Windows XP – why won’t Alt+L type “ł” on Polish Programmer keyboard?
prokopcio 32842 2
  • #1 3067485
    prokopcio
    Help: 39
    Rate: 143
    I have this problem - this is the second time, but the problem somehow disappeared.
    When I press alt+l in the text entry fields, nothing happens and I should enter "ł", but if I press shift+alt+l, I enter "Ł" (capital letter) normally, and vice versa - if I switch to writing in capital letters letters (caps lock), you can't type a capital "Ł" but a lower case one works normally - shift+alt+L - that's how I type it :D . I will add that this is a laptop, my friend has the same problem with another laptop, other Polish letters work properly with alt (programmer's Polish keyboard set). In safe mode, the keyboard works fine. Windows XP prof... system does not work properly, only "ł".
    PLEASE HELP.
  • #3 3067585
    prokopcio
    Help: 39
    Rate: 143
    kill me... :-)
    I just tried to search but I didn't know what to enter into the search engine... best regards and thank you.
