Audi A3 '98 1.6 Gas System: Issues with Controller After Battery Change - Driver 504s/05 Solutions
jaguarete 9680 10
How can I stop an Audi A3’s Gas System 504S/05 controller from losing its gas settings after battery or voltage interruptions, and should I update its software or replace the controller?
The recurring loss of settings after a battery or voltage interruption is reported as a normal weakness of the 504 controller, so replacing it with a 704 is the practical fix rather than repeatedly recalibrating it [#13649687] Be cautious about uploading new firmware: an attempted update reportedly left another controller unusable and required replacing the installation [#14017553] For programming, an RS-232 connection was reported as more stable than USB, although USB can work with suitable hardware and contacts [#13646407][#13646487] The thread does not identify a confirmed matching firmware package for the 504S/05, so obtain the exact manufacturer-compatible software before attempting an update.
  • #1 10456925
    jaguarete
    Hello, I am new here, I apologize for any mistakes.
    So this is how I have Audi A3, year 98 1.6, it has gas sequencer system Gas System. Recently I changed the battery in the car and, oddly enough, the car stopped riding on gas, choked and choked. My gasper checked the gas settings and set up the patch and everything went back to normal. But after a week, the same problem occurred again, so the gazer again had to set a given correction and ok, but recently after the engine was turned off and a few things started firing, the problem continued to appear. I am driving to the gasifier so constantly because it does not give results in the long run. After talking to the gasifier, he said that it would be necessary to upload new software or replace the driver.
    And here's the question for you what to do with this, and where to get the matching software for a given driver
    driver is 504s / 05 I count on the advice ...
    Yours sincerely, new user
  • #2 10480855
    blazehare
    Rate: 60
    Maybe I will step on the subject, I also have a DT gas system and a problem with connecting to the computer.
    Exactly, I do not know what kind of computers I have in this installation.
    The only data at his disposal is:
    - MG-01E reducer
    - LOVATO EV00 gas solenoid valve
    - LOVATO 305 multivalve
    - LOVATO BC00 refueling valve
    - Irene tank
    - Other: Gas Tech 5 injections set
    How can you get to the driver in this installation and what program can I use?
  • #3 10483463
    jaguarete
    hello you have to fire some DT programs for somebody to hook up,
    look first here
    https://www.elektroda.pl/rtvforum/topic159609.html?sid=aadf88e6d271ebb99fc452097aca4c71
    or the same is there
    http://www.pliki.drypa.pl/entry-096aa8f9ff9dbf2ed5bfb37adf64edda.htm
    or normally Google does not bite Dt gas system chomikuj and there are also programs and I'm there the latest package with the program and drivers for Dt as something I can send you on enamel.
  • #4 10484806
    blazehare
    Rate: 60
    I connected the driver using GasTech 2.21.
    When connecting, the password prompt pops up.
    Sure, the gasper has set up such, underneath is I forgot the password, I click on it and pops up: generate the code, or somehow yes. What can I do with this code?
  • #5 10547322
    wolek
    As a cover, the former employee of the company from Lublin would say briefly. THIS IS SCRATCHING !!!!! How the driver does not work is not surprising! He has the right not to act. I will say more how it works correctly, you have an incredible luck! Well, this company for servicing drivers employs inexperienced students who did not have a soldering iron in their hands. as a result of such a "repair" the driver is irreparably damaged! in addition, the cheapest components that are not suitable for this type of construction are used to build the controller! I recommend buying a second driver or changing the installation to another one. This is the best and cheapest solution! I will say this life has only one thing and it is not worth risking for a few cents!
    Firma z lublina releases drivers under various names (technology, modena, verona, etc.) but regardless of the name they have one thing in common DO NOT WORK! . one company appears under several names. tehnology, lo "in" atofast, gaztech, techgaz, dtga'z, gazsystem! (I made delirium for mistakes on purpose)
  • #6 10548573
    blazehare
    Rate: 60
    Okay, let's just click, I've forgotten my password, I've generated a hint, I've staked a one-time password, my computer has been connected for 10 seconds and a blue screen, the system has been :(
    Could this be the fault that I have Windows 7 64bit?
    There is no one-time password generator for this DTGas ???
    Okay, I managed to get into the computer and switch everything.
    Thanks to everyone for help.
  • #7 13602724
    jacco92
    Friend @blazehare what cable did you use to connect to a given driver? I have gt704s and ni hu hu I can not connect, but I do not know if my cable is good because I have USB and I think I need a COM port?
  • #8 13646407
    kris-bora
    Friend jacco92 I also have a GT 407 before 504 so I tell you that by usb, the connection is not stable often hangs best is via RS 232 and the xp system
  • USB connection works reliably; inspect cable contacts and water ingress
    #9 13646487
    jacco92
    I was able to connect via a USB cable. I have a perfect connection, no interruptions, I traveled more than 100km with a connected computer. Buddy, you have to have a problem with another thing. I overcame this stupid DT gas system program and the car ;) like a ;) doll
    My system is win 8.1 and there are no problems ;) I think it's a matter of plugs, contacts, in the cable itself and the mkrochure on it. It interrupted me when water came in, but I also dealt with it ;)
  • COM connection stabilized programming; 504 controller replaced with 704
    #10 13649687
    kris-bora
    ok.mój usb cable fell, so I changed to com.Now the connection is stable.Cyt a program until nice programming driver files flawlessly.On this gas I made about 120 thousand of which my predecessor also with 100 thousand so despite the change of the blade and the wrong word kompa I will say the clock was 504, but I changed to 704 because 504 lost memory and settings after the voltage decay in the circuit but it's supposed to be normal for the 504 model.
  • #11 14017553
    jaguarete
    basically something happened to the driver after uploading the new version was quite dead and it was impossible to even the previous one I was forced to new installations now I have a stag and it's about :)
The discussion revolves around issues with the gas system in a 1998 Audi A3 1.6 after a battery change, specifically related to the controller (driver 504s/05). The user experiences repeated failures of the gas system, requiring frequent adjustments by a gas technician. Suggestions include uploading new software or replacing the driver. Other users share their experiences with similar gas systems, mentioning connection issues, the importance of using the correct cable (preferably RS 232), and the potential unreliability of certain drivers. Recommendations include seeking stable software and considering alternative installations if problems persist.
