How to Scan Local Network for OBK Devices After WiFi Pairing and Find Assigned IPs?
p.kaczmarek2 594 6
  • JavaScript IP scan idea for pairing page
    #1 21691640
    Rate: 12976
    @divadiow @insmod @max4elektroda
    I've got some random idea on how to improve pairing with WiFi. Currently, when you pair device with your router, you don't get to see a new IP that was received it. And we don't have a mechanism to have both AP and STA at the same time....
    But what if we add a little script to pairing page? Remember the device MAC in Javascript and then, in JS loop, iterate local IP addresses (?), query obk endpoint and see if there is a matching one?
    There is however one issue - can we somehow figure out the range of IP addresses to check while being in that browser page? I usually pair my devices on my laptop, which is also connected to network via cable... what about phones? If you exit device AP and connect back to your WiFi, would that still work?
    I didn't do any testing yet, it's just a random idea
  • #2 21691668
    Help: 451
    Rate: 921
    yes, that'd be useful. kinda like how Tasmota web installer gives you the link to real device after you've configured and joined wifi? Won't that mean having OBK join wifi without reboot? or joining, scan/reporting IP to browser then rebooting?
  • Browser-based LAN scan for OBK devices
    #3 21691673
    Rate: 12976
    I think ESP has dual AP + STA mode support. We dont' have this officially in OBK.
    I am rather thinking about a little Javascript that queries first common gateway/ip addresses and then scans network. How often do people have 192.168.0.1 LAN with 255.255.255.0 mask? There are 255 IPs to check (or less, we can skip gateway, etc), I don't think that checking 255 IPs would take long in a modern browser. You can also play with it in separate html file, ask ChatGPT to create a scanner that queries network for tasmota devices, OBK supports cm ? cmnd STATUS endpoint like Tasmota. Hmmm.
  • #4 21691696
    Help: 451
    Rate: 921
    I imagine it’s safe to assume that most people will add their converted devices to a basic home network, where the device will receive an IP address in the same subnet as the management device.
    Of course, there will be exceptions — for example, if someone uses an IoT VLAN or another network setup that prevents the newly leased IP from being accessible from their management device.
  • Use DHCP leases or hostname to find device IPs
    #5 21691936
    insmod
    Help: 168
    Rate: 455
    I have router at 192.168.1.1 with 255.255.254.0 mask (and 255.255.255.0 for dhcp, so that devicers with static ip use 192.168.0.x addresses and dhcp devices use 192.168.1.x).
    No idea about the script, i've never had the problem with getting the ip of a newly flashed device. In openwrt, i just look at "Active DHCP Leases" table.
    And wouldn't it be easier to get the ip by hostname rather than by mac? Although then the problem is setting up the correct local domain (like esphome default is .local, while i use .lan).
  • Suggesting AP-mode reboot to report assigned IP
    #6 21692114
    max4elektroda
    Help: 49
    Rate: 189
    I like the idea of getting the new IP "served" instead of looking for it but I wonder how to do it. The only idea to get a probably correct one without scanning would be on a quick thought to
    get WiFi credentials from AP mode,
    connect (which means reboot) and somehow save the IP
    restart in AP mode to "report" the IP (using the fact that usually it will get the same IP on next boot in STA mode) .
    If we could do all steps without rebooting, it would be much easier.
    So there might be a simpler way, but trying the name might be easier, if your router registers the name.
  • WebApp scanner finds OBK devices by STATUS 5
    #7 21693934
    max4elektroda
    Help: 49
    Rate: 189
    Added a simple scanner for OBK devices to WebApp https://github.com/OpenBekenIOT/webapp/pull/225
    You can define the network and hosts to scan (and a timeout).
    It will try to open
    http://${ip}/cm?cmnd=STATUS%205
    which will work for OBK devices thanks to
    "Access-Control-Allow-Origin *" in OBK.
    General idea:
    If you add a new device, you load "WebApp" (possible even in AP mode) and then add WiFi credentials in GUI.
    After restarting device in STA mode, you can "scan" the network in the WebApp to find out the IP of the new device (and possilbe other OBK devices) in WebApp even if device was restarted and is no longer available in AP mode.
The discussion addresses methods to identify IP addresses assigned to OBK devices after WiFi pairing, given the lack of simultaneous AP and STA mode support in OBK firmware. A proposed solution involves using JavaScript on the pairing page to remember the device MAC address and scan local IP ranges by querying the OBK-specific endpoint (e.g., /cm?cmnd=STATUS 5) to detect devices on the network. The challenge lies in determining the correct IP range to scan, especially when the management device is connected via Ethernet or on different subnets. Common home network configurations typically use 192.168.x.x subnets with 255.255.255.0 masks, making scanning up to 255 IPs feasible in modern browsers. Alternative approaches include retrieving the device IP from DHCP leases on routers or resolving device hostnames if local DNS or mDNS (.local, .lan) is configured. A practical implementation was added to the OpenBekenIOT WebApp, allowing users to define network ranges and scan for OBK devices by sending HTTP requests to their status endpoint, leveraging CORS headers for browser access. This enables discovering device IPs post-reboot in STA mode after WiFi credentials are set via the WebApp, even if the device is no longer in AP mode.
