Panasonic SA-HT990: Substitute 5010L12S-PHD Fan Model & Where to Purchase Options
kozabeusz 14241 14
How can I replace the noisy 5010L12S-PHD fan in a Panasonic SA-HT990, and where can I buy one?
The safest fix is to remove the fan, clean and lubricate the bearings/axle, because Panasonic controls the current through the fan and a non-original replacement may not work [#12303436] If you want to buy a replacement, the original fan was said to be available through an authorized Panasonic service, and one user reported buying a new original at north.pl [#7592590] [#12693935] Other sources mentioned were soltronic.pl and TME, but availability and price vary, and north.pl was noted as expensive [#8634241] [#12295268] [#12291045] Before buying a substitute, check the fan voltage and dimensions; one reply suggested these fans are often similar to PC fans, but the size here was reported as 45 mm with three wires and a diagonal mounting-hole spacing of 55 mm [#7592590] [#12295063] [#12295203]
  • #1 7592559
    kozabeusz
    I am not an electronics engineer. The fan gets vibration and buzzs mercilessly. Which model can I exchange it for, or where will I get the same: 5010L12S-PHD?
    Paul
  • #2 7592590
    varrior87
    Help: 17
    Rate: 37
    You will get the same at an authorized Panasonic service. It is best to check how much voltage you have on it, it often happens that these are fans used in computers. You will know the voltage and dimensions, then you can go to the electronics store or to the computer parts store.
  • #3 8634241
    organo
    Rate: 11
    The same can be purchased in the store www.soltronic.pl only I do not know if there is sense, because the second I will be exchanging. I think I will put something on the computer now, because these years last and buzz.
  • #4 8634912
    egon42
    Level 37  
    Help: 358
    Rate: 825
    Cannot undress, clean and lubricate it?
  • #5 12289533
    artelektron
    Help: 14
    Rate: 49
    Gentlemen, do you know where you can buy such a fan? I've searched almost everything and it's gone.
  • #6 12291045
    egon42
    Level 37  
    Help: 358
    Rate: 825
    Check www.north.pl, but it will probably be expensive.
  • #7 12293447
    artelektron
    Help: 14
    Rate: 49
    Yes, I saw 78 PLN plus shipping, but they wrote that they do not have :)
  • #8 12294305
    egon42
    Level 37  
    Help: 358
    Rate: 825
    If it is buzzing, remove and repair it or take it to a computer technician, have it repaired, it should also work. I get a fan to repair it once a week and I fix it as it works and I don't replace it, because it's a cost, and I have a profit for myself.
  • #9 12294933
  • #10 12295063
    artelektron
    Help: 14
    Rate: 49
    The diameter of the 45 mm fan with three wires.
  • #11 12295154
  • #12 12295203
    artelektron
    Help: 14
    Rate: 49
    Diagonally between the holes for screwing it is 55 mm, so it will not enter the housing :( I connected other fans for a moment and after a while the same error F61, if not for this protect :( that would be ok
  • #13 12295268
  • #14 12303436
    radiogaga
    Service technician RTV
    Help: 398
    Rate: 436
    Panasonic controls the current flowing through the fan. Unoriginal will not work. It is necessary to pry the plastic cotter pin off the fan axis, clean the bearings and axle, then lubricate. Every Vietnamese or Chinese is consumed in this way.
  • #15 12693935
    artelektron
    Help: 14
    Rate: 49
    I bought a new original at north.pl and the cinema works.
✨ The discussion revolves around finding a substitute for the Panasonic SA-HT990 fan model 5010L12S-PHD, which is experiencing vibration and noise issues. Users suggest checking authorized Panasonic services for replacements and recommend verifying the fan's voltage and dimensions. Some participants mention alternative purchasing options, including online stores like soltronic.pl and north.pl, although availability may be limited. Suggestions for repairing the fan by cleaning and lubricating it are also provided, as well as considerations for using fans from other devices if compatible. The fan's specifications, such as a diameter of 45 mm and three wires, are discussed to aid in finding a suitable replacement.
