Passat B6 2.0TDI 103kW 2006: Timing Belt Replacement Interval Confirmation
adi_wrc 95604 11
When should the timing belt be replaced on a 2006 Passat B6 2.0 TDI 103 kW?
For the 2006 2.0 TDI 103 kW, the timing belt replacement interval is 120,000 km; from the 2007 model it was extended to 150,000 km [#7723328] Some forum users still recommend not waiting that long and changing it earlier, around 60–90,000 km, because a belt failure can damage the engine [#7643652][#7646374][#7708826] When replacing it, it is worth doing the whole timing set with good-quality parts, including rollers, the water pump, and the belt itself [#7799208]
  • #1 7643602
    adi_wrc
    Rate: 8
    How much should the timing belt be replaced in the Passat B6 2.0TDI 103kW 2006 year of production. There is information in the service book that every 120,000 km. I am asking for professional information.
  • #2 7643652
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    Apparently every 90,000, but knowing what is going on today in the subject, I would not risk such runs.
  • #3 7646374
    borrysek
    Conditionally unlocked
    Rate: 14
    I would suggest 60-90 thousand, because waiting for 120 may end up repairing the engine by accident.
  • #4 7685723
    pawcio1988
    in the car mechanic training book they write (general mileage of all models and brands) 80,000km. I think it's worth sticking to it ...
  • #5 7708826
    Drapek_skate
    Rate: 21
    I mention timings after 60,000 km and all my friends also within these limits (55-70,000 km). This is not changed every day and it is better not to wait for the belt to break, etc. There are so-called "collision-free" engines (older 8V on mono-injection - mainly VAG and Opel) in which breaking the belt does not make any trouble, but most (if not all) now produced there are collisions - valves bend, etc. It is also better not to risk it because then it may be too late and often after such a crash it is not worth repairing the engine.
  • #6 7711484
    witekrad
    Rate: 9
    does anyone know what is the cost of replacing the 2.0 tdi timing belt on vw
  • #7 7723328
    Matze
    the timing belt is replaced with 2.0 TDI 103 kw for the 2006 model every 120 tkm and from the 2007 model every 150 tkm costs about PLN 2,000.
  • #8 7780878
    mortalbird
    Help: 11
    Rate: 131
    you can replace every 120tkm, but I do not recommend 60-80
    and as for the price in the service of 2000, and half of the mechanic
  • #9 7799208
    MiKev
    Rate: 8
    the manufacturer, giving 120kkm, did not give the upper limit of possibilities for sure. I do not see the point in replacing 60kkm, unless you have nothing to do with the money.
    it is important to replace with good company parts and every single element of the timing gear.
    I recommend rollers, SKF water pump, GATES belt
    check how they folded the front after replacement because the entire front belt will have to be knocked down, along with the lamps and bumper
  • #10 7803633
    mortalbird
    Help: 11
    Rate: 131
    a friend asked a question, so many answered, like MiKev writes well, but I have already seen a few cars that did not reach 120, like the first timing is the most powerful because the factory did it, but a year ago I did the 97 thousand belt, had and broke 1 owner and the breakdown, I was hard to advise in November, vektre was 52 thousand and also the fact was 9 years, I personally bought a {1200 PLN} golf II 1.6TD with a mileage of 160 thousand {supposedly} drove it who wanted {such a workshop} until 2005 had about 330,000, maybe the tower did not do the timing, it did not matter to me that you can see how it is in this case, all colleagues describing the posts more clearly are right, maybe I'm wrong
  • #11 7840857
    MiKev
    Rate: 8
    There are also such situations, sometimes you buy a new bulb in the store and it also does not work. I replaced the Audi only when it had 106KMil and it lasted until then, now I have a new fieste and the manufacturer says that the belt should be replaced at 100KMil and I do not see the point in replacing it after 50,000. Sometimes the new replacement belt is worse than the original.
  • #12 7857874
    basstec
    Help: 144
    Rate: 178
    http://vwszrot.pl/
    It's just like the 2.0 TDI, if you have a later model, you have nothing to worry about, but it's worth reading.
The discussion centers around the timing belt replacement interval for the 2006 Passat B6 2.0TDI 103kW. While the service book suggests a replacement every 120,000 km, several contributors recommend earlier intervals, citing 60,000 to 90,000 km as safer options to avoid potential engine damage from belt failure. The consensus emphasizes the importance of using high-quality parts during replacement, including SKF rollers and GATES belts. The cost for replacement is noted to be around PLN 2,000, with some suggesting that a lower price may be available through independent mechanics. Overall, caution is advised against adhering strictly to the manufacturer's recommendation due to the risk of belt failure.
