Finding IP Address from MAC Address: Tools and Commands to Use
szmytu 46323 17
How can I find a computer’s IP address on a local network from its MAC address?
If the host is on your local LAN, the usual way is to make it appear in the ARP table by pinging the subnet or the hosts one by one, then run `arp -a` and match the MAC address to the IP address [#720820][#853906] Another practical place to check is the ARP table on the router or server that carries the traffic, since it can show the MAC/IP mapping directly [#2333910] If you prefer a tool, forum users mentioned utilities such as Advanced IP Scanner, WinSuperKit, CommView, and Cain and Abel for discovering this mapping [#848114][#853864][#18796846][#720827] One reply also suggested `arping`, but it was noted that it is not available by default on Windows/Unix and may not work in every network setup, especially with managed switches [#854521][#854554]
  • #1 720794
    szmytu
    I have a question, is there any program or command that will find the IP address of a computer on the network after entering the MAC address of its network card.
  • #2 720820
    SQ9PXB
    Help: 75
    Rate: 59
    hmm, nothing specific comes to my mind at the moment, but there is a method that can be checked "on foot", if the network is small, you can use the appropriate program to ping all computers in turn and then enter arp -a -> show ip of computers and their mac, then you can manually try by. mac what is the ip
  • #3 720827
    leoha
    Help: 18
    Rate: 8
    Hello !!
    I used to use a program called "Cain and Abel" or something like that and I think it was there ... I don't know because I don't currently have it...
    Check here: www.oxid.it maybe there will be something you are interested in
  • #4 720833
    szmytu
    As for checking on foot, it's rather out, I've already tried but I'm too impatient
  • #5 848079
    oli
    Rate: 16
    In xp you can get it by typing ipconfig/all in run
  • #7 853864
    Gelip
    Level 36  
    Help: 324
    Rate: 611
    R3x, CommView
  • #8 853906
    beukot
    arp
    It is on both Windows and Unix.
    Windows:
    Interface: 192.168.1.4 on Interface 0x1000002
    Internet Address Physical Address Type
    192.168.1.1 00-60-97-da-2b-c2 dynamic
    FreeBSD:
    laptop (192.168.1.3) at 00:00:e8:93:0e:fb on xl0 permanent [ethernet]
  • #9 854521
    rasz
    Help: 31
    Rate: 10
    oh god, just type arping in the console :)
  • #10 854554
    beukot
    rasz wrote:
    oh god, just enter arping in the console :)
    Windows doesn't have it, unix doesn't have it by default
    system.
    Besides, if the user is connected to a managed switch, it's arping
    It will not work.
  • #11 855097
    rasz
    Help: 31
    Rate: 10
    system.
    It will not work.
    Windows doesn't have - is it my fault? :)
    I don't know what a managed swich has to do with arping
  • #12 968224
    marek216
    Help: 1077
    Rate: 932
    I have a similar problem, but none of the above suggestions work, neither recommended programs nor arp, the physical address is constant, but unfortunately the IP address in the case of the type that scanned me is probably variable because it cannot be determined (at least I can't)
    here is the address 00-30-4F-30-96-E1
    can someone decipher it, if I find the IP, maybe I will find the type faster.
    Thanks
  • #13 984320
    beukot
    Managed switches are blocked from showing addresses by default
    MAC of connected users. It will show your [swicha] MAC address which
    mediates in communication between users.
  • #14 2333173
    Ucio
    does anyone know where i can download r3x??
  • #16 2333910
    mbo
    Help: 2333
    Rate: 845
    What is this nonsense?
    None of the switches have anything like this by default.
    On managed switches, at most, VLANs or MAC blocking on specific ports can be set.
    With a switch, none of its MAC is involved in the transmission, it is only for managing the switch.
    The router will give you your MAC.
    Thanks
    The easiest way to read it is from the ARP of the router or server through which the traffic to the world passes.
  • #17 2336229
    mcz1
    Level 19  
    Help: 21
    Rate: 26
    You can also use any sniffer such as ethereal www.ethereal.com and connect the old hub along the signal path and at the same time log packets with another computer and then look for packets with a suspicious poppy. Of course, the client must be active on the network at this time.
  • #18 18796846
    koperk
    I'm resurrecting the topic but maybe someone will find it useful
    Advanced_IP_Scanner
The discussion revolves around methods to find an IP address from a MAC address on a network. Various tools and commands are suggested, including using the command "arp -a" after pinging devices, and programs like "Cain and Abel," "WinSuperKit," and "R3x." Users also mention using "ipconfig/all" on Windows and "arping" in Unix systems. The limitations of managed switches in revealing MAC addresses are highlighted, along with the suggestion to use packet sniffers like Ethereal for monitoring network traffic. Advanced IP Scanner is also mentioned as a useful tool for this purpose.
