How can you integrate lighting and appliance control in a smart home?
admiral 8063 5
  • Seeking integrated remote control for room appliances
    #1 7293039
    admiral
    Hi, I’m currently in the process of finishing off my house...
    I’d like to find out how I could control, for example, a single room – what I mean is being able to use a remote control to switch on a lamp, turn on the TV, lower the blinds, and so on.
    I’ve searched online but haven’t found a specific answer as to where I could get such equipment or, alternatively, how to make it myself.
    I have a SEP.
    Best regards ;P
  • Seeking remote control for room-wide home automation
    #2 7293086
    avatar
    Level 36  
    Help: 159
    Rate: 416
    admiral wrote:
    Hello, I’m currently in the process of finishing my house...
    I’d like to find out how I could control, for example, a single room – I mean being able to use a remote control to switch on a lamp, turn on the TV, lower the blinds, and so on.
    I have a SEP
    Best regards ;P
    Use some sort of home automation system?
    Available to buy on Allegro?
  • #3 7293135
    admiral
    That’s exactly the phrase I was looking for. Thanks ;P
  • Xcomfort suits simple retrofits, but wired systems scale better
    #5 7303087
    controlhome
    I have a SEP
    Best regards ;P
    For simple, not-too-complex systems, I’d recommend – just like the chap above – Xcomfort. Personally, I only install this system in properties where the wiring is already in place and no renovation is planned. In such situations, it’s the ideal system. Although it certainly won’t be possible without a few minor modifications (e.g. power supply to the control panel, detectors or solenoid valve controllers – those cables are always missing).
    Generally speaking, the system is fairly straightforward, cheap to install and programme. With EIB or LCN, you’d have to fork out several thousand just for the ability to programme it (software, certification, gateway, etc.). With Xcomfort, all you need to do is buy a single device for a few hundred zlotys; the basic version of the software is free. You can also ‘program it with a screwdriver’, but only simple functions.
    Another such simple system from a well-known company is Legrand’s InOne, but I haven’t had any experience with it. This system can also be installed (implemented) once the wiring is already in place.
    Generally speaking, with more complex systems, Xcomfort isn’t actually that cheap – its binary outputs and inputs are incredibly expensive. Even EIB options are cheaper.
    Wired systems (i.e. those requiring an additional cable or cables for communication) are much better and offer far greater possibilities.
    If you have any specific questions, do drop me a line – I’ll try to help.
    Best regards,
    Grzesiek
  • #6 7304805
    admiral
    Thanks, Grzegorz!
    I’m closing this.
    [Akrzy]
