Netia Contract Termination Due to Non-Functional Landline Service
XWindowsMen 73971 19
Can I terminate a Netia fixed-term contract without penalty if incoming calls to my landline have not worked for over two weeks, even though outgoing calls still work?
Yes, if Netia is really failing to provide the service, that can be treated as non-performance of the contract, but you should first document it, file a complaint, and if needed escalate to UKE or the Consumer Federation [#7526056][#7454117] Netia’s own regulations say that in the event of a breakdown or improper performance, a consumer may demand a contractual penalty of 1/30 of the average value of the last 3 bills for each started 24 hours of failure, and the claim is made on the basis of a complaint [#7527904] If you terminate a fixed-term contract early, you may still have to return the benefit/discount you received, meaning the difference between the promotional price and the regular price for the period already used, not necessarily an arbitrary PLN 600 penalty [#7498560] The contractual penalty cannot be higher than the discount granted for the period of use [#7501266] So the practical advice from the thread is: check the contract/regulations, submit a written complaint, demand repair and compensation, and only then push for termination if the fault is not fixed [#7454117][#7527904]
  • #1 7453929
    XWindowsMen
    Agreement with Netia signed for 3 years. There are less than 24 months to the end of the contract. The internet works and everything is fine. However, for over 2 weeks no one has been able to call my landline number ("there is no such number"). Outgoing calls from this number are working. Can I terminate the contract with the operator on the grounds that he fails to fulfill his part of the contract without incurring ewe? costs etc!? Filing a complaint about the defect does not bring anything to the case ... they cannot / do not want to fix it. Of course, the bills are paid on time. Regards.
  • #2 7454117
  • #3 7497703
    sam_my
    I have a similar problem.
    I still have a year and a half to finish the contract with Netia, but a month ago I bought a flat and it turned out that Netia is not able to transfer its services to my new place of residence for nothing (using any technology).
    Now he informs me that in the above-mentioned situation, I will either pay for the net to the end of the contract, which I do not use because they deliver it where I am no longer available, or I have to pay them a penalty fee of PLN 600 for breaking the contract.
    Zenada, I spoke to the manager and nothing: /
    What to do ?
    sam_my
  • #4 7498014
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    I think they are doing better in Gabon. People! Read the contracts you sign or have signed. Do you think that idle forum discussions will solve the problem? Any contract must be able to be terminated. And under what conditions it is already included in the contract.
  • #5 7498560
  • #6 7498940
    terrade
    Level 36  
    Help: 427
    Rate: 8
    In both cases, it is probably about 3-year contracts, including the first year for free?
    You don't have one like it, but completely different. Complaints are absolutely groundless, you can even complain to UKE and lose everywhere. There are the same rules in TP, breaking the contract is 100% your fault, so you have to return what you gained from the promotion, 600 PLN is very little.
    @yon, you are probably wrong, because the alleged discounts (offered by TP, Netia, etc.) are overwhelming (for me, 150 / month) and then there would be a lot more.
    @XWindowsMen: your complaint is justified (they fixed it much faster for me), but from what I read in the regulations (similar to TP) they have a terrible 30 days to consider the complaint, and you are also entitled to 1/30 of the subscription for each day ( so I did not even try to get back those pennies). Call them and press for repair.
  • #7 7501266
  • #8 7525953
    zygusia
    I have a nice question.
    I have a telephone line in tp (only for the line only)
    but I have internet in netia (place 49 PLN)
    I signed the contract for 3 years, it has already passed a bit, but to be honest I don't need this net. I would like to resign from it, the contract is still ongoing and will last a long time. How much will I pay for terminating the internet contract with Netia?
    Apparently it is the sum of PLN 2500, but I found somewhere on the website with PLN 630
    Can anyone tell me how much this punishment will take me?
  • #9 7526056
    radio-service
    Help: 229
    Rate: 212
    After all, this is a classic failure to comply with the concluded contract due to NETIA's fault !!! The contract is valid for both parties !!! If one of the parties does not comply with the contract, this is a sufficient reason to terminate it. In case of doubt, you are left with the Consumer Federation.
    Regards
  • #10 7527858
    szaleniec
    Help: 476
    Rate: 199
    yonnie wrote:
    If the regulations or the price change, you can terminate the contract without any consequences.
    Not true. At least not always.
    After the amendment to the Telecommunications Law of April 24, 2009, the matter is not as obvious as it seems to be.
  • #11 7527904
    radio-service
    Help: 229
    Rate: 212
    Quote from Netia's regulations:
    CHAPTER 7
    LIABILITY FOR NON-PERFORMANCE OR INADEQUATE PERFORMANCE OF THE CONTRACT § 16
    Responsibilities
    1. The Operator shall be liable for non-performance or improper performance of the Agreement only to the extent specified in the Regulations, unless otherwise provided for in the Agreement and the Act.
    2. The Operator shall not be liable for non-performance or improper performance of the provisions of the Agreement in the event of the Subscriber's failure to meet the obligations arising from the Regulations, the Price List, the Agreement or special conditions, to the extent to which the Subscriber's failure to perform such an obligation had an impact on the non-performance or improper performance of the Agreement by the Operator. .
    3. The Operator shall not be liable for non-adaptation or defects of devices other than the Subscriber Devices and shall not repair, adjust or adapt them.
    4. In the event of a Breakdown lasting longer than 24 hours, a Subscriber who is not a Consumer may demand a contractual penalty in the amount of 1/30 of the average value of the last 3 Bills for each started 24 hours of Failure, with the proviso that in the event of a break in the provision of the telephone service, the penalty is payable periodically the contract is charged in the event of a Breakdown lasting more than 12 hours).
    5. In the event of a Breakdown, a break in the provision of the Service caused by a malfunction of the network of another operator, Planned Works, the Consumer may demand the payment of a contractual penalty in the amount of 1/30 of the average value of the last 3 Bills for each started 24 hours of Failure (except that in the event of a breakdown in the provision of a periodically paid telephone service, the contract penalty is charged in the event of a Breakdown, a break in the provision of the Service caused by a malfunction of another operator's network or Planned Works lasting longer than 12 hours).
    6. In the event of a delay in the commencement of the provision of the Service, the Subscriber may demand, for each day of delay, the payment of a contractual penalty in the amount of 1/30 of the fixed subscription fee due for the Service, the provision of which has not been commenced by the Operator on time.
    7. The period for which the Subscriber is entitled to a contractual penalty does not include the time when the Failure could not be removed for reasons attributable to the Subscriber.
    8. The Subscriber is obliged to provide authorized Representatives of the Operator with access to the Subscriber Equipment located in the Premises for the purpose of inspection, measurement and failure removal.
    9. The contractual penalty is paid on the basis of a complaint submitted by the Subscriber in the manner specified in Chapter 6 of the Regulations.
    If nothing else can be done, you have to kill Netia with your own weapon :)
    Regards
  • #12 7527913
  • #13 7528750
    szaleniec
    Help: 476
    Rate: 199
    Not every change in the regulations gives the right to terminate the contract without consequences. Don't be misleading.
  • #14 7529017
  • #15 7529131
    szaleniec
    Help: 476
    Rate: 199
    yonnie wrote:
    Each amendment to the regulations allows the contract to be terminated if the subscriber does not accept the changes.
    Not everyone.
    The above-mentioned amendment introduced a limitation - the contract cannot be terminated without negative consequences if the change
    results directly from the change in the law, including the removal of prohibited contractual provisions
  • #16 7529140
    Tremolo
    Help: 1016
    Rate: 497
    I have a Netia connection on the TPSA line. One day my line came off; automatically no signal on the phone and no Netia internet connection. I called telecommunications, they said that they would repair the damaged lines after the weekend; we simultaneously called the netia line reporting a line fault; found out that the line would be repaired on Monday.
    Unfortunately, the damaged line could not be repaired in the telecommunications box. After a month, we reported to TPSA again, the lady on the line was terrified that it had not been repaired yet; similar in netia. After the line was repaired in 3 months, the internet came back (replacement of the wires in the staircase with the consent of the cooperative for operations in the newly renovated building). A few days later, compensation came from TPSA, for a large sum: about half a year the phone was free. On the other hand, netia calculated the compensation of PLN 7. It concluded that the damage to the line had been repaired after the first installers visit. And two weeks later, the lady called to see if we would terminate the contract with Netia due to the inability to continue sending the service.
  • #17 7532872
  • #18 7534588
    szaleniec
    Help: 476
    Rate: 199
    yonnie wrote:
    But I wrote about changes that the subscriber can accept or reject.
    Not true. You wrote
    yonnie wrote:
    Any change to the regulations makes it possible to terminate the contract in the event that the subscriber does not accept the changes.
  • #19 7534703
  • #20 7534836
    mat_ed
    Help: 924
    Rate: 268
    The topic was founded on December 29, 2009. that is over 2 weeks ago. From that moment on, the author did not deign to write anything, so I close the topic.
    However, you, my madman, if you want to argue, I suggest you move to PW. On the other hand, I am asking the author for relevant information via PW, and I will resume the topic if necessary.
The discussion revolves around the termination of a contract with Netia due to non-functional landline service. A user reports that their landline has been unreachable for over two weeks, despite timely bill payments and functional internet service. Responses suggest that terminating the contract may be possible if Netia fails to fulfill its obligations, but the user must provide evidence of this failure. Various users share similar experiences, highlighting issues with service transfer and penalties for early termination. It is noted that changes in regulations or pricing can allow for contract termination without penalties. Users are advised to file complaints and consider appealing to the Office of Electronic Communications (UKE) if issues persist.
