Inserting the | Pipe Character for Scripting on Different Keyboards
danshi 101426 13
How do I type the pipe character `|` on my keyboard for use in scripts?
To type the pipe character `|`, use the key combination that matches your keyboard layout: on many keyboards it is Shift + the backslash key near Enter or Backspace, and on some systems you can also enter ASCII 124 with left Alt + 124 on the numeric keypad [#719790][#723592][#719746] Yes, the broken vertical line you see is the same `|` character [#721088][#723602] In Linux scripts it is the pipe operator, for example `ls -l | grep log` [#726639]
  • #1 719640
    danshi
    jo
    how to insert this "|" character from the keyboard, needed to write scripts ??
    danshi 8)
  • #2 719746
    Akane
    Help: 144
    Rate: 33
    you press the left ALT and on the numeric part of the keyboard you type 124, you let go of ALT
  • #3 719790
    jiwaniuk
    Help: 142
    Rate: 145
    For me, this sign is on the key (Back Slash + Shift) |.
    I guess this is his standard spot.
    I greet everyone
    jjanek
  • #4 720551
    danshi
    jo
    well, but when I type this character, it is interrupted instead of a straight vertical line! Is it the same sign - does it fulfill the same function?
    danshi 8)
  • #5 720583
    Akane
    Help: 144
    Rate: 33
    I wrote a program that shows the ascii code of the first character from the clipboard - copy the | character to the clipboard and run the program, and it should write
    sign | has the code 124
    press enter
    • GetClipboardASCII.zip (61.23 KB) You must be logged in to download this attachment.
  • #6 721088
    elektryk
    Help: 439
    Rate: 241
    Best check it out, you'll know for sure. In my opinion it is the same.
  • #7 723592
    badboy
    you have to press shift and the key that has a slash and a dashed dash (I don't know what it's called :P ) for me it is near backspace, and in other keyboards I saw enter below
    here is an example that it works ||||||||||||||| ;)
    best regards
  • #8 723602
    Dr.Zepsuj
    Help: 6
    Rate: 35
    it is the same character as the dash with a gap. | . Enter it in the attacker you will see.
  • #9 723616
    Akane
    Help: 144
    Rate: 33
    if you have a german keyboard then (polish programmer's layout) "shift" + "#" enter wheel
  • #10 724006
    ad_min
    this character is a circle [enter] above shift (you press shift + \ and it becomes ||||||| ..... at least that's the way it is on my keyboard) ...... you can also try the array of characters .... Start -> programs -> accessories -> system utilities (I think) -> character table ..... you have to find it there
  • #11 725079
    zeberko
    Level 32  
    Help: 143
    Rate: 43
    My keyboard
    Shift + the first key to the left of backspace
  • #12 726618
    danshi
    jo
    It just so happens that I know how to insert this character under windows, but I don't want to insert it under linux, or rather when writing a script in the shell (instead of a vertical line, a vertical broken line pops up).
    danshi 8)
  • #13 726639
    zoltar
    Help: 12
    Rate: 24
    As it is a script in schelu and on linux, it is definitely a processed dash. There is the so-called dynamic stream. If you want one comedy to affect the other, for example: "ls -l | grep log".
  • #14 729516
    danshi
    jo
    Well, this is what I mean by inserting this character, a broken vertical line pops up and I do not know if it is the same as the processed line.
    danshi 8)
    Then just read the answers :(
The discussion revolves around how to insert the pipe character "|" for scripting purposes on various keyboard layouts. Users provide multiple methods for different keyboards, including pressing "Shift" with the backslash key, using "ALT" with the numeric code 124, and specific combinations for German and Polish keyboards. There are also mentions of issues with the character appearing as a broken line instead of a straight vertical line, particularly in Linux environments. The ASCII code for the pipe character is confirmed to be 124, and users suggest checking character maps for additional solutions.
