Peugeot 207 1.4 8V Ejects Coolant on Unscrewed Cap: Thermostat, Head Gasket & Overheating Issues
polo54 61503 19
Why does my Peugeot 207 1.4 8V eject coolant from the expansion tank when the cap is removed, even though the temperature seems normal, and what should be checked?
Coolant ejection from an open expansion tank is not necessarily a fault: the cooling system is designed to remain sealed and pressurized, and opening it lowers the boiling point; coolant can also be expelled by pump flow when engine speed is raised, especially if the cold level is above halfway between MIN and MAX [#17396127] [#17398038] However, ejection at idle on a genuinely cold engine can indicate combustion gases entering the cooling system, so the system should be checked for blow-by [#17398038] [#17412854] Bleed the system through both designated vents—one at the rear of the cylinder head and one at the heater inlet near the bulkhead [#17412617] Because the later overflow occurs after stopping while the temperature appears normal during driving, verify that the radiator fan switches on correctly and that the expansion-tank cap releases at its specified 1–1.4 bar [#17414470] [#17413980]
  • Possible coolant circulation issue with cap open
    #1 17396106
    polo54
    Rate: 19
    Hello. I have a problem with the Peugeot 207 1.4 8V, namely it ejects the liquid when the cap from the tank is unscrewed. When the plug is closed, it keeps the temperature, the fan turns on normally. Two months ago, the thermostat was replaced, now the head gasket was replaced (the head was planed, checked for tightness, valves, seals and valve guides were replaced), the o-rings under the sleeves and the timing with the water pump were also replaced. I would like to add that before replacing the thermostat and the gasket, it was also the case and that is why the gasket under the head was overheated. I checked the flow of the heater and cooler too. I do not know what the reason is, unfortunately, it looks as if there is no fluid circulation on the open plug. Please give me some hints.
    Pressurized cooling system can boil with cap open
    #2 17396127
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    There is probably (I'm not sure) that the cooling system is closed, pressurized and after its opening and while it is working, such cases can happen in such a system. I also had a similar case, but with a Fiat, after opening the tank, the liquid "boiled" after a while, the diagnoses were different. The car is still running for 6 years since the case was discovered. It does not overheat, the fluid does not decrease and everything is OK, of course with the container closed.
    gimak
    Help: 614
    Rate: 1678
    Or maybe that's not a problem, just a normal thing when the engine temperature is to be above 100 ° C.
    In the Peugeot 2008 daughter, and the engine temperature is kept at 103 ° C and in this case, it is normal that when the cap is loosened it will eject fluid.
  • #4 17396249
    andrzej20001
    Help: 1578
    Rate: 6669
    what are you rummaging for?
  • #5 17396409
    ociz
    Help: 1379
    Rate: 3486
    Too much money, you wanna smash your engine? The cork is to be tightly closed and that's it. The worst thing you can do is unscrew the cap on a hot engine, a sudden drop in pressure lowers the boiling point.
    Need engine temperature before opening coolant cap
    #6 17396777
    wodzu_1
    Help: 72
    Rate: 144
    To the author of the post: you did not specify at what engine temperature you unscrewed the reservoir cap.
    However, you must acknowledge, if you do not know when you can unscrew the cap, you better not do it - even for your own good.
    Colleagues clearly suggest that the pressure system is to be tightly closed.
  • Bleeding issue despite cold engine and open tank manual
    #7 17397776
    polo54
    Rate: 19
    The plug was unscrewed on a cold engine, I know that it does not unscrew on a hot one, so far it is the first engine that I do, so it is, no one has done it yet, and always when I vented after replacing the pumps with the timing, no one did, I know the laws of physics and I know what is going on with the pressure in the circuit and the boiling point of the fluid that is different, please give me some hints and not instructions when I can unscrew the cap, because I know it, in the manual from 206 with the same engine it says that when bleeding the system after replacing the fluid, the tank is to be open, and this is not possible just like that, half a minute and the fluid breaks down, some failure and that's it.
    High-rpm coolant ejection only with overfilled tank
    #8 17398038
    gimak
    Help: 614
    Rate: 1678
    polo54 wrote:
    The cap was unscrewed on a cold engine, I know that it does not unscrew on a hot one,
    If a colleague had marked it at the beginning, there would be less guesswork.
    polo54 wrote:
    in the manual from 206 with the same engine it says that when bleeding the system after replacing the fluid, the tank should be open, and here it is not possible just, half a minute and the liquid crashes, some failure and that's it.
    I do not know exactly how it is presented in the manual, but if this happens with the engine running at idle, it may indeed be the beginning of a failure (blow-by), but if this happens with a sharp increase in RPM and holding them at a high level for a while , fluid may be ejected with the reservoir open. Something like this surprised me in a megance and I thought I had a blow to the cooling system, but it wasn't. The second surprise was when, instead of the original cork, I put on a cork with a hose and put this hose into the bottle (to the bottom). Then, with this sharp increase in revolutions, the liquid was ejected into the bottle, but as soon as I slowed down the revolutions, the liquid from the bottle was sucked back into the surge tank. I also noticed that the described trend was only present when, on a cold engine, the fluid level in the expansion tank was above halfway between the MAX and MIN marks.
  • #9 17401080
    polo54
    Rate: 19
    We'll see what will happen, so far I gave my friend the car and told him to watch the coolant level in the tank, after some time I will let you know if everything is fine or not. Thanks to everyone for the answer. Regards
  • #10 17412488
    polo54
    Rate: 19
    Hello everyone, but something is wrong.Yes, my friend made over 600km home and the whole road was ok, then he did 15 km and there was such pressure in the system that it spilled fluid on the connection of the lower hose going to the radiator and the radiator on this clamp , any ideas?
  • #11 17412515
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    At 1.4 8V, the gasket likes to rot and also likes to leak through the oil supply channel.
    Replacing the gasket as a piece of cake.
  • #12 17412617
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    polo54 wrote:
    any ideas?
    Could be badly vented. There are 2 vents, one on the back of the head and the other at the entrance to the heater, deep against the bulkhead wall.
  • #13 17412854
    gimak
    Help: 614
    Rate: 1678
    I do not know what it looks like a Peugeot, but in all the cars I have had and I have, if the thermostat was opened (a large circuit was opened), the system automatically vented completely.
    polo54 wrote:
    Yes, a friend made over 600km home and the whole way was ok, then he did 15 km and there was such a pressure in the system that it ejected fluid on the lower hose connecting to the radiator and the radiator on this clamp, any ideas?
    Here, the thermostat was definitely open. Perhaps sometimes the thermostat may get jammed, but then there should be an information on the board about an excessive increase in engine temperature (if the engine is not gassed), so in my opinion, you need to check whether the control (indication) of the engine temperature is efficient, possibility of blocking the opening of the thermostat. In connection with the leakage described, it is also checked whether the plug on the expansion tank is functional, because it should not allow such a pressure increase.
    I would also check if there is any blow to the cooling system.
  • #14 17413977
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    gimak wrote:
    I don't know what a Peugeot looks like
    You can see buddy that you don't know what a Peugeot looks like :-)
    There is a reason that they made these vents because the air must be released if the small circulation hoses are directed downwards.
  • #15 17413980
    ociz
    Help: 1379
    Rate: 3486
    gimak wrote:
    he should not allow such pressure to rise
    The stopper is released at a pressure within 1-1.4 bar. Old, rotten snakes can't stand it.
    And BMW is at all. ;)
  • #16 17414210
    gimak
    Help: 614
    Rate: 1678
    I wrote it unfortunately, because I know what the Peugeot looks like, but I do not know the spatial cooling system in this car and I also know very well what the vent plugs are for.
    gimak wrote:
    It follows from this text that at the beginning the system was vented, because I do not think that driving on the 600 km route, with the air in the system, was normal.
    And even if the cooling system was not thoroughly deaerated at the beginning, while driving, when the thermostat opened (and it certainly did), the pump should chase all the bubbles to the expansion tank during the 600 km of travel. In addition, the inefficient cooling system is accompanied by an increase in the temperature of the coolant, which the author does not mention.
  • #17 17414404
    polo54
    Rate: 19
    I did not mention the temperature, because it is surprisingly okay, i.e. it oscillates around 90 degrees (reading from the temperature indicator and in the computer), a friend called me today and it looks exactly like it is good when driving, but how to he will stop for a while or he will quench it, then he throws out the liquid, he told me so much.
  • #18 17414470
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    polo54 wrote:
    a friend called me today and it looks exactly like driving it is fine, but when he stops for a moment or quenches it then throws out the liquid, he told me so much.
    Reading this last entry, this begs me:
    And the radiator fan turns on at all, does it work?
    While driving (even faster), it is cooled by the rush of air and the fan does not have to turn on. As the cooler is efficiently efficient, the momentum of the air while driving is enough to cool the engine. Slower driving or stopping, the fan must "work", maybe it does not turn on as it should and that's why such "circuses". The fan simply does not turn on as it should and during this time (slow driving, stopping, even turning off a well-warmed engine after driving), the engine "boils" and the fluid is ejected ...
  • #19 17414628
    Help: 1405
    Rate: 6430
    Do you have air conditioning?
  • #20 17414652
    gimak
    Help: 614
    Rate: 1678
    As he wrote wojtek1234321 .
    My neighbor in a garage in a Ford Fiesta has a similar situation. It does not lose the fluid while driving, but when it comes to the garage and opens the garage door, the expansion tank starts to boil over. The fan turns on for him, I guess it's a bit late, but the neighbor prefers to add liquid instead of going and checking the temperature sensor
The discussion revolves around a Peugeot 207 1.4 8V experiencing coolant ejection from the expansion tank when the cap is unscrewed. The user has replaced the thermostat and head gasket, yet the issue persists, suggesting potential problems with fluid circulation. Responses indicate that coolant ejection may occur due to a pressurized cooling system, normal engine temperatures exceeding 100 °C, or improper venting. Suggestions include checking the radiator fan operation, ensuring proper venting of the cooling system, and verifying the functionality of the expansion tank cap. The user reports that the engine temperature remains stable around 90 degrees Celsius, but coolant spills occur during stops or after driving. Further investigation into the cooling system's integrity and pressure management is recommended.
TL;DR: On Peugeot 1.4 8V, 103°C operating temp is normal; "when the cap is loosened it will eject fluid". Keep the cooling system sealed; diagnose fan, cap, vents, and gasket if overpressure appears. [Elektroda, gimak, post #17396195]
Why it matters: For Peugeot 207 1.4 8V owners and independent techs, this FAQ helps diagnose coolant ejection, overpressure, and safe bleeding procedures.
Why does my Peugeot 207 1.4 8V eject coolant when I unscrew the expansion cap?
The system runs sealed and can regulate around 103°C. Loosening the cap drops pressure, and hot coolant surges or flashes. That behavior is expected if you open the system at that temperature. Keep the cap closed during operation. [Elektroda, gimak, post #17396195]
Is 103°C a normal operating temperature for this engine?
Yes. A Peugeot petrol engine can regulate around 103°C under normal use. At that temperature, cracking the cap will eject coolant. This aligns with a pressurized, closed cooling system’s design. [Elektroda, gimak, post #17396195]
Can I open the coolant cap on a hot engine to release pressure?
No. "The worst thing you can do is unscrew the cap on a hot engine." Depressurizing instantly lowers the boiling point and causes boil‑over. You also risk burns and engine damage. Only open when the engine is cold. [Elektroda, ociz, post #17396409]
How do I correctly bleed the Peugeot 1.4 8V cooling system?
Use the two factory bleed points.
  1. Open the rear‑of‑head vent and the heater‑inlet vent at the bulkhead.
  2. Fill slowly until a steady, bubble‑free stream flows from both vents, then close them.
  3. Top to the mark, run briefly, recheck, and repeat. [Elektroda, diodabg, post #17412617]
Why does it overflow only after stopping or shutting off, not while cruising?
At speed, airflow through the radiator cools effectively. When you slow or stop, cooling depends on the radiator fan. If the fan does not engage, heat builds and coolant can boil over and eject. Verify fan operation at idle. [Elektroda, wojtek1234321, post #17414470]
How can I quickly check if the radiator fan and control are working?
Let the engine idle after a hot drive and watch for the fan to engage. If the fan starts late, you can see boiling at the tank. That points to a control or temperature sensor issue rather than a blockage. Check the sensor first. [Elektroda, gimak, post #17414652]
What pressure should the cap relieve at, and can old hoses burst first?
The reservoir cap typically relieves around 1.0–1.4 bar. If hoses are weak, they can leak or burst before the cap vents. "Old, rotten hoses can't stand it." Replace suspect hoses and clamps before stress testing. [Elektroda, ociz, post #17413980]
Could the head gasket still be at fault after replacement on the 1.4 8V?
Yes. The 1.4 8V head gasket is known to rot and can leak at the oil feed. Combustion gases can still pressurize the cooling circuit if sealing fails. Re‑test for combustion in coolant before chasing other faults. [Elektroda, Strumien swiadomosci swia, post #17412515]
It drove 600 km fine, then after 15 km it blew coolant at a lower hose clamp—what does that indicate?
That report shows the system held during a long drive, then overpressure appeared soon after. The lower hose‑to‑radiator joint was the weak point, so fluid escaped there. Reseat or replace that clamp and monitor the level closely on the next drive. [Elektroda, polo54, post #17412488]
With the cap off, revving hard shoots coolant out and then it gets sucked back—normal?
Yes, with an open system, high RPM increases pump flow and can push coolant out. When you drop RPM, the system can draw the expelled coolant back. Route any overflow into a bottle. Keep the level between the marks. [Elektroda, gimak, post #17398038]
Should I leave the tank open during bleeding like a 206 manual says?
One owner noted the 206 manual instructs bleeding with the tank open. In his case, with the tank open, fluid ejected within about 30 seconds, suggesting a fault. If that happens, stop and diagnose before continuing. [Elektroda, polo54, post #17397776]
Could a sticky thermostat or faulty gauge be causing this with “normal” readings?
A contributor recommended checking the temperature indication and thermostat movement. A jammed thermostat would show high temperature warnings if sensing works. Also test the reservoir cap and check for combustion pressure in the cooling system. [Elektroda, gimak, post #17412854]
Can trapped air persist on this engine, and why are there two bleed points?
Yes. The small‑circuit hoses route downward, which traps air unless you open the vents. The two bleed points exist to purge those pockets during filling and service. Skipping bleeding leaves air that upsets circulation. [Elektroda, diodabg, post #17413977]
Is cracking the cap to “test” pressure a good idea?
No. The cooling system is designed to stay tightly closed during operation. If you are unsure when to open it, don’t. Open only when cold to avoid injury and false symptoms. [Elektroda, wodzu_1, post #17396777]
