How to convert battery Wh to Ah at 11.1V, and can 20V chargers interchange?
as127 32112 2
  • #1 7869012
    as127
    Help: 16
    Rate: 13
    The question as in the title, maybe someone will take pity and tell you :-)
    I have 2 notebooks, one has a 4.4 Ah battery and the other 28 Wh
    (both voltages the same 11.1V)
    How to convert from one value to another? (to compare)
    Chargers have the same dimensions, voltages and polarities,
    different powers (2 A and 3.25 A, both 20V), identical plugs
    can I use them interchangeably?
    But there are other computer makers: twinhead and lenovo
    The manufacturer of the chargers is the same (LI SHIN), and the batteries are probably the same
    but I can't read it because it's written in bushes, probably in Chinese
    Maly
    Help: 195
    Rate: 336
    You can probably assume that from the first one we will get 4.4A in an hour, so at a voltage of 11.1V (4.4 * 11.1) we will get the power of almost 49W, i.e. for an hour 49Wh.
    The second, when it has 28Wh, for an hour with this voltage, we can "take" the current 28 / 11.1 = 2.5A. So how for an hour is 2.5Ah.
    It turns out that this 4.4Ah is more powerful, so it must have a more powerful power supply. This 3.25A will be from him.
    Regards.
  • #3 20370748
    azaghorth
    Rate: 11
    Power, P=U*I, where U is the voltage and I is the current
    Energy W=P*t, where t is time (usually in hours)
    For example a battery with 3.7V and 5000mAh can provide 18.5Wh (3.7V times 5Ah), where 5000mAh=5Ah.
