Recognizing Connected Load in a 1968 Countryside House with 3-Phase
willy1986 49159 34
Can my existing 3-phase household connection in a 1968 countryside house handle a future 15 kW motor, and how do I check the available connection power?
No — with a 14 kW connection, your installation is probably too small for a 15 kW motor, especially if other household loads run at the same time, so you should first verify the contracted connection power and the pre-meter protection size with the utility. The forum advice is to check the contract with the power company or call the ZE hotline using your customer number, and to have an electrician inspect the installation on site [#7708370][#7708639] One reply states that to start a 15 kW motor you need to increase the connection power and the pre-meter protection to at least 32 A; otherwise the motor will not start even with star/delta starting [#7718614] Another post estimates the motor current at about 25 A in operation, around 35 A during star start, and roughly 150 A during delta start, while a more detailed calculation gives about 213.6 A starting current for a 15 kW motor [#7722213][#8471853] The utility may charge about PLN 130–150 per additional kW, and one reply notes that in G11 the monthly fixed fee does not increase, only the one-time increase fee is paid [#7718466][#7718614]
  • #1 7708315
    willy1986
    Rate: 21
    The building is from 68, it is a house in the countryside. The power connection is from the overhead line. There is no or I can not find the electrical installation project because perhaps it was not there. I have a 3-phase installation. 380V and I want to use a 15 kW motor in the future and will such an installation stand it?
  • #2 7708370
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    To determine the connection power of the building, please refer to the contract with the Power Plant. Theoretically, it can still be based on pre-meter security, but it is very often fatal.
  • #3 7708395
    willy1986
    Rate: 21
    I have to look for this contract, although I don't know if I will. There are 3 fuses L20, L20, L16A at the meter.
  • #4 7708639
    Łukasz-O
    Help: 654
    Rate: 4292
    I meant pre-meter protections.
    Call the ZE hotline, provide your customer number (from your bill) and they should provide this information to you.
    It would be advisable to invite an electrician to make a site visit and assess the actual condition of your installation.
  • #5 7718036
    willy1986
    Rate: 21
    ok, i have already checked i have 14 kW. so probably a little bit considering the parallel work of other appliances in the household. does anyone know what are the costs of increasing this power to some 20 kw?
    Please correct your spelling as the post is trash can. Point 8.2 of the regulations [retrofood]
  • #6 7718466
    retrofood
    Help: 1140
    Rate: 4800
    willy1986 wrote:
    ok, i have already checked, i have 14 kW. so probably a little bit considering the parallel work of other appliances in the household. does anyone know what are the costs of increasing this power to some 20 kw?
    14 kW is not enough. And for every additional kW, the power industry will ask for something around PLN 130-150 + a monthly increase in the fixed fee. I believe you have no need to increase your power.
    And as for a 15 kW motor, I do not know if the power industry will agree to connect it as part of the home tariff (because you will have to provide the reason for the increase in demand in the application). And here the fees will be higher.
  • #7 7718614
    Qnt
    willy1986, the retrofood moderator misleads you twice. First of all, the monthly fixed fee in the G11 tariff will not increase, you pay only once for increasing the power, secondly, you must change the connection power, and thus the size of the pre-meter protections, to at least 32 A, otherwise you will not be able to start a 15 kW engine even for star / delta switch.
  • #8 7718740
    retrofood
    Help: 1140
    Rate: 4800
    Qnt wrote:
    willy1986, the retrofood moderator misleads you twice. First of all, the monthly fixed fee in the G11 tariff will not increase, you pay only once for increasing the power, secondly, you must change the connection power, and thus the size of pre-meter protections, to at least 32 A, otherwise you will not be able to start a 15 kW engine even for star / delta switch.
    Well, in the debut, accuse the moderator of misleading ... and twice ... cymes. :D
    Ale ad rem: First alleged mistake: maybe you are right and maybe not. If even, then in the G11 tariff this fee is not great, so the error is small and only partial, because you have to pay for kilowatts anyway.
    Second alleged error: I don't understand at all. I, my fellow debutant, have not written anywhere that the connection power does not need to be changed. Only that not necessarily living. I know a farmer who bought a sawmill and started it up on a farm. And in a month he had an inspection from the Power Plant, which made him realize that such reception does not fall under the living needs, only service needs. They sealed him with 20A security and ordered him to make a new connection and a new power supply for the sawmill, but energy at a price for economic activity.
    So accusing me of misleading the questioner is, to put it mildly, untrue and, above all, inelegant. Anyway, you, my friend, mislead the questioner by writing:
    secondly, you need to change the connection power, and thus the size of the pre-meter protections, to at least 32 A, otherwise you will not be able to start the 15 kW motor even through a star / delta switch
    Well, the questioner does not have to do anything, he only has to pay. Suggesting him to do any work can be very dangerous.
  • #9 7718979
    Mariuszczs
    Level 19  
    Help: 6
    Rate: 114
    You must not boast that you want a 15 kW engine to turn on only, let's say, increase the connection power, for example to 20kW - as much as they offer without additional billing for reactive power. I do not remember exactly, but probably in the allocation to the house they allow to turn on the engine max 11kW and it must be started in gw / tr. The fuses are 32A, but probably the pre-meter ones, because if you put on the 32A pre-meter and then seal it behind the 25A meter, it's also not very interesting for this engine.
  • #10 7719236
    Arturo2005
    Help: 149
    Rate: 485
    A friend writes complete nonsense.
    Bakers work in ZE and they do not know why we increase the connection capacity?
    Later, they go around the houses and check that the motors have star-delta switches ;)
  • #11 7719252
    Łukasz-O
    Help: 654
    Rate: 4292
    jakubwaba wrote:
    I have not heard yet that ZE sealed the advance security; P
    The meter and the pre-meter protections are sealed.
    Yes, they do seal it sometimes. Sealed post-meter protection is treated as a limitation of current consumption. I have written about it many times.
  • #12 7719276
    Arturo2005
    Help: 149
    Rate: 485
    Łukasz-O wrote:
    jakubwaba wrote:
    I have not heard yet that ZE seals advance security measures; P
    The meter and pre-meter protections are sealed.
    He hears first too. Why then pay for the connection capacity if it is lower than the ordered one anyway?
  • #13 7719292
    artis666
    Help: 69
    Rate: 34
    And I will ask, from a different barrel: What the hell is this 15KW engine? What are you going to drive with it? Take into account that with this power, with your 1st mistake, something powered by a 15KW motor will turn you into a luncheon, so in total I would think what power is actually needed, sold this colossus, and bought the right engine, and spent the rest on safety switches with appropriate installation. Why ? Because this is not a joke, I am sorry, but if you have the same approach to the machine as to this forum, in a moment you will not have anything to press the next question on the keyboard.
  • #14 7719302
    retrofood
    Help: 1140
    Rate: 4800
    After all, it is not to be tinkered with, it is obvious.
  • #15 7719330
    artis666
    Help: 69
    Rate: 34
    I think that my colleague has already learned more than once that what seems obvious is not at all obvious, small toys turn into larger ones with age, so I would not let my hand cut off ...
    And then I asked what this engine was for, I did not suggest that someone would connect it and watch it spin, since such a giant must also drive something big, I am interested in what it is.
    And if it were to be smaller than I imagined, I have proposed an appropriate solution. What is still not clear in my speech?
  • #16 7719331
    Łukasz-O
    Help: 654
    Rate: 4292
    Arturo2005 wrote:
    I can also hear it first. Why then pay for the connection capacity if it is lower than the ordered one anyway?
    We do not understand each other, you pay and you have the power you ordered. They use it where the pre-meter protections are fusible and the user can insert a nail instead of an insert at any time.
    Very often in WR they write to install 35A inserts for 5kW (to have peace of mind and not to come), while the advance is given by the 25A esa.
    I have encountered such cases several times, especially in suburban areas.
  • #17 7719339
    Arturo2005
    Help: 149
    Rate: 485
    artis666 wrote:
    Take into account that with this power, with your 1st mistake, something powered by a 15KW motor will turn you into a luncheon, so in total I would consider what power is actually needed,
    And with, for example, 11 kW, is it not?
    artis666 wrote:
    so in total, I would consider what power is actually needed, sell this colossus, and buy a suitable engine,
    A colleague did not wonder that the author has already thought?
    But what's not a joke? What does this have to do with typing?
    Łukasz-O wrote:
    Arturo2005 wrote:
    I also hear it first. Why then pay for the connection capacity if it is lower than the ordered one anyway?
    And the fusible pre-meter protections are not sealed anymore?
  • #18 7719369
    Łukasz-O
    Help: 654
    Rate: 4292
    Of course they seal, but sometimes you have the option of replacing the cartridge, after what I have already written, it is always much oversized.
  • #19 7719397
    Arturo2005
    Help: 149
    Rate: 485
    It smells like an ordinary fluff here, but ok, we deviate from the topic and why write and then throw it into the trash.
  • #20 7719432
    artis666
    Help: 69
    Rate: 34
    And I thought about it, and I continue to support my request to describe a machine that is to be powered by a 15KW motor. If your colleague does not like it, please remain silent as this is not a question for a colleague.
    Think about it, if you still don't know, think about it in terms of health and safety.
  • #21 7719442
    Łukasz-O
    Help: 654
    Rate: 4292
    I don't like it either, but it's not for me to judge, I get Connection Requirements, I do the job and I'm going elsewhere. It's not my fault that some EVs have strange habits.
    Okay end, let's get to the topic.
  • #22 7720025
    Mariuszczs
    Level 19  
    Help: 6
    Rate: 114
    I do not understand my colleague what he is talking about, but if the author of the temet will turn on this engine even in the star (start), the light will probably be dimmed throughout the village during the start - just a complaint from a polite neighbor and they can accuse that a larger engine than can be installed. Or let him turn on this engine right away in the triangle - how many Amperes will it take when starting?
    15kW is not much :)
    In my case, 20A security for the house was sealed and 3x20A for the workshop were sealed - they even wanted to seal the box - and I am asking how to get to the fuse, if I want to cut off the electricity. It is more and more common for them to seal the first advance security.
  • #23 7722030
    willy1986
    Rate: 21
    Well, I am going to buy or build a compressor for a sand blaster. The assumed power with the performance that interests me is 11 - 15 kW. As for the earlier questions, why do I need such an engine. The second thing is that I have power supplied from the pole with cables with a diameter of about 4 mm, but they are aluminum cables. As for meter security, I do not touch because I do not know what it is with :) . well, but if it is not sealed, will it withstand all this? engine, of course, working star / triangle. I live in the countryside, so there will be no such problem with the neighbors because already in the spring, when the more intense work begins, the electricity fades every day when someone is welding there, but it's better to be safe than sorry. Also my question, what is the current of this motor at high load? How does this relate to these old welders (I mean the big 3-phase old ones because I have most of them), whether the current is comparable and whether the neighbors really feel it. The measured voltage is about 237 volts in the sockets as it contributes to the matter :) electrician is not my element, so please be understanding in the rough approach to the topic :)
  • #24 7722213
    Mariuszczs
    Level 19  
    Help: 6
    Rate: 114
    This motor will consume about 25A during operation, star start around 35A delta start around 150A. You will have a motor, it will write on it what the rated current is.
    I will tell you right away that from my experience, the welder is a piece of cake compared to the start of the 15kW compressor.
  • #25 7733111
    cranky
    Level 30  
    Help: 70
    Rate: 416
    Classic engines of the most common compressors were just 11kW. I know how something like this starts from the wind network - even through gw / tr. Pure tragedy. In fact, motor 15 or 11 with a soft starter is better (an inverter would be even better). Unfortunately, ZE will cling, just like the neighbors, whose light may be too dim (voltage dips, sudden change of cosine). I just hope you are close to the transformer.
    I do not understand my colleagues who ban the Electricity Association for increasing the fee and the surcharge for changing the nature of the collection. Finally, there are 2 such recipients and it is necessary to mention the fact that I will not mention compensation. Those whose home appliances gave up their spirits from such pins and sags probably understand EV.
  • #26 7733124
    retrofood
    Help: 1140
    Rate: 4800
    You must be exaggerating. Nobody here swears. And since a few colleagues find the facts, that's a good thing. ZE does not play with the nuances, because he knows that he is practically a monopolist and that's it. And a few of our remarks are not likely to hurt him.
    And it is not so fast to be mentioned, oh no.
  • #27 7733637
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    I have an 11 kW motor and it starts normally from a star and with a heavy load. Somehow the light does not dim in the whole village. In fact, it is barely noticeable at home.
    It would have to be a 30kVa transformer and a 16 mm2 line in this village ... But it probably also happens.
  • #28 7734012
    Mariuszczs
    Level 19  
    Help: 6
    Rate: 114
    For me there is a 25mm2 line and there is a tragedy, but because the compressor has a large flywheel, the start-up is long. Of course, not only the compressor is bad for this network, because an ordinary electric kettle also dims the light in the entire village, but the compressor also turns off, for example, TV sets.
  • #29 7735337
    Informacja
    Rate: 26
    If you already use large inductive reactive power receivers, it might be worth compensating for them at least partially with capacitors.
    And you will cause less voltage drops and you will pay less for energy.
  • #30 7735881
    cranky
    Level 30  
    Help: 70
    Rate: 416
    As for the bills, he will not pay a penny less in the current tariff. Only after "retraining" will he pay for the passive. Of course, in accordance with the contract, he undertook not to charge a larger reactive amount (something or rather tg phi).
    As for reducing the drops when starting the compressor with a capacitor, I don't think I get how it should work. Maybe a colleague explain?
    Michcio - unequal load. The compressor provides "hammer" resistance not to the entire engine revolution, but tremendously strong at a few points per revolution. It doesn't matter after the engine revs, but the first, the first three revolutions, is a massacre for the engine. Hence the voltage dip and the pins.
The discussion revolves around the electrical capacity of a 1968 countryside house with a 3-phase installation, specifically regarding the feasibility of operating a 15 kW motor. The original poster is uncertain about the existing connection power, which is indicated to be 14 kW, and seeks advice on whether this is sufficient for the intended motor use. Participants suggest checking the contract with the power provider for connection details and recommend consulting an electrician for a site assessment. Concerns are raised about the starting current of the motor, which can reach up to 150A, and the potential need for upgrading the connection power to accommodate the motor's demands. The conversation also touches on the costs associated with increasing power capacity and the implications of reactive power on electricity bills. Additionally, the importance of proper fusing and the potential for voltage drops during motor startup are highlighted.
TL;DR: Starting a 15 kW compressor motor can pull 150 A on direct-on-line start [Elektroda, Mariuszczs, post #7722213]; “pure tragedy” for weak rural lines, warns cranky [Elektroda, cranky, post #7733111] Verify your contract power first or upgrade to 20 kW and 32 A fuses before energising.
Why it matters: Oversized inrush current can black-out your neighbours and breach your utility agreement.
How do I check the official connection power for my house?
Look at your supply contract or call the utility (ZE) with your customer number; they will tell you the contracted power and fuse size [Elektroda, Łukasz-O, post #7708639]
Three fuses marked L20 A, L20 A, L16 A sit by my meter—what power does this indicate?
A 3 × 20 A set limits continuous three-phase load to about 14 kW (√3 × 400 V × 20 A ≈ 13.8 kW) [Elektroda, willy1986, post #7708395]
What running and starting current should I expect from a 15 kW, 400 V motor?
Rated current is roughly 26 A. Star start draws ≈ 35 A, direct start ≈ 150 A—about six times rated [Elektroda, Mariuszczs, post #7722213]
How much will it cost to raise my supply from 14 kW to 20 kW?
Utilities charge PLN 120–150 per additional kW, so +6 kW costs about PLN 720–900, plus a small one-time administrative fee [Elektroda, retrofood, post #7718466]
Do I need to tell the utility that the new load is a compressor motor?
Yes. ZE can reject upgrades if the load is classed as ‘service’ rather than household use, forcing a business tariff [Elektroda, retrofood, post #7718740]
Why do lights dim or TVs reset when large motors start?
Motor inrush drags voltage down on thin rural lines; users report kettles and welders already dimming lights on 25 mm² conductors [Elektroda, Mariuszczs, post #7734012]
What can I do to cut start-up current spikes?
  1. Fit a star-delta starter or soft-starter (Schneider, Danfoss).
  2. Keep cable runs short and ≥ 6 mm² Cu.
  3. Start with unloaded compressor if possible. "Soft-start is better," notes cranky [Elektroda, cranky, post #7733111]
Is power-factor compensation with capacitors worthwhile on a home tariff?
No savings under G11 because the meter bills only active kWh; a 500 kvar capacitor cuts no cost [Elektroda, marian_em, post #8388804]
Could the utility seal post-meter fuses, and what if I swap them?
ZE sometimes seals post-meter breakers as current limiters. Breaking the seal is tampering and risks penalties [Elektroda, Łukasz-O, post #7719252]
How do I size cables and protections for a 15 kW motor?
Use 5-core 6 mm² Cu or 10 mm² Al up to 30 m, protected by 32 A gG at the main panel and a-M 32 A motor fuse per Markiewicz tables [Elektroda, troll21, post #8471853]
What’s an edge case where the utility refuses the motor connection?
If measured dips exceed 5 % or the motor exceeds 11 kW limit for household class, ZE can demand a separate business connection [Elektroda, Mariuszczs, post #7718979]
3-step guide: upgrading to 32 A pre-meter fuses?
  1. Submit written request with new 20 kW load list.
  2. Pay quoted connection fee (≈ PLN 720–900).
  3. Utility replaces seals, installs 32 A NH fuses, and updates contract—work must be done by a licensed electrician [Elektroda, Qnt, post #7718614]
