tell).
    Anyway, I'm closing the topic.
    Thanks again to my colleagues for help.
The discussion revolves around the Whirlpool ADP 6949 C WH dishwasher, specifically addressing recurring error F5 after a heater replacement. The user initially experienced an F6 error, leading to a service call where the heater was replaced. However, the error reappeared, prompting further investigation. Users suggested that the pump impeller might be blocked due to excessive clearance, and one user reported success by tapping the pump housing, which temporarily resolved the issue. Despite replacing the pump and O-ring, the dishwasher continued to exhibit unstable behavior, with intermittent errors. The user expressed frustration over the ongoing issues and considered the possibility of a faulty control module or other electronic components. Ultimately, the user decided to continue using the dishwasher until it fails completely, indicating a reluctance to invest further in repairs.
