[Solved] I have a Netia spot router and it disconnects my internet connection
kacper1255 8124 5
  • #1 16899724
    kacper1255
    Level 4  
    Rate: 31
    My router has connection problems sometimes. sometimes it turns off for 5 minutes and connects. then it's okay
    however, a few times a day he can do it. I have no idea what the Internet from Netia Spot is with, I do not know what it depends on and how to fix it. I also have no clue where this defect came from. I am asking for helpful advice
  • #2 16899765
    Dra98
    Help: 1321
    Rate: 1076
    You can report the problem to Netia.
    The network is Wifi or LAN, loses the connection or does the white LED on the router go off and the red LED lights up?
  • #3 16899802
    VooVoo
    Help: 215
    Rate: 266
    What about when your computer is started in Safe Mode with Networking?
  • #4 16900003
    seb235
    Help: 98
    Rate: 74
    kacper1255 wrote:
    my router sometimes has problems with connection, there is internet and sometimes it turns off for 5 minutes and connects back and then it does it a few times a day. I have no idea what is the Internet with Netia Spot, I have what it depends on and how to fix it no I have no idea where this fault came from
    The first thing - what color is the LED on the netia spot when you are watching the Internet? If red, I recommend checking your installation to make sure everything is connected as it should be, if it doesn't work, I recommend contacting the hotline. It will likely end up with a port profile change and the problem will be at the expense of speed.
  • #5 16900057
    IC_Current
    Help: 1499
    Rate: 2522
    I would start by checking all the filters on the phones. Telephone noise can effectively break synchronization on the DSL line.
  • #6 17080861
    kacper1255
    Level 4  
    Rate: 31
    Itself
    The future solution to the router will be overwhelmed and it would have to work. Network failure
