Bosch Logixx 6 Washing Machine – Encounter with Error A02 and E18, Water Collecting in Dispenser
len-in 23790 12
What should I check on a Bosch Logixx 6 washing machine when it stops near the end of the cycle, shows A02/E18, and water collects in the dispenser?
Check the pressure/vacuum path first, because one reply says to “clear the vacuum” and the machine should return to normal [#17579304] For error A02, other replies point to a faulty door lock or a damaged switching path in the control module [#17632951][#17634168] If the door lock has already been replaced, then the module is the next suspect [#17641351]
  • #1 13932433
    len-in
    Hello!
    During washing, the washing time stops about 30 minutes before the end and cannot finish, every few minutes it returns to 31 minutes before the end. The light in the lower right corner of the foaming bowl display is on.
    Error A02 appeared once. I switched the program to rinse and it finished washing. Then I drained the water at the filter and cleaned it *there was some soapy limescale and a 10 groszy coin. There is water in the rinse aid container. During the next wash, the foaming bowl is displayed again and water collects in the dispenser, even though the drawer has been cleaned. Can you help somehow?
    Regards.
    When I was finishing as stated above, the second wash appeared error E18 .
  • #2 17566609
    radkeskaw
    Rate: 15
    I have the same error and I am spreading my hands. I replaced the LNK and the 100Ω resistor. Now the washing machine comes to life, but it does not spin or spin the drum. The pump discharges water. Error A02 pops up on the display and I can't find an answer anywhere what this error is. Thanks in advance for any advice on what is causing the crash.
  • #3 17576337
    wiesiekmisiek
    Help: 259
    Rate: 524
    Have you checked the engine?
  • #4 17577986
    radkeskaw
    Rate: 15
    I didn't check because I don't know which pins to plug in with the current, and I don't want to burn it. There are 7 pins. I watched the brushes and they are over 4 cm. length, and the motor itself as well as the inside of the washing machine look like brand new from the factory.
  • #5 17577994
    abuhamza
    Home appliances specialist
    Help: 383
    Rate: 1032
    The two extreme ones are the tacho, the next two are the rotor, and the last three are the stator. But I wouldn't connect it directly to the network, only through, for example, an autotransformer.
  • #6 17578276
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Enter the E-number of the device.
  • #7 17579304
    abuhamza
    Help: 383
    Rate: 1032
    Clear the vacuum and it should be back to normal.
  • #8 17583840
  • #9 17585655
    wiesiekmisiek
    Help: 259
    Rate: 524
    radkeskaw wrote:
    I didn't check because I don't know which pins to plug in with the current and I don't want to burn it.
    There are 7 pins.
    I watched the brushes and they are over 4 cm long and the motor itself and the inside of the washing machine look like a new one from the factory.
    When I wrote checking the engine, I meant measurements with a multimeter of resistance and possibly leakage - not connecting it to the power supply on the table. Did you make these measurements? Just because it looks brand new doesn't mean it's efficient.
  • #10 17632231
    orajc
    Rate: 25
    As I read, I stick to the topic.
    I have a Bosch logixx6 washing machine and at first it had a problem with the lock, I replaced it with a new one because it was actually damaged, but the problem did not disappear, error A03 continued to pop up. I checked everything and found no reason. The washing machine worked when I disconnected the ground from the motor. Then I cleaned the engine from carbon dust and everything works fine.
    After several tries, the washing machine shows error A02. The heater has the correct resistance and there is no breakdown to ground. When I move the heater, it has a leakage within the limits 2MΩ . My question is is it normal that the heater has a slight puncture when I move it and can there be a small voltage on the motor housing during operation - about 40V? I will add that I have 3 used heaters and would all 3 be damaged? Is the problem more in the engine?
    What did the colleague mean when he wrote clean the vacuum? Should I clean the hydrostatic funnel?
    I will add that in the washing machine you can set a program, run a cycle, e.g. rinsing or spinning and the washing machine will start without a problem, but at the end it will not open the door, only error A 02 pops up.
    Today I started the washing cycle for 15 minutes. and 40 ° C and did the washing without any problems. I am asking for any advice where to look for the cause because Bosch washing machines are really a mystery. How error A03 caused dust in the engine, what is the cause error A02 ?
  • #11 17632951
    Piotr2608
    Help: 851
    Rate: 4487
    orajc wrote:
    then what is the cause of error A02 ?
    Possibly damaged door lock - check.
    ZimTech Piotr Zimny
  • #12 17634168
    wiesiekmisiek
    Help: 259
    Rate: 524
    As above or the damage is on the switching path in the module.
  • #13 17641351
    orajc
    Rate: 25
    The lock was replaced with a new one, it certainly won't be that.
    The damage is probably in the module, but where.
    Thanks to the moderators for correcting the spelling errors, I always have trouble with this.
The Bosch Logixx 6 washing machine is experiencing issues with error codes A02 and E18, along with water collecting in the dispenser. Users have reported similar problems, including the machine stopping 30 minutes before the cycle ends and the foaming bowl light being illuminated. Troubleshooting steps discussed include checking the motor, cleaning the filter, and examining the door lock and hydrostat chamber. Some users suggest measuring the motor's resistance and checking for leaks in the heater. The presence of foreign objects, such as coins, and the condition of the motor and components are also highlighted as potential causes of the errors.
