Returning Netiaspot Router after Contract Ends: Required Components & Accessories
marcin6660 64539 13
What exactly do I need to return with a Netiaspot router after my Netia contract ends?
You should return the Netia Spot router together with all delivered elements: the splitter with built-in microfilter, telephone cable, Ethernet cable, charger/power supply, one microfilter, and the instruction manual; the CD is not on Netia’s official set list [#13582105][#13761748][#13756432] The contract text says the subscriber must return the device with all delivered elements in non-deteriorated condition within 14 working days [#13761748] One user reported sending back only the router and power adapter with no later charge, but that was only an anecdote and does not change the official requirement [#13810288]
  • #1 13577319
    marcin6660
    Rate: 152
    Tomorrow I will send the Netiaspot router back to Netia after the end of the contract. What do I need to pack apart from Router, power supply, CD ??? There were some more cables, but after so many months I don't know which ones they are and is it required to return the mains cables or only the device with a power supply?
  • #2 13577398
    kamil2993
    Help: 45
    Rate: 76
    Probably a splitter with a micro filter and a cable for the telephone socket.
    • Returning Netiaspot Router after Contract Ends: Required Components & Accessories splitter_i_ufiltr.png (21.39 KB) You must be logged in to download this attachment.
  • #3 13578839
    marcin6660
    Rate: 152
    I forgot about the filter. But I am interested if someone has already returned this device to Netia and are the cables important or is it enough: a router, power supply, filter and CD ???
  • #4 13582105
    podpowiedz_netia
    Rate: 12
    Ladies and gentlemen,
    Together with the device, you will receive a brochure with the detailed elements of the set.
    Installation package content:
    - Netia Spot Wi-Fi ROUTER,
    - Splitter - signal splitter with built-in microfilter,
    - Telephone cable,
    - Ethernet cable,
    - Charger,
    - Microfilter 1 pc,
    - and instruction :-)
    Best regards,
    Netia
  • #5 13586003
    marcin6660
    Rate: 152
    I have an SMS from Netia in which it clearly says that the DEVICE should be returned within 14 days. Nothing to write about accessories. I sent the Router, Power Adapter, CD and Manuals.
    It is strange that after 2 years and having several different routers, I look for used cables and filters worth a few zlotys, which I have several and I do not even know which one is from Netia.
  • #6 13594823
    podpowiedz_netia
    Rate: 12
    marcin6660, "device" in this case means the entire assembly.
    Best regards,
    Netia
  • #7 13756432
    Tulkas_42
    Rate: 16
    marcin6660 wrote:
    I have an SMS from Netia in which it clearly says that the DEVICE should be returned within 14 days. Nothing writes about accessories. I sent Router, power supply, CD .............
    You can choose not to return the CD, because it is not included in the set. See also the list quoted above. At least I didn't get such a CD in the set. Maybe they were attached before. Greetings.
  • #8 13757641
    adasek1
    Rate: 11
    Do you need to attach any special information on who is returning the device? Maybe they will find it themselves after the serial number? Anyone have any experience in this matter?
  • #9 13761748
    Tulkas_42
    Rate: 16
    Returns the signer of the contract. The device has a serial number, MAC address, (Setup) PIN, individual NETIASPOT-xxxxxx network name and a WPA key for the Wi-Fi network.
    A quote from the regulations to the contract regarding the device:
    "In the event of termination of the contract by the Subscriber or the Operator, the Subscriber is obliged to return the device with all delivered elements in a non-deteriorated condition, except for wear resulting from proper use, to the following address: Netia SA - Magazyn Centralny arvato Polska Kopytów 44D building 4; 05 --870 Błonie near Warsaw, within 14 working days from the date of termination of the Agreement. "
  • #10 13763048
    ajvens
    Rate: 16
    If I borrow PLN 100 from you, you will be interested in what banknotes will I give you back? or will I give back?
    After that, you write that if it's worth a few zlotys, it will not matter if you give the company your own ... because for you it's a few zlotys in a company with a million customers, let's say every 50th will do that, there are already hundreds of thousands ...
  • #11 13763804
    Tulkas_42
    Rate: 16
    Gentlemen, there is nothing to do with a problem ...
    We sign the contract by agreeing to the attached terms and conditions. In the contract, the operator indicated what to return, how and where. It also set an amount to be paid in the event of destruction or damage to the equipment due to the user's fault. So what is this discussion about? For example, TPSA left the Neostrady modem from the previous contract for me, and installed DSL instead (after changing the contract to DSL with fixed IP). After switching to Netia, I had to return the DSL modem to Orange (in the meantime, TPSA turned orange :) . I gave away the modem and power supply. The cables and filters were of no interest to the technician receiving the equipment. As you can see from the contract, Netia is more greedy for trinkets added to the device and there is no help for it. Well, except for not signing the contract ... best regards
  • #12 13810288
    marcin6660
    Rate: 152
    I will say this. I sent back NetiaSpot with a power supply and nothing more in May and silence (I have confirmation of sending the package and on the net from the post that it was received in Netia). So I guess they skipped these cables because they would probably ask for it and it's been almost 3 months already ??? My finances are fine on my account (Netia Online).
  • #13 13810435
    kamil2993
    Help: 45
    Rate: 76
    :shii:
    You do not have anything on your head, only the Netia Spot router that you have been pulling it from May? oO
  • #14 13814618
    marcin6660
    Rate: 152
    Solved - closing.
The discussion revolves around the return process of the Netiaspot router to Netia after the contract expiration. Users inquire about the necessary components to return, confirming that the router, power supply, and microfilter are essential. Additional components such as the telephone cable and Ethernet cable are also mentioned as part of the original installation package. Some users express uncertainty about the importance of returning all accessories, with experiences indicating that returning just the router and power supply may suffice. The return must be completed within 14 days, and users are advised to include identifying information such as the serial number and MAC address.
