2.0TDI - How often should the timing belt be replaced in TDI?
man12124 185970 30
How often should the timing belt be replaced on a 2.0 TDI engine, in km and years?
For 2.0 TDI/CR engines the interval depends on the exact engine code, but the forum consensus is that the first replacement is often around 150,000 km or 5 years, and then every 90,000 km or 5 years thereafter; some users prefer a more cautious 60,000 km or 5 years, while others note manufacturer figures of 180,000–210,000 km or even 200,000 km [#20273095][#20275923][#20280883][#21385806][#21387321] If your car has an EA288 engine, remember there is also a second toothed belt for the oil pump in the oil bath and it should be replaced together with the main timing belt [#20276004] The safest answer is to check the service book or dealer data for your exact engine code, because the interval is not the same for all 2.0 TDI variants [#20272032][#21385812]
  • #1 20263194
    man12124
    Level 4  
    Rate: 13
    Every how many km/years. According to the manufacturer, 200,000, I understand that this is 1 replacement and then every 50, 60, 70, 80, 90, 100, 110, or 120,000?
  • #2 20263199
    Ireneo
    Help: 747
    Rate: 2472
    Also 200,000 km
  • #3 20272032
    piotrek gti_abf
    Help: 7
    Rate: 37
    Which TDI are we talking about, from 1999, 2010 or maybe 2016? As for the tdi CR, it`s 200,000. but only on highway mileage, and 150,000 in mixed driving, but no one talks about it. 90,000 or every 5 years and it will be fine.
  • #4 20273079
    man12124
    Level 4  
    Rate: 13
    from 2017 to CR 150,000 with mixed driving, are you sure it`s not too much? The mechanic recommended 60,000 or even more
  • #5 20273095
    piotrek gti_abf
    Help: 7
    Rate: 37
    150,000 at the first replacement, and every 90,000 or every 5 years thereafter, but do as you see fit.
  • #6 20275098
    man12124
    Level 4  
    Rate: 13
    there are no guidelines, e.g. in the user manual, the manufacturer recommends replacement after 1 replacement every few km or something like that?
  • #7 20275623
    danielzy
    Help: 167
    Rate: 319
    What kind of user manual, why should it be written there? The manufacturer stipulates that you should have your car serviced at an authorized VW service center, and they already know how often to replace the timing belt. As Piotrek Gti wrote, replace it every 90=100,000 and it will be fine.
  • #8 20275751
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    I recently built an engine in which the customer never had time to replace the timing belt, at 220k km the teeth on the belt broke, the repair cost was PLN 12,000.
  • #9 20275923
    Kantylena
    Help: 18
    Rate: 222
    For these engines, the manufacturer`s recommendation
    Timing: Belt, replaced after 180,000 km or 5 years
    If someone wants, they can do it every year, but these are the recommendations, just like oil every 15,000 km or every year
  • #10 20275953
    sigwa18
    Help: 1194
    Rate: 3359
    In my opinion, the first one is PLN 150,000 for 5 years, the second one is PLN 90,000 and 5 years and the next one is PLN 60,000 and 5 years. The number of kilometers is reduced due to the wear of the wheels that are not replaced. And so the sum of these 3 replacements is 300,000 km, or more than the average of the vehicle`s mileage before it ends up in the scrapyard (rust).
  • #11 20276004
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    To be precise, these engines (EA288) have two toothed belts, the second one drives the oil pump and works in the oil bath. When replacing the timing belt, remember to also replace it. More expensive timing kits contain the belt and cover with sealant and these are the ones you should buy
  • #12 20276669
    man12124
    Level 4  
    Rate: 13
    in EA188 was 1?
  • #13 20280883
    forest1600
    Help: 10
    Rate: 172
    Timing every 60 thousand. km or 5 years and that`s it.
  • #14 20281091
    man12124
    Level 4  
    Rate: 13
    so why do you write earlier that every 150,000-200
    or the manufacturer states 200?
  • #15 20281171
    forest1600
    Help: 10
    Rate: 172
    I don`t write like that... What about the fact that the manufacturer provides such an interval? If someone likes risk, go ahead. The same with oil changes, the manufacturer states every 30,000 km, I change it every 10,000 km.
  • Timing belt interval debated against manufacturer spec
    #16 20282620
    man12124
    Level 4  
    Rate: 13
    I understand, so I`m asking how often, because you can even do the timing belt every 30,000, but why?
    so I`m asking what 45,50,60,70,80,90,100,120? so 60,000 or 5 years, right? I heard they also say every 90
  • Manufacturer intervals suggest five-year timing belt replacement
    #17 20283166
    Kantylena
    Help: 18
    Rate: 222
    man12124, it`s best to check what the manufacturer provides, I provided the rest in my post.
    Do you have a service book for this car or not? there you have the exchange intervals...
    I haven`t seen any manufacturer recommend replacing the timing belt every 60,000 in a diesel engine, most of them do 30 thousand per year, so replacing the timing belt every 2 years?
    You can assume that you change the timing belt every 5 years and the oil every year and that`s it.
    You can sleep soundly.
  • #18 20284706
    man12124
    Level 4  
    Rate: 13
    Kantylena wrote:
    I haven`t seen any manufacturer recommend replacing the timing belt every 60,000 in a diesel engine, most of them do it 30 thousand per year, so replacing the timing belt every 2 years?
    probably every 90kkt
  • Warranty-driven service intervals extend timing belt life
    #19 20285555
    sigwa18
    Help: 1194
    Rate: 3359
    Manufacturers tend to extend the duration of service visits during the warranty period. Apparently, such an inspection costs money and the costs are covered by the guarantor. So they extend this time as much as possible. If even 2 or 3 cars need to be repaired under warranty for this reason, they are still ahead of the curve and a specific number of mechanic`s hours and spare parts/operating fluids are required. It is simply profitable for them and what impact it will have on the condition of the car after the warranty is not their problem. That`s why we have Loglife oils and filters (1 replacement instead of 2 or 3). The first timing belt is expected to last the entire warranty period. The next one is not their problem.
  • Timing belt interval shortened after warranty period
    #20 20285622
    elektryku5
    Help: 460
    Rate: 1055
    Therefore, sometimes it happened that with each subsequent replacement, the number of kilometers from replacement to replacement of the timing belt was shortened...
    Oils are a slightly different story, changing them every 30,000 or recommending not to change the oil in the gearbox is, from what I once heard, the result of "ecological" regulations...
  • Factory belts and old pulleys justify shorter intervals
    #21 20285780
    sigwa18
    Help: 1194
    Rate: 3359
    Shortening the intervals on the timing belt is justified by the fact that we change the belt but the wheels remain old. They wear out and destroy the belt faster. The first two belts come from the factory and you can`t necessarily buy them in the quality and control that these belts go through in the factory that assembles the engine. Another aspect is the time from the production of the belt to its installation/use.
  • #22 20285910
    Kantylena
    Help: 18
    Rate: 222
    sigwa18, so are you suggesting that, for example, the Contitech/Continental belt is much worse than the ori from the factory? Well, I don`t know, because this particular company, for example in tires, is number 1 in my opinion
    on the other hand, you don`t pour the same oil as in the factory, but aftermarket oil, how do you know how the engine will wear? What "quality" does he have?
  • Factory priorities favor emissions over durability
    #23 20285935
    sigwa18
    Help: 1194
    Rate: 3359
    Well, the client certainly does not test one strip from a batch of, for example, 1000 in his own laboratory. The power of negotiation is two different. If you want a belt with specific parameters, they will laugh at you. How the factory orders is a different conversation. Look at the batteries, they seem to be the same manufacturer and have the same capacity, but the stickers are different. However, those from the first installation are heavier and last much longer.
    Oil and lubrication systems in general have been a circus in recent years, and I dare say that combustion numbers and emission standards are much higher on the list of priorities than engine durability (of course, after the warranty, and even this varies). Such as 0W20 oil. Variable displacement oil pumps. Turning off the water pump etc etc. and general road testing of systems and solutions on customers. Software patches that fix one problem and create three new problems.
    Unfortunately, the customer looks at the car differently and the factory looks at it differently.
  • #24 20286558
    man12124
    Level 4  
    Rate: 13
    but for the first assembly, the factory does not produce VW parts, only some other company
    so you`re saying that you can`t buy the same part as for the first assembly and the original one at the dealership?
  • #25 20286662
    pp_pablo
    Help: 93
    Rate: 405
    My Skoda SuperB 2.0 tdi CR 170 HP from 2012 (CFGB engine) had a ContiTECH timing belt with an additional VW logo from new. I bought a new one at the dealership, also ContiTECH, and the VW logo was also painted on it. The car has been in the family since new, so I`m sure it hasn`t been replaced before.
  • Dealership parts may meet stricter quality standards
    #26 20287251
    danielzy
    Help: 167
    Rate: 319
    Belts or other parts available at the dealership - it is known that they are not produced by, for example, VW or Audi, but by other companies - subcontractors, e.g. Contitech or other companies, but these parts are subject to much more restrictive quality standards than the same part available in a wholesaler or automotive store (without VW logo, etc.) and therefore must be made even better - quality 1A.
  • Questioning whether branded parts justify 2.3× higher cost
    #27 20287264
    sigwa18
    Help: 1194
    Rate: 3359
    This is where classic quality management comes in. The client does not have a laboratory and if something goes wrong, the consequences are the loss of the client. It is difficult for the customer to prove that the supplier did something wrong. The factory is now a legal department, a laboratory, and tests. Threat of breaking off contact or contractual penalties.
    But is it worth 2.3 times as much, when sometimes it is the same production line and the part differs with a milled brand logo.
  • Timing belt still perfect at 200,000 km
    #28 21385806
    Droppss
    If anyone is wondering what the timing issue is on new 2.0 TDI engines (DTTC designation in my case, Seat Leon IV, 150 hp, vintage 2021), I can share my experience. A few days ago I replaced the timing gear at 200,000 km. The manufacturer recommends replacement after 210,000 km, but I preferred to blow the whistle. After this mileage, the timing gear was in perfect condition - the rollers were not worn and the belt had no cracks, only a little dirt. The mechanic couldn't believe that the timing gear hadn't been replaced before. Personally, I wouldn't wait longer than 200,000 km, but if someone is thinking of replacing it at 100,000 km, it doesn't make much sense in my opinion. I hope I have been able to help someone. I would like to add that the car was imported from Germany, mileage mostly highway.
  • #29 21385812
    vogelek1
    Help: 36
    Rate: 114
    Call an authorised service centre and they will tell you, only Volkswagen.
  • #30 21386236
    skleppoczesci
    The recommended timing change intervals for the 2.0TDI engine depend on the manufacturer and vehicle specification. In general, it is recommended to replace the timing gear every 180,000 km
The recommended timing belt replacement interval for 2.0 TDI engines varies depending on the engine generation, driving conditions, and manufacturer guidelines. Generally, the first replacement is advised around 150,000 to 200,000 km or 5 years, with subsequent replacements recommended every 90,000 km or every 5 years. For example, EA288 engines have two toothed belts (one for the oil pump in an oil bath) that should be replaced together. Mixed driving conditions may warrant earlier replacement, around 90,000 km, while highway mileage allows longer intervals up to 200,000 km. Some mechanics suggest more conservative intervals such as 60,000 km to reduce risk. Manufacturer recommendations often require servicing at authorized VW centers, where timing belt replacement intervals are specified in the service book. Quality of replacement belts is critical; OEM or dealership belts (e.g., ContiTech with VW logo) meet stricter standards than aftermarket parts. Timing belt failure can cause costly engine damage. Newer 2.0 TDI engines (e.g., DTTC in Seat Leon IV 2021) show good durability up to 200,000 km. Factors influencing belt wear include wheel wear, oil pump condition, and quality of parts. Some users report manufacturer intervals are extended during warranty periods, but post-warranty maintenance may require shorter intervals. Overall, a safe practice is to replace the timing belt every 90,000 to 100,000 km or every 5 years, adjusting for driving style and conditions.
TL;DR: VW’s 2.0 TDI (EA288/DTTC) timing belt is factory-rated for 180 000–210 000 km or 5 years; “replace at 90 000 km after the first change” [Elektroda, piotrek gti_abf, post #20273095] Ignoring it caused a PLN 12 000 repair when teeth sheared at 220 000 km [Elektroda, carrot, post #20275751]
Why it matters: A snapped belt can wreck valves and pistons, turning a €150 kit into a €3 000+ engine rebuild.
• Factory interval: 180 000–210 000 km or 5 years for EA288/DTTC engines [Elektroda, Kantylena, #20275923; VW ElsaWin 2021]. • After the first change: 90 000–100 000 km or 5 years [Elektroda, piotrek gti_abf, post #20273095] • EA288 has an extra wet belt for the oil pump—replace both together [Elektroda, carrot, post #20276004] • Typical full kit + labour: PLN 1 400–2 100 in Poland [InterCars PL price list 2024]. • Failure example: PLN 12 000 repair after belt tooth loss at 220 000 km [Elektroda, carrot, post #20275751]
What interval does VW specify for the 2015-2023 2.0 TDI CR (EA288/DTTC)?
VW service data lists 210 000 km or 5 years, whichever comes first [VW ElsaWin 2021; Elektroda, Droppss, #21385806].
How much does a complete timing-belt service cost?
Parts average PLN 800–1 200; labour 600–900 PLN, totalling about PLN 1 400–2 100 [InterCars PL price list 2024].
How do I inspect a belt before the due date?
  1. Remove the upper plastic cover.
  2. Check for cracks, missing teeth or frayed edges under strong light.
  3. Rotate crank 360° to view the full belt section. If any damage appears, replace immediately [Autodata 2024].
Why do mechanics advise shorter intervals than VW?
Manufacturers stretch intervals to cut warranty costs; wear on reused pulleys speeds later belt fatigue [Elektroda, sigwa18, post #20285555]
Should I change the water pump and rollers together?
Yes. Worn rollers or a leaking pump can shred a new belt early; kits include all components [Elektroda, carrot, post #20276004]
What about the wet oil-pump belt’s life?
VW lists the wet belt for replacement together with the dry belt—max 210 000 km or 5 years [VW ElsaWin 2021].
