Panasonic SA-HT990 Fan Replacement: 5010L12S-PHD Model & Alternatives - Solve Vibration Issues
jackyjoy123 3288 7
  • #1 19579740
    jackyjoy123
    I am not an electronics engineer. The fan gets vibration and buzzs mercilessly. Which model can I exchange it for, or where will I get the same: 5010L12S-PHD?
    thanks
    jackyjoy
  • #2 19590993
    radiogaga
    Service technician RTV
    Help: 398
    Rate: 436
    Just disassemble, clean the axle and coat with a light grease.
  • #3 19591082
    zadam64
    Help: 552
    Rate: 735
    For a while it will help like "Etopyrin for the headache". The plain bearing is worn out here. You can disassemble the fan and reduce the axial play by adding graphite washers.
    It's best to replace. Such a "light lubricant" application doesn't help. Maybe for a month
  • #5 19592417
    radiogaga
    Help: 398
    Rate: 436
    Everyone has their own experience. My many years of evidence indicate that proper repair gives a good effect. For my part, I think that you have not seen the condition of the bearing. Replacing it with a new one is of course the surest solution.
  • #6 19599531
    gorki73
    Help: 548
    Rate: 1068
    Hello, what is this fan for? because it could be replaced with a bigger one, which will be more efficient. Take a picture of what voltage and power this fan is. Maybe we'll choose something. regards
  • #7 19599835
    zadam64
    Help: 552
    Rate: 735
    Find a larger one with the same parameters. Hard start of the original fan causes an error in it.
  • #8 19600440
    398216 Usunięty
    Help: 3925
    Rate: 9265
    zadam64 wrote:
    Find a bigger one with the same parameters
    It is going to be hard...
✨ The discussion revolves around the replacement of the Panasonic SA-HT990 fan, specifically the 5010L12S-PHD model, which is causing vibration and noise issues. Users suggest various solutions, including disassembling the fan for cleaning and lubrication, though some caution that this is only a temporary fix. Recommendations include replacing the fan entirely, with one user providing a link to an alternative part (L6FAHAKH0001) available on Amazon. Others suggest considering a larger fan with the same specifications for improved efficiency. The consensus leans towards replacement as the most reliable solution to the vibration problem.
