How to Type a Vertical Line (|) Character on Windows 98 Keyboard?
sampo 31415 6
  • #1 1241560
    sampo
    Help me. I received a series in which it is like this... F5RZZ-PP4QCC|3RSXMSF........ How can I get a vertical line? I can`t paste it. The program doesn`t accept it. (in Windows) Win98.
  • #2 1241633
    dasko
    Help: 29
    Rate: 72
    What is this series supposed to be for? Or maybe this vertical line is a separation of two series?
  • #3 1241648
    Łuk_F
    Help: 34
    Rate: 12
    The vertical line is on the button under the Backcpace key. There is also a \ sign on this key. However, don`t be fooled by the character on the keyboard, as it shows two short lines. In some programs it is displayed as one dash, and in DOS, for example, it is displayed as a key.
    I hope I helped you.
  • #4 1241658
    sampo
    4RFDDK-F5RZZ-PP4QCC|3RSXMSF 4QZDNK-XZ6FS-78BSR7|JX3CTK9 - the whole form of it, it doesn`t accept either way.ACDSee7.0.47 I haven`t found a good series yet.
  • #5 1241773
    marcinj12
    Level 40  
    Help: 1024
    Rate: 250
    This vertical line also looks like some sort of separation to me. And just in case this is not the case, you have this icon on your keyboard: SHIFT+\ . |||||||||||||||||||||||||||||||||||||||||||||
    It`s possible that you have or it inserts a line divided in the middle (two lines) - it`s one and the same. And if anything, you can always press left ALT and type 124 from the numeric keyboard.
  • #7 1241915
    sampo
    marcinj12 wrote:
    This vertical line also looks like some kind of separation to me. And just in case this is not the case, you have this icon on your keyboard: SHIFT+\ . ||||||||||||||||||||||||||||||||||||||||||||||
    Simple, but it helped. That`s a plus. He came in, I didn`t even have time to blink. Thanks.
The discussion revolves around how to input a vertical line (|) on a keyboard while using Windows 98, specifically in the context of entering a series of codes for ACDSee software. Users suggest that the vertical line can be found on the key below the Backspace key, which also features a backslash (). It is noted that in some programs, the vertical line may appear differently. Additionally, users mention using the ALT key combined with the numeric keypad to type the character by entering 124. The conversation also touches on the method of pasting text and the necessity of purchasing ACDSee versus using free alternatives like IrfanView.
