Connecting the Cable to E27 Socket in OBI Lamp Holder: Cable Connection & Disassembly Guide
astral 49652 6
  • #1 7669771
    astral
    Rate: 36
    I am asking for advice on how to connect the cable to this lamp holder, which I recently bought from OBI. In ceramics it is very intuitive, but here I can't get my head on. In addition, removing the lower part is very difficult, the latches hold tight to the housing and you need to use two screwdrivers and apply quite a lot of force.
  • #2 7669861
    Mr.K
    Help: 71
    Rate: 380
    You press the wire into the holes.
  • #3 7669948
    Pittt
    Level 32  
    Help: 148
    Rate: 213
    You can help yourself with a flat screwdriver by pushing it into the oval holes and thereby folding out the clamping plates.
  • #4 7669995
    Elmont
    Help: 68
    Rate: 220
    What a problem, the lampholder has quick couplings. Press the insulated connector under the bottom contact
    the phase wire, e.g. after the switch, press in the same way into the side contact hole
    neutral wire / blue / and after the problem.
  • #5 7670195
    tragi
    Help: 19
    Rate: 51
    If it is a stranded wire, the ends should be whitened with tin.
  • #6 7670245
    Zapol
    Rate: 17
    Yes, colleagues, but the questioner must connect the L wire on the plate in the holder and the N wire on the thread.
  • #7 7670840
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4287
    All the necessary information has already been released. If the author of the topic still has a problem with connecting this holder, I suggest calling an electrician.
    I close the topic, regulations, point 8.1.
✨ The discussion revolves around connecting a cable to an E27 lamp holder purchased from OBI. Users provide various methods for connecting the wires, emphasizing the use of quick couplings and the importance of correctly identifying the phase (L) and neutral (N) wires. Suggestions include using a flat screwdriver to manipulate clamping plates for easier disassembly and ensuring stranded wires are tinned before connection. One user advises consulting an electrician if difficulties persist, indicating that all necessary information has been shared.
