Accelerating Gas to Petrol Switch: Audi A4, Reducer Pressure, ECU Errors, VAG, Autoadaptation
witux 65947 16
Why does my LPG system switch to petrol when I accelerate hard, and should I adjust the reducer, clear ECU errors, or run autoadaptation?
The most likely cause is that LPG pressure drops under load because the gas is too cold for the reducer to evaporate enough fuel, or because the gas filters are clogged; the thread does not point to ECU error clearing as the real cause [#7595850][#7614056][#7614963] Do not tighten the reducer screw or do random self-adaptation without a real need [#7595850] Replace the liquid and vapor phase filters, since they should be changed about every 15,000 km and clogged filters can make the controller think gas is missing and switch to petrol [#7614056][#7614963] If the problem only appears in cold weather, wait for warmer conditions or improve the system’s capacity, for example with a larger or second reducer [#7595850] Insulating the reducer and fluid lines can also help the system reach temperature faster and avoid switching back to petrol [#7605322]
  • #1 7595579
    witux
    Help: 390
    Rate: 252
    I'm not smart in this area but I have a problem with the gas installation.
    The temperature outside is what it is but when I accelerate quite rapidly from gas it switches to petrol (exactly the control unit beeps as there is no gas).
    At the beginning, when I set up a new installation, when it switched, the mechanic tightened the screw on the reducer, increasing its pressure. For a year it was fine and now the cylinder is 3/4 gas, and here it switches to petrol when I accelerate.
    1. Is it caused by erasing ECU errors with VAG? Because recently I deleted inspections in the car and errors by the way.
    2. Can I tighten the screw in the reducer? So how much turnover?
    3. Should I buy an interface for the gas installation, take a picture and put it here (I have the program)?
    4. Is it good to carry out Autoadaptation from time to time?
    Except this everything is fine. I suspect that if the temperature of the fluid was 70 ~ ~ 90 degrees, there would be no problem.
    Data :
    Audi A4 engine 2.8 V6 AAH 174 PS year 1995
    Sequential installation
    ESGI computer 2
    VALTEC 3 OHM injectors
    reducer ZAVOLI Zeta/S
    ESGI switchboard
    Added after 31 [minutes]:
    Is it possible that I filled up with the wrong gas?
    manio123
    Help: 163
    Rate: 269
    everything is fine, only the gas is very cold (it's cold in winter) and in these natural circumstances the reducer is not able to evaporate the required amount of lpg, the pressure drops and switches to petrol. Foot off the gas and just until spring. Do not turn the reducer. Do not perform self-adaptation without a real need. However, if you cannot wait until spring, either install a second reducer or replace it with a larger one.
    :D
    It is also always worth replacing the liquid and vapor phase filters. :idea:
  • #3 7597047
    witux
    Help: 390
    Rate: 252
    Thank you for your reply. I will not interfere because I do not know.
  • #4 7602483
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2091
    Witek, if it's any consolation, I have the same in my Nissan ;)
    I asked the mechanic and he didn't tell me to do anything but wait for global warming :D
  • #5 7602695
    manio123
    Help: 163
    Rate: 269
    but I recommended replacing it with a real reducer, which has the declared power in the conditions of the Russian high, and not only in the sunny climate of Palermo :D . A strong reducer also means less crap in the reducer or injectors. It's always better to be too big than even a little too small. Oh, and a hoof :!: not frogging :cry:
  • #6 7603969
    agniesia110
    hello, zawola evaporators have a factory defect, you need to unscrew them and remove the copper springs on which the muck settles
  • #7 7604221
    witux
    Help: 390
    Rate: 252
    But this reducer is about 2 years old. So exchange? I called the specialist who put it on me and he said - "fill up gas somewhere else"
  • #8 7604328
    przem27
    Level 30  
    Help: 131
    Rate: 496
    And has your friend changed the gas filters at all during these 2 years?
  • #9 7605241
    witux
    Help: 390
    Rate: 252
    He didn't say anything because nothing happened ;)
  • #10 7605312
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2091
    So you didn't replace the air, oil and A/C filters either because nothing happened? :D
    every 15,000 I am replacing this filter so I think you should do that ;)
  • #11 7605322
    Zdunek 25
    Help: 10
    Rate: 52
    I had the same thing. I insulated the reducer with mineral wool and wrapped it with foil. And I put foam pipe lagging on the fluid lines.
    1. In the morning it reaches temperature faster and switches to LPG
    2. Even when parked for about 1 hour, it starts immediately on LPG and maintains the temperature
    3. When accelerating, it does not switch to petrol
    Renault espace 20.16v Stag 300 installation
  • #12 7614056
    przem27
    Level 30  
    Help: 131
    Rate: 496
    witux wrote:
    Well, you have the answer, clogged filters cause a temporary pressure drop, which the controller considers as a lack of gas and switches to petrol. Replace filters will rather help.
  • #13 7614963
    manio123
    Help: 163
    Rate: 269
    the liquid phase and volatile phase filter should be replaced every 15 kkm, not when it is impossible to drive. Replace immediately and you will see for yourself how much dirt is in them. The volatile phase filter absorbs heavy fractions of hydrocarbons that like to contaminate injectors, after some time it loses its absorptivity and does not clean anything, or even the opposite. I recommend the volatile phase filter FL02 prod. Czaja
  • #14 7615802
    witux
    Help: 390
    Rate: 252
    tino2003, don't make fun of me :) . I replace everything on time. Well, with this gas I neglected it a bit.
    Today I went on a little tour. temp. I had 70 degrees of liquid. Everything was running as it should.
  • #15 7622014
    pinger666
    I had exactly the same thing, changed the filters and everything stopped :)
  • #16 7720058
    dany1977
    Hello, I also have an a6 c4 with lpg, I drove the greatest frosts without major problems and now similar symptoms :) . As for the filters, you are not alone Witux has not been replaced for almost 2 years. Regards
  • #17 7721731
    witux
    Help: 390
    Rate: 252
    I haven't done anything at the moment and the car runs like lightning :) Apparently, maybe some crap or really does not like low temperatures.
The discussion revolves around issues with a gas installation in an Audi A4, specifically related to the vehicle switching from gas to petrol during rapid acceleration. Users suggest that cold temperatures may be causing the reducer to fail in vaporizing sufficient LPG, leading to pressure drops and the switch to petrol. Recommendations include avoiding unnecessary adjustments to the reducer, replacing gas filters regularly, and considering a larger or additional reducer if problems persist. Some users share personal experiences with similar issues, emphasizing the importance of maintaining filters and the potential benefits of insulating the reducer to improve performance in cold conditions.
