Bosch Logixx8 Washing Machine Error F18: Troubleshooting Rinsing and Water Left Issues
diorek82 76649 4
  • #1 7518565
    diorek82
    Rate: 23
    Hello, I searched the forum and found nothing :cry: and I need help because I do not know what the F18 error on the display means :cry: :cry: water was left in the washing machine and the washing machine stopped working on rinsing on the super short program Please reply quickly Regards Ewa[/b]
  • #3 7518895
    diorek82
    Rate: 23
    Hello, thank you for your answer but I don't know and I don't know what could be wrong?? the washing machine stopped spinning so it seemed to me that that's why there was water ... Only tomorrow I will call the service because I need to find a guarantee because the washing machine is probably not a year old :( everything was ok before and the filter was also checked :(
    Added after 23 [minutes]:
    on google I read that the F18 error is the code of the damaged module and that the selector has probably failed ... could someone explain to me easier what's going on??? Regards
    TomekCarlos
    Help: 89
    Rate: 585
    F 18 - water draining time exceeded. Maybe it's worth draining the water and see if there is any object in the filter, insert your finger and turn the impeller of the pump - it's possible that something fell in.
  • #5 7566145
    diorek82
    Rate: 23
    Hello, we did so and it turned out that the hair pin was in the filter :) otherwise it was clean. Thanks for the replies :)
