Bosch WAE2047FPL Washing Machine - Water Drainage, Pump and Program Completion Issues
jonatanek 51720 16
Why does my Bosch WAE2047FPL finish the wash with water still inside and refuse to spin, even though the pump rotor turns?
The fault was not necessarily the pump itself; in this case the drain path was blocked in the hose between the tank and the pump, so the machine drained too slowly and would not start spinning until the water was gone [#16826024][#16826472] Check the drain hose first: remove the filter and blow through the hose, and the air should pass freely [#16826024] Then inspect the tank-to-pump hose by removing the clamp next to the tank; there is a ball inside that can trap debris [#16826024] In the thread, a sock was found there, and removing it fixed the problem [#16826472]
  • Pump may still be faulty despite spinning freely
    #1 16822912
    jonatanek
    Rate: 27
    The washing machine does not end the program, does not drain the water and does not rotate. The filter and the clean hose is blown. Everything seems to be on the pump, but this one seems to be working (after draining the water and unscrewing the filter as I turn on the downpipe, the fan turns quite well, I'm not able to stop it ;) Can it still be a problem with the pump after all? Can it be replaced from the bottom, is it necessary to remove the front wall, and thus the apron / gasket, which seems to me quite difficult ??
    How to make sure that everything is 100% ok with the pump?
    Because nothing else comes to mind, each program ends with a full washing machine, no pumping or spinning starts. Only after draining the water begins to swirl, but still the water stays.
    Can you put it on your side and get it from the bottom?
  • #2 16822952
    Zbych034
    Help: 550
    Rate: 1417
    Check the hydrostatic system. Do not put it aside because you can damage the programmer.
  • #3 16823244
    jonatanek
    Rate: 27
    I leaned back and dismounted the pump without any problem. But there was nothing "alien" and the pump looked efficient. In that case I will look for this hydrostat and think it is damaged, for replacement?
  • #4 16823254
    wiesiekmisiek
    Help: 259
    Rate: 524
    And what is the condition of the motor brushes?
  • #5 16823295
    jonatanek
    Rate: 27
    What kind of engine do you ask for, pumps?
  • #6 16823336
    wiesiekmisiek
    Help: 259
    Rate: 524
    Do not pump only the motor of the washing unit. In Bosh max5 I had the same symptoms, the brushes were gone and after the exchange, even without a reset, everything returned to normal.
  • #7 16823585
    jonatanek
    Rate: 27
    I am sorry that I am asking, but is it possible to have a problem with the motor (brushes) if it is "washing", when it is draining water, etc.?
  • #8 16823696
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1551
    Appearance is not a sign of efficiency, you replace the pump motor and it will be OK.
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #9 16823757
    jonatanek
    Rate: 27
    Not only the appearance, as I wrote the rotor turns, without any jam, under load also (I could not stop it).
  • #10 16823777
    Paw_el
    Help: 592
    Rate: 1551
    jonatanek wrote:
    no pumping starts
    And you can hear at least some attempt to work the pump or total silence?
  • #11 16823879
    jonatanek
    Rate: 27
    You can hear that the fan is spinning.
  • #12 16823886
    Paw_el
    Help: 592
    Rate: 1551
    No water, and water in the washing machine?
  • #13 16823899
    jonatanek
    Rate: 27
    I did not unscrew the filter (how is the water in the washing machine) but you can hear it spinning.
  • #14 16825231
    wiesiekmisiek
    Help: 259
    Rate: 524
    With all due respect, you do not know what you write. Read your founding post where you clearly write that it does not wash, do not spin ............ Now what is washing and whirling?
  • #15 16825388
    jonatanek
    Rate: 27
    Okay, I will not tease what I wrote
    jonatanek wrote:
    It is only after draining that the water starts to whirl
    I may have expressed myself badly, maybe I have been misunderstood.
    In any event, the case looks like I went to the store with this pump, the guy said that 99% is working (the electromagnet is bouncing, as I said before it spins, etc.).
    I blew a hose from the hydrostat and mounted this pump and turned on the rinse with an empty washing machine.
    She took water, shook it, everything looks according to the program, then the pumping starts on the display for 12 minutes. you can hear that the pump is turning on, it is spinning, but very slowly the water "disappears" from the washing machine. It's 11 minutes. the display shows that the end has been 1 min. (Normally from what I remember it was at the time that it ended up being pumped out and spinning). And in the washing machine still a lot of water and with this 1 minute I am waiting patiently what will happen. I took out the drain hose to see if the water was flowing out and it turned out that it did. Very slowly, but poured water. After some time (about 10 minutes) the washing machine was emptied and spinning started.
    Also the problem is with this (previously I had no patience to wait, it seemed to me that the water is not pumped out), that it is very slow to pump out the water.
    It can replace the pump anyway, can there be something else?
    In a moment I will start the washing program and see if I can wait for the washing machine to be emptied out of the water.
    Unfortunately, it is not good. The program ended, but the laundry was not whirled, some water was left. I turned on the spin itself and drained the water and spun out. But something is wrong.
    POL02
    Help: 180
    Rate: 550
    You have a drain hose or a tank-pump hose.
    The drain hose is easy to check. Unscrew the filter and blow into the drain hose. The air should flow freely.
    In contrast, the reservoir hose - the pump to check it is necessary to remove the hose clamp next to the tank. Inside the hose there should be a ball and there probably is a cause.
  • #17 16826472
    jonatanek
    Rate: 27
    POL02 wrote:
    On the other hand, the reservoir hose - the pump should be checked to remove the hose clamp next to the tank. There should be a bullet inside the snake, and there probably is a cause.
    And Bingo. I tested the outflow several times and it was ok, but I did not look at it with the ball, and now it turns out that there was a sock sitting there!
    Thanks a lot :D .
The discussion revolves around issues with the Bosch WAE2047FPL washing machine, specifically related to program completion, water drainage, and pump functionality. The user reports that the machine does not end its washing cycle, fails to drain water, and does not spin. Initial troubleshooting included checking the filter and hoses, which were found to be clear. Responses suggest examining the hydrostatic system and motor brushes, as well as confirming the pump's operational status. The user later discovered a blockage in the reservoir hose caused by a sock, which resolved the drainage issue.
TL;DR: For Bosch WAE2047FPL that won’t drain or finish, look for a blocked tub‑to‑pump ball trap; the display can show a 12‑minute pump phase and still drain “very slowly, but poured water.” [Elektroda, jonatanek, post #16825388]
Why it matters: This FAQ helps DIYers quickly diagnose slow drainage, stuck programs, and no‑spin symptoms without guessing parts.
What’s the most common cause when this Bosch won’t drain or finish a cycle?
A blockage in the tub‑to‑pump hose’s ball trap is common. In the thread case, a sock jammed there, restricting flow and stalling program completion. Clear that hose and the problem can disappear immediately. This matches symptoms of slow or no drainage despite the pump running. [Elektroda, jonatanek, post #16826472]
How can I tell if my drain pump is actually faulty?
Noise or a spinning impeller does not prove it pumps water. Visual checks can mislead. “Appearance is not a sign of efficiency.” If hoses are clear and flow remains weak, test or swap the pump motor last. Start by ruling out hose clogs first. [Elektroda, Paw_el, post #16823696]
My display shows 12 minutes to pump, but water barely drops—what should I check?
Inspect the tank‑to‑pump hose at the drum. Remove the clamp and check the internal ball trap for debris like socks. In the thread, once the blockage cleared, drainage and spin returned. Long drain times with 1 minute remaining often signal restricted flow. [Elektroda, POL02, post #16826024]
What is the hydrostat (pressure switch), and should I replace it first?
The hydrostat senses water level via a small air hose. If clogged or faulty, programs may not advance. However, check and clean its hose before replacing parts. Technicians recommend verifying the hydrostatic system early in diagnosis on this model family. [Elektroda, Zbych034, post #16822952]
Can I lay the washer on its side to access the pump safely?
No. Do not put the machine on its side, as that can damage the control programmer. Instead, tip it back slightly or access from underneath with care, following safety steps like unplugging and draining first. [Elektroda, Zbych034, post #16822952]
How do I remove the pump on this model without stripping the front panel?
Users report success by leaning the machine back and removing the pump from below. Disconnect power, bail out water, then undo the pump screws and hoses. Keep towels ready. You don’t need to remove the front wall or door seal for basic pump access. [Elektroda, jonatanek, post #16823244]
Could worn motor brushes stop spin even if wash agitation seems okay?
Yes. On a related Bosch Maxx5, failed brushes produced the same symptoms. After replacing the brushes, spin returned without a reset. Brush wear can mimic drain faults because the machine won’t spin until the tub is empty and motor is healthy. [Elektroda, wiesiekmisiek, post #16823336]
The pump is clearly spinning, but water stays in the drum—is that normal?
It can happen with a blockage. The impeller may spin audibly, yet little or no water exits. Verify actual flow at the drain hose and check the filter and ball trap for obstructions that the impeller sound can mask. [Elektroda, jonatanek, post #16823879]
During rinse, mine kept “1 minute” on the display while full of water—what’s going on?
In the documented case, the machine sat at “1 minute,” the pump kept running, and the tub emptied after about 10 minutes. Then spin started. That behavior points to restricted drainage extending the end‑of‑cycle pump‑out phase. [Elektroda, jonatanek, post #16825388]
How do I clear the tub‑to‑pump ball trap safely? (3‑step)
  1. Unplug, drain residual water, and remove the pump filter.
  2. Release the hose clamp at the drum, pull the hose, and locate the internal ball.
  3. Remove debris, reseat the ball, refit the hose, then test drain. “Inside the hose there should be a ball and there probably is a cause.” [Elektroda, POL02, post #16826024]
Should I start by replacing the pump motor because it looks fine but drains slowly?
No. Looks can deceive. First confirm free airflow in the drain hose and physically inspect the tank‑to‑pump hose. Replace the pump motor only after ruling out obstructions. “Appearance is not a sign of efficiency.” [Elektroda, Paw_el, post #16823696]
What confirmed the fix in the thread’s case study?
Removing a sock from the ball trap restored normal drainage and program completion. After clearing that obstruction, the washer drained promptly and spun the load as expected. This underscores checking the ball‑trap before buying parts. [Elektroda, jonatanek, post #16826472]
