Peugeot 307 1.6 2005 – “PLIP BATTERY SPENT” message, what does it mean?
glosny83 77399 8
  • #1 7533524
    glosny83
    Help: 91
    Rate: 487
    What this message means:
    PLIP BATTERY SPENT
    yaaro
    Help: 195
    Rate: 1083
    and sometimes not plip
    in my opinion it is the battery in the remote control
  • #3 7534113
    glosny83
    Help: 91
    Rate: 487
    As I wrote above, the message appears on the display.
    yaaro
    Help: 195
    Rate: 1083
    I would like to add that the battery replacement time should not exceed 30 seconds
  • #6 7539067
    glosny83
    Help: 91
    Rate: 487
    Gentlemen, the case is this is the 2nd key, I start the car with it and everything is ok, namely in that key I replaced the battery and it is the same replacement time exceeded 30s it took about 1h but the remote control normally closes and opens it somehow? I will add that it is a pocket knife.
    sms
    Rate: 9
    1.Put the key into the ignition switch
    2.Push the loock button on the key, turn on the ignition, wait ten seconds
    3.Turn off the ignition, release the button
    5.Wait for 5 seconds
    Ready
    Checked today on a Peugeot 307
    vauer6
    Help: 16
    Rate: 147
    As the central locking works, you do not need to synchronize anything further.
    Could be the entire remote to be replaced.
  • #9 12674957
    Tristyan
    Rate: 12
    I have a Citroen C2 2006 1.4 benz and today this message "SPENT PILP BATTERY" appeared to me, once I replaced the battery, I synchronized it and it was OK. however, with this battery replacement, I synchronized the closing, but the message remained
    any hint?
    I will just add that the key "pocket knife" in which the remote control is located does not work and the spare is attached to it and it tries to synchronize it, because when it tries to synchronize the "pocket knife", there is no answer, while on the spare key, closing and folding the mirrors everything works only this message is still shown
The message "PLIP BATTERY SPENT" indicates that the battery in the remote control key for the Peugeot 307 has depleted. Users suggest that replacing the battery in the key is necessary, and the replacement process should ideally take no longer than 30 seconds. If the central locking system is functioning, further synchronization may not be required. However, if issues persist after battery replacement, it may indicate a need for a new remote. A related issue was noted with a Citroen C2, where the message remained even after battery replacement and synchronization, suggesting potential problems with the remote itself.
