Consequences of Unscrewing Expansion Tank Cap on a Warm, Turned-off Engine
qer 109519 17
What happens when you unscrew the coolant expansion tank cap on a warm, switched-off engine, and is the hissing sound normal?
A short hiss when you unscrew the expansion tank cap on a warm, switched-off engine is usually just pressure being released and is normal, but do it carefully because hot coolant can spray out [#7792615][#7793288][#7792843] The coolant system cap has two valves: an overpressure valve and an underpressure valve, and both should work properly [#7796128] If the overpressure valve is faulty, hot hoses may stay soft; if it does not open, the hoses can become very hard, and if the underpressure valve does not open, the hoses can be flattened on a cold engine [#7796128] A brief equalizing whistle after shutdown does not by itself prove a head gasket fault; to check for gas leaking into the cooling system, a bottle test is recommended [#7793009][#7796128]
  • #1 7792551
    qer
    Rate: 9
    what should be the effect of unscrewing the expansion tank cap on a warm engine off?
    I hear air sucking in, is it bad?
    Greetings,
    qer
  • #2 7792615
    Piotr520
    Help: 68
    Rate: 243
    Rather, you can hear air escaping from the reservoir. You should be able to hear this short psytes and that's it.
  • #3 7792625
    Qbuś
    Help: 380
    Rate: 876
    qer
    You can't immediately write what engine is it, what car etc ....... ???
    (fortune teller no longer accepts, they work until 18 :cry: )
  • #4 7792637
    xxxRebounDxxx
    I do not know 100%, but it is rather not air suction, but pressure released ... that's why there is usually some achtung on the cork .. :D
  • #5 7792642
    wmarek65
    Help: 11
    Rate: 35
    It depends on the car, there are cars that have an "open" expansion tank and a closed one (tightness of the plug in the tank because it is not on the radiator), e.g. Audi WV, in these cars there is a similar symptom, but as an overpressure after turning off the engine, but after complete cooling there may be a symptom of negative pressure (due to fluid expansion)
  • #6 7792728
    manta
    Help: 463
    Rate: 1533
    And the check valve in the traffic jam?
  • #7 7792766
    qer
    Rate: 9
    OPEL Astra F 1.6, why am I asking?
    Today I was picking up the car from the mechanic, he was showing me what he had done and me
    by the way, I checked the oil and coolant levels, they were
    ok, but the mechanic said it was after twisting the tank cap
    equalizing coolant, you could hear the whistle of the air, it was evidently a sign that I had a gasket under the head and said that occasionally for PLN 500 he would do it to me: / I ignored him, because such a diagnosis only after hearing something, basically without
    Checking out other things is probably a failure, but I started now
    wondering ... is such a whistle (I do not know if it is sucking or pushing - you can hear the whistle!) on a warm engine something disturbing ??
  • #8 7792843
    manta
    Help: 463
    Rate: 1533
    Normal symptom.
  • #9 7792861
    fake_nick
    Help: 12
    Rate: 69
    no difference what kind of car it is, the negative pressure in the cooling system hits the leakage of the cooling system-combustion chamber system
    very bad indeed, only a book fault
  • #10 7792873
    fake_nick
    Help: 12
    Rate: 69
    I didn't read until the end,
    as there are no problems, do not unscrew :D
  • #11 7792888
  • #12 7793009
    manta
    Help: 463
    Rate: 1533
    Regardless of what the car is, the negative pressure in the cooling system indicates a leak in the cooling system-combustion chamber system
    very sporadically, even only a bookish defect.
    Let a friend kindly explain when a vacuum is created in an internal combustion engine? And spelling to be improved.
  • #13 7793239
    fake_nick
    Help: 12
    Rate: 69
    vacuum is created when fluid is drawn into the combustion chamber,
    practically unheard of in passenger cars, in 4-4 layout motorcycles
    where the cooler is above the combustion chamber system also not very common, but common
    units from the early 1980s
    half a year ago, w203 due to such a condition, after replacing the thermostat, it came to me
    suction of the vice with the addition of "gas"
    WHAT TO WRITE, MR. MODERATOR
    WRITTEN ON THE MECHANICS FORUM
    If I was looking for help from Polish language teachers, I would write on their forum :D
  • #14 7793288
    palmotor
    Help: 5
    Rate: 23
    In the case of some engines (where there is liquid directly under the plug), the effect may be a boiled hand or face. Therefore, I advise you to be careful when playing with the cooling system.
  • #15 7793932
    lukasz530
    Rate: 23
    Dawn is due to fluid pressure (air is forced out as warm fluid is). And this is no opportunity to replace PLN 500, the seals costs about PLN 100 (up to 1.7 isuzu PLN 130, so it is probably cheaper for gasoline) and the labor is a maximum of PLN 120.
  • #16 7794662
    manta
    Help: 463
    Rate: 1533
    Oh, I am supposed to understand that the leak is a check valve that allows underpressure, but does not allow a dozen times greater overpressure at the time of ignition?
  • #17 7795163
    Ekolog
    Rate: 11
    I have an astra F 1.4 16v, I also had something like that, if it also catches a slightly higher temperature than the standard, the mechanic was right because I had the same thing, you gave the kite too much and the gasket to be replaced :P
  • #18 7796128
    gimak
    Help: 614
    Rate: 1678
    Just to add, the plug closing the cooling system, regardless of whether it is on the radiator or the expansion tank, has two valves: overpressure (something like a safety valve), opening when the pressure increases above a certain value (depending on the performance of the plug) and underpressure, through which it is to occur equalization of pressure in the cooling system (if negative pressure is created in it) with the atmospheric pressure. Both valves should be operational. If the overpressure valve is faulty, i.e. leaky, then the rubber hoses on a hot engine are soft, while if it does not open, the hoses will be as hard as stone. Vacuum valve when it is inoperative: i.e. leaky, symptoms are like a leaky overpressure valve, but when it does not open, the rubber hoses on a cold engine become more or less flat. To check the existence of purges to the cooling system (gas - with gas or exhaust gas - with a blown gasket under the head), I recommend the bottle test (described by me), it is simple, reliable and unambiguous.
Unscrewing the expansion tank cap on a warm, turned-off engine can lead to the release of pressure, which may produce a whistling sound as air escapes. This is generally a normal symptom, indicating that the cooling system is equalizing pressure. However, caution is advised as it can also lead to hot coolant splashing out, potentially causing burns. The behavior of the cooling system can vary depending on the vehicle type, with some having open or closed expansion tanks. If negative pressure is present, it may indicate a leak in the cooling system or combustion chamber. Regular maintenance of the cap's valves is crucial to prevent issues related to pressure regulation.
