VW Passat B5 1.9 TDI 1997 – which oil for 300,000+ km mileage?
pyrokar01 66738 7
  • #1 12548313
    pyrokar01
    Rate: 40
    I wonder what oil to pour into the passat that has 300,000 or more.
    Semi-synthetic or maybe mineral.
    I do not know what the doll before?
    there are a few such themes but with smaller runs.
  • #2 12548368
    LA72
    Help: 648
    Rate: 1658
    Is engine oil running out?
  • #3 12548410
    krocze
    Help: 24
    Rate: 149
    If the oil is not depleted, even a synthetic funnel, the engine will work longer, when he drinks a little bit of a semi-synthetic, when he drinks oil like a drunkard, the cheapest mineral funnel, such an engine will not be helped anymore, and it is a pity to refill expensive oil.
    In general, this engine is durable and the design is simple, so it will work even on a mineral one, but in winter for a good start it is better to have a lower density oil, that is, semi-synthetic.
    Even if you don't know what's wrong, don't be afraid to change the oil grade, because it won't hurt the engine, today oils do not damage the seals and are miscible, the rest are unconfirmed stereotypes. To be sure, you can do a rinse and then pour in better oil, if the engine is not using it.
  • #4 12551436
    ciuqu
    Help: 512
    Rate: 829
    People pour whatever, go and nothing happens, and when it happens, let someone else worry about it, and if you want to enjoy your pass for a long time, then the synthetic standard 505.00 or 506.00
    This and the herring oil will not hurt the engine ;) and the turbine is.
    By the way, there will be 500,000 there. or more, but don't worry about it.
  • #5 12551724
    pyrokar01
    Rate: 40
    I do not know if he is taking the oil because I have only two weeks of it. the dipstick is ok and if you press the pedal, it does not smoke like some.
  • #6 12551956
    ciuqu
    Help: 512
    Rate: 829
    Pour the synthetic 505.00, how much will you drink, you will learn during operation.
    Many VW users recommend MOTUL but apparently it's easy to find fakes.
    I poured into everything, it pours and I will pour it Mobil and so far it rides. My passat 2004 with a mileage of 400,000 and maybe 600,000 (this only knows the autohaus tour), I drank what was left of the 5l can + liter for replacement and there was always something left, so probably about 1.5l, after the head repair 0.5l for now
  • #7 12552135
    pyrokar01
    Rate: 40
    cool, that's what i'll do
    thank you very much for the advice
  • #8 12754203
    Thomasemi
    Rate: 48
    Hello everyone, let me step on this topic, I also have a dilemma, namely
    Passat B5 2l petrol - Oil change
    I am going to change the oil in the engine, now it has castrol gtx 15/40 poured in. When I was buying an oil filter, I asked about the oil, the guy told me that it is recommended full synthetic 5/30 I have driven 200 thousand I told him what I have now, he said that it does not bother me
The discussion revolves around the appropriate engine oil for a 1997 Volkswagen Passat B5 1.9 TDI with over 300,000 kilometers. Users suggest that if the engine is not consuming oil excessively, synthetic oil (specifically standards 505.00 or 506.00) is recommended for longevity. Semi-synthetic oil is also considered suitable, especially for winter conditions due to its lower viscosity. Some participants mention that mineral oil can be used, but it may not be ideal for high-mileage engines. Recommendations include brands like MOTUL and Mobil, with caution advised regarding potential counterfeit products. Overall, the consensus is that regular oil changes and using the right oil type can help maintain engine performance.
