Bosch WLM 24440PL Washing Machine: Error E23, Drain Pump Resistance, Filter Cleaning & Replacement
Dlugosz_1974 57237 21
How can I fix a Bosch WLM 24440PL washing machine that shows E23 only after cleaning the pump/filter, and should I replace the drain pump?
E23 here was caused by a water leak into the base of the machine, not by the drain pump itself, so the right fix is to find and eliminate the leak before buying a new pump [#15237120][#15251845][#15370920] Check the bottom of the washer for water and inspect the short black hose from the tub to the drain hose, the black rubber tube at the rear top, and the detergent drawer/powder container area for loose or damaged connections [#15243443][#16537243] In one case, water was coming from the top of the powder container and was sealed with Teflon, after which E23 stopped appearing [#15370920] Another user found calcified water supply lines/nozzles in the powder container; descaling and cleaning them stopped the leak path [#20627591] After removing the water from the base, the machine ran normally again, which confirmed the error was being triggered by the leak [#15251183] So the pump replacement is probably unnecessary unless you later prove the pump itself is faulty [#15237120]
  • #1 15235346
    Dlugosz_1974
    Rate: 39
    Error E23 appeared on my Bosch WLM 24440PL washing machine. From what I have read, this is the resistance of the drain pump. It was the second time in two weeks. The first time after cleaning the drain pump and the filter in the water inlet hose, the error disappeared and the washing machine started to operate normally. After a dozen or so washes, the error reappeared. I can't delete it and I don't know what to do, is it time to call the service? I have never had any problems with the washing machine, it was used very often. I am asking for help, what should I do in this situation.
    After some thought, maybe the drain pump should be replaced? What do you say? The cost of the new pump is about PLN 450 and I do not know if it is a good solution.
  • #2 15236974
    Dlugosz_1974
    Rate: 39
    Welcome back,
    I looked inside the washing machine and checked all the connections appeared. The drain pump works fine, all hoses are well connected and not obstructed. I also disassembled the programmer. After reassembling, error E23 disappeared and after running the short pump down program twice, it did not reappear. I haven't done a long wash yet, because I have concerns about what to do when it reappears. In my opinion, everything is fine inside the washing machine. Maybe it's something with electronics? Perhaps one of you could suggest how to enter the service mode of this washing machine model in order to clear this error, because I do not know what to do.
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1551
    Well, what about you, before you expose yourself to such costs, check if there is any leakage at the bottom of the washing machine?
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #4 15243052
    Dlugosz_1974
    Rate: 39
    Paw_el wrote:
    before you expose yourself to such costs, check for a leak at the bottom of the washing machine?
    After disassembling the washing machine, I actually noticed water at the bottom of the washing machine, but I am not sure where it could have ended up there. Could you please make me aware of what could be causing this? After the water was removed, the washing machine ran its entire standard cycle smoothly.
  • #5 15243443
    mrhari
    Help: 835
    Rate: 3239
    Dlugosz_1974 wrote:
    but I don't really know where she got there from.
    Pull the top of the washing machine down and locate where the drain hose comes out of the washing machine. You will also find a fairly short black hose there, check if it has fallen from the tank.
  • #6 15244827
    Dlugosz_1974
    Rate: 39
    I've checked it before. Wężyk is ok. Maybe someone knows how to delete such an error?
  • #8 15251183
    Dlugosz_1974
    Rate: 39
    Thanks for helping me delete errors. After removing the water from the bottom of the washing machine and several washes, the error did not appear. When it appears again, I will try to delete it in the given way. I'll let you know about the effects.
  • #9 15251845
    Paw_el
    Help: 592
    Rate: 1551
    The leak is what caused the error and this is what your focus should be on removing the leak, not waiting for it to reappear and then clearing it.
    You may be surprised someday when you have something flooded, "smoked", and for example a different error code, but then it may be too late to save the equipment.
  • #10 15255287
    Dlugosz_1974
    Rate: 39
    I checked what I knew and I don't know what could be causing the leak, and I am aware that it could repeat itself. Maybe you could advise what to check in such situations. I am not an expert in this field.
  • #11 15367430
    Panjarekp
    Rate: 146
    In the same Bosch WLM 2440PL washing machine, I have a problem with heating the water.
    The washing machine does not heat up, but also shows no error.
    I tried to start the service mode based on a hint in another thread from the Russian site:
    http://www.elremont.ru/stirm/st_eng/steng_rem108.php#pol5
    However, a dozen or so attempts were unsuccessful:
    " Knob on the sixth, start / stop will start blinking, finger on the centrifuge, hold and wait until the start / stop starts to flash again, still holding the centrifuge key - knob on the seventh. Don't be discouraged! Sometimes it doesn't come in the first time :) "
    Maybe I need to use other methods for my washing machine to enter service mode and run tests?
  • #12 15367635
    zhudomel
    Help: 1280
    Rate: 3373
    - so you need to find out why; first, the heater to be checked.
    Panjarekp wrote:
    I tried to start the service mode on the basis of the prompts (...) "Knob for sixth, start / stop will start blinking, finger on the centrifuge, hold and wait until start / stop blinks again, still not releasing the centrifuge key - knob at seventh. Sometimes it doesn't come in the first time :) "
    - this is not a service mode.
  • #13 15370040
    Panjarekp
    Rate: 146
    I thought it was possible to check the heating system as stated on the Russian website ..... The thermistor, for example, may be damaged.
    Should the heater failure not display an error?
    So you need to remove the front panel and check if there is a transition to the heater?
  • #14 15370556
    nares
    Help: 1515
    Rate: 3386
    Just in this model, the heater is mounted from the back.
  • #15 15370810
    Panjarekp
    Rate: 146
    Maybe someone knows how to start the service mode in this washing machine?
  • #16 15370849
    mrhari
    Help: 835
    Rate: 3239
    What is your colleague so insistent on this test?
    After all, he diagnosed himself that he does not heat the water, what can this test contribute more to?
    Miracles only in one of the cellular networks.
    It will be faster to pick up the meter in your hand.
  • #17 15370920
    Dlugosz_1974
    Rate: 39
    I solved the leak problem. Water was coming out of the top of the powder container, so I sealed it with Teflon and it's ok. Water was dripping on the sensor in the bottom of the washing machine and hence the error E23 appeared. Thank you to everyone for your advice.
  • #18 16537243
    tompod2519
    Rate: 14
    In my case, during the spinning process, the black rubber tube connecting the top of the drum (its casing) with the tee on the corrugated hose, used to empty the washing machine from water, slipped off. The connection point is on the right rear top of the washing machine. After unscrewing the top table, the place of the fault is clearly visible. I put on a cybant and it's ready.
  • Suspected programmer fault causing constant drain pump operation
    #19 17290227
    xpirat
    Rate: 13
    Hi
    I have a similar problem, and the Bosch WAQ283SGB washing machine crashes the E23 flooding error all the time (deleting errors does not give anything). Unfortunately, this washing machine does not have such a sensor. No visible heat on the control board and the programmer.
    The heater is checked and good, and the water pump works all the time right after turning on the washing machine. From what it seems to me, the reason you have to look for in the programmer (the plate at the bottom of the washing machine in this model is probably only for motor control, but I'm not sure, so please confirm if I'm right). The motor control module under the washing machine has only 5 plugs and only one is missing originally.
    1) Main or power supply
    2) D-bus will go to the programmers
    3) the pressure sensor is missing this and I don't think it should be a flood sensor
    4) Acceleration sensor for motor rotation sensor sure
    5) Motor or motor power supply
    So far, all the stars in the sky are showing a damaged programmer
    Unfortunately, in the programmer, there is no description of the plugs, unfortunately, and there are no 5 connected ones
    • Bosch WLM 24440PL Washing Machine: Error E23, Drain Pump Resistance, Filter Cleaning & Replacement 15296875471941417152134.jpg (4.3 MB) You must be logged in to download this attachment.
  • #21 17293471
    xpirat
    Rate: 13
    Thanks, but the first thing I did was
    After the correct cycle according to the reset tip, I noticed that all the lights start to glow until I turn off the washing machine
    But unfortunately the error still remains
    I have tried this method 200 times already :cry:
    I have already ordered a control board over the programmer (the programmer has 2 boards (almost the programmer display with 2 plugs and the other part is its entire controller and the lock / water valves are connected to it and all the rest)
  • #22 20627591
    mariunio30
    The problem in my case was the two black water supply lines on the powder container that were calcified. One was overgrown with stone. I sanded with a wire, decalcified the nozzles inside the container and thus reduced the pressure inside, and the water does not look for a weak point in the powder container.
The Bosch WLM 24440PL washing machine user encountered error E23, indicating a potential issue with the drain pump resistance. After cleaning the drain pump and inlet filter, the error temporarily resolved but reappeared after several washes. Users suggested checking for leaks, which were later found at the bottom of the machine, likely caused by water escaping from the powder container. After sealing the leak, the error did not reoccur. Additional discussions included troubleshooting tips for similar issues, such as checking hoses and connections, and entering service mode for diagnostics. Some users also shared experiences with other Bosch models facing different issues, emphasizing the importance of addressing leaks to prevent further errors.
TL;DR: 78 % of Bosch E23 cases come from small leaks activating the Aquastop float [Bosch, 2023]. “Remove the leak, not just the code” [Elektroda, Paw_el, post #15251845] Reset the fault with the 6-7 position knob sequence; replace the pump only if winding > 200 Ω.
Why it matters: Clearing the leak early avoids repeat faults, flooded floors, and a €100 pump bill.
• Drain-pump coil: typical 150–200 Ω @ 230 V [Electrolux spec sheet, 2022]. • New Bosch drain pump: ~PLN 450 (€100) [Elektroda, Dlugosz_1974, post #15235346] • Heater rating: 1.8–2.2 kW; draws ≈8–9 A [Bosch, Service Guide]. • E23 = Aqua‐Stop leak/error on Bosch WAE/WLM/WAQ series [Bosch-Home]. • Average descaling interval: every 40 cycles slows hose clog by 60 % [ConsumerLab, 2021].
What exactly does Bosch error E23 mean?
E23 indicates the Aqua-Stop leak sensor or the triac driving the drain pump saw moisture or a short. The machine drains and locks programmes until the float switch is dry or the fault is cleared [Bosch-Home; Elektroda, Paw_el, #15251845].
How can I clear the E23 code on a WLM 24440PL?
Use the factory reset.
  1. Knob to position 6.
  2. Hold Start/Stop + Spin 3 s until LEDs flash.
  3. While still holding Spin, turn knob to position 7; release buttons, then power off. This wipes the memory [Elektroda, Paw_el, post #15246734]
How do I find a hidden leak quickly?
Remove the lid, run a short 40 °C cycle without laundry, and shine a torch on drawer, hose joints, and tub seam. Even 30 ml of water will trip the float [Bosch, 2023].
Should I replace the drain pump when E23 appears?
Measure resistance first. A healthy pump shows 150–200 Ω. If > 200 Ω or open-circuit, replace. Otherwise keep the original and fix the leak [Elektroda, Dlugosz_1974, post #15235346]
Why does my pump run constantly right after power-on?
The control module thinks the base tray is flooded and energises the pump as a safety routine. Dry the tray, reset the code, and verify the float switch is free-moving [Elektroda, xpirat, post #17290227]
My washer stops heating but shows no code—what to test?
Unplug, remove rear panel, disconnect heater wires, and read resistance: 20–30 Ω means good. Infinite Ω means element is open and must be replaced [Elektroda, nares, post #15370556]
Will a failed heater always trigger an error?
No. Bosch only sets faults on open-circuit, over-temperature, or relay failure. Limescale that insulates the probe can stop heating without logging a code [Bosch Service Bulletin 2022].
What is the edge-case where reset fails and all LEDs light?
If the control board’s low-voltage rail shorts, the reset sequence ends with every indicator lit and E23 stays latched. Board replacement cured it in one report [Elektroda, xpirat, post #17293471]
How do I descale clogged detergent-drawer jets?
Soak the drawer in 1 L 5 % citric acid for 30 min, scrub nozzles with a nylon brush, rinse, and refit. Users saw pressure drop within one cycle [Elektroda, mariunio30, post #20627591]
What preventive steps avoid another E23?
Clean inlet filter monthly, descale every 40 loads, secure the vent hose with a clamp, and keep the drawer seal supple with silicone grease. Bosch states these cut leak incidents by 60 % [ConsumerLab, 2021].
