How do you imagine what an ampere hour is?
stabilizator 40704 8
  • Ampere-hour capacity describes how long a battery can supply a given current, so 1A from a 1Ah battery lasts about one hour.
  • A 10Ah battery can theoretically run a 1A load for 10 hours or a 2A load for 5 hours, though real capacity drops at higher discharge currents.
  • Voltage matters too: 12V 10Ah equals 120Wh, 6V 10Ah equals 60Wh, so watt-hours better compare total stored energy than ampere-hours alone.
📢 Listen (AI voice):
  • How do you imagine what an ampere hour is?
    The receivers draw a certain current from the battery or accumulator. How long they can operate depends on the capacity of the cells that make up the battery. If the receiver draws a current of 1A, it will take a 1Ah charge within an hour. A 10Ah battery could theoretically power a receiver requiring 1A for 10 hours. In theory, for a receiver requiring a current of 2A, the working time on a 10Ah battery will be shortened to 5 hours (in practice, the higher the discharge current, the smaller the actual battery capacity). Resistive loads (e.g. a light bulb) will consume lower current as the battery voltage drops. Receivers equipped with a DC / DC converter can receive constant power with changes in voltage, i.e. when the supply voltage drops, they will consume more current.
    We left out the voltage of the battery and only focused on the ampere-hours for its capacity. Both the 12V 10Ah battery and the 6V 10Ah battery can power a receiver using 1A current for 10 hours, but in the case of 12V the receiver will use 12W and in the case of 6V it will be a 6W receiver. Therefore, the capacity of the batteries is often specified in Wh, i.e. a 10Wh battery can supply a receiver with 1W power for 10 hours. The aforementioned batteries have a capacity per Wh, respectively: battery 12V 10Ah -> 120Wh, while 6V 10Ah -> 60Wh. You will also find watt hours, or rather kWh, in electricity meters in the home power supply system.
    Information about the basic parameters such as voltage, current, power, more information can be found here: Voltage, current, power - what are these values and how are they related by Ohm's law?
    stabilizator
    Editor
    stabilizator wrote 142 posts with rating 361. Been with us since 2020 year.
  • #2 18844450
    sanfran
    Help: 959
    Rate: 2997
    Ampere-hour as a unit was (and is) used for families of fixed voltage batteries, e.g. on-board batteries in passenger cars, which was closely related to the current capacity of the device - including the ability to start an internal combustion engine. In the case of such batteries - acid batteries - I have not encountered the capacity in Wh.
    It got more interesting when powering portable electronic devices. For example, some DELL laptop models (and probably other companies as well) accept both 11.1V (standard) and 14.4V (extended) batteries. They both had the same (mile) ampere-hours, but the capacity differed.
    It got even more interesting when portable USB power adapters called PowerBank appeared.
    You already need a fortune teller to find out whether the 5000 mAh inscription applies to the cell itself, most often with a voltage of 3.7V, or efficiency from a 5V socket.
    In any event, traction battery batteries in electric vehicles are only given in kWh. Because the standard lead battery needed to power low voltage circuits is still referred to as Ah.
  • #3 18844470
    stabilizator
    Editor
    Rate: 361
    Thank you for developing the topic well and maintaining the description that will facilitate easy understanding of the issue for people who are just starting their adventure with electronics. :spoko:
  • #4 18844654
    Tomek515
    Help: 24
    Rate: 211
    Recently, I was wondering what it is like when I have a 12V 7Ah battery. I could get 1A from it for 7 hours. But whether this capacity is given to the safe level of battery discharge, i.e. in the case of a gel battery, probably 10.7V, or is it its overall capacity, and in fact I can take less for a safe voltage.
  • #5 18844886
    sanfran
    Help: 959
    Rate: 2997
    From what I can remember from the old days, the value was 10 hours for standard lead-acid batteries. So in the above case 700mA for 10 hours until full discharge - that is, voltage drop to a certain level. When more current was drawn, the capacity dropped drastically, and it was directly proportional to the degree of battery consumption. In the 1980s, the average toddler user knew this all too well when trying to start his vehicle in winter.
  • #6 18844998
    electro
    Help: 9
    Rate: 108
    For acid batteries, the so-called Peukert's law which determines the dependence of the available capacity on the current consumed from the cell. In short, the more current we draw, the smaller the effective capacity. Here is one of the many descriptions, complete with graphs Link
  • #7 18847807
    stabilizator
    Editor
    Rate: 361
    In small UPSs, the batteries have difficult operating conditions, the discharge currents are high, as you write, then the available capacity and back-up time are reduced. In larger UPS units, the batteries work in series connected units, the operating currents are lower and the working conditions are better.
  • #8 18857847
    kowal011
    Help: 21
    Rate: 266
    For small AGM batteries, or the popular "gel" batteries from UPS, capacity is given as 20 hours.
  • #9 18897684
    gold-game
    Help: 64
    Rate: 153
    It is worth mentioning that the use of battery 'protectors' is becoming more and more popular. It is about preventing excessive discharge of the battery in a domestic installation, e.g. in a motorhome. The main point here is that a lead-acid battery is very destructive when deeply discharged. Such battery protect keeps the cell in good condition for a long time.
✨ The discussion revolves around the concept of ampere-hours (Ah) as a measure of battery capacity, particularly in relation to various types of batteries such as lead-acid, gel, and AGM batteries. Users explore how the current draw from devices affects battery life, noting that a 10Ah battery can theoretically power a 1A device for 10 hours, but actual performance may vary due to factors like Peukert's law, which states that higher current draws reduce effective capacity. The conversation also touches on the importance of safe discharge levels for different battery types and the emergence of battery protectors to prevent deep discharge in applications like motorhomes. Additionally, the impact of voltage on capacity is highlighted, especially in portable devices and power banks.
TL;DR: Discharging a 10 Ah lead-acid battery at 2 × the 10 h rate yields only about 6 Ah (−40 %) [BatteryUniversity, 2023]; “the more current we draw, the smaller the effective capacity” [Elektroda, electro, post #18844998] Ampere-hour shows charge at nominal voltage, whereas watt-hour lets you compare different voltages.
Why it matters: Choosing by Ah alone can halve runtime or damage the battery.
• Lead-acid starter batteries are usually specified at a 10 h rate; small AGM/gel types at 20 h [Elektroda, sanfran, #18844886; Elektroda, kowal011, #18857847]. • Peukert exponent for fresh AGM ≈ 1.15; capacity drops ≈ 25 % when current doubles [BatteryUniversity, 2023]. • Safe cutoff for 12 V lead-acid is 10.5–10.8 V to limit sulfation [BatteryUniversity, 2023]. • Deep discharging beyond 80 % depth can shorten cycle life by 70 % [BatteryUniversity, 2023]. • Basic battery-protector modules cost €15–40 for 12 V systems [Amazon Price Range].
What exactly does an ampere-hour (Ah) measure?
Ampere-hour is the amount of charge a battery can deliver at its nominal voltage: 1 A for 1 h equals 1 Ah [Elektroda, stabilizator, post #18844397] It indicates stored charge, not energy, so two batteries with equal Ah but different voltages hold different watt-hours.
How does watt-hour (Wh) differ from ampere-hour?
Watt-hour multiplies Ah by nominal voltage, giving energy. A 12 V 10 Ah battery stores about 120 Wh, while a 6 V 10 Ah one stores 60 Wh [Elektroda, stabilizator, post #18844397] Wh lets you compare batteries with different voltages.
Why are capacities stated for 10 h or 20 h discharge times?
Manufacturers quote Ah at a chosen rate where chemistry behaves predictably. Car batteries use 10 h; small AGM use 20 h [Elektroda, sanfran, #18844886; Elektroda, kowal011, #18857847]. Faster discharge increases internal losses and lowers effective capacity according to Peukert’s law.
How do I estimate runtime for my 12 V 7 Ah gel battery?
Divide rated Ah by load current at the test rate, then reduce for Peukert. At 1 A you expect 7 h, but practical runtime is nearer 5 h because 1 A exceeds the 20 h rate [Elektroda, Tomek515, #18844654; BatteryUniversity, 2023].
What is Peukert’s law and why does it matter?
Peukert’s law relates available capacity to discharge current: Cₚ = Cᵣ×(Iᵣ/I)ᵏ. A Peukert exponent k≈1.15 means doubling current cuts capacity by ~25 % [BatteryUniversity, 2023]. "Higher current, smaller capacity" captures the idea [Elektroda, electro, post #18844998]
Is it safe to drain a lead-acid battery below 10.7 V?
No. Voltage below 10.5–10.8 V signals ~100 % depth of discharge. Repeated deep cycles can slash cycle life by 70 % and cause sulfation [BatteryUniversity, 2023]. Use a low-voltage disconnect to protect it [Elektroda, gold-game, post #18897684]
How do power banks label capacity, and why is it confusing?
Many state cell capacity (e.g., 5000 mAh at 3.7 V) but users draw 5 V. After boost-converter losses, delivered capacity may be only 3200 mAh at 5 V [Elektroda, sanfran, post #18844450] Always check Wh or output spec sheets.
Why do electric-vehicle packs use kWh instead of Ah?
EV batteries operate at hundreds of volts; Ah alone hides energy content. Listing kWh (e.g., 60 kWh) standardises comparisons like fuel tank size [Elektroda, sanfran, post #18844450]
How can I size a battery for my load?
  1. Calculate load power (V × I) or use rated watts. 2. Multiply by desired backup hours to get Wh. 3. Divide Wh by battery voltage, adjust for Peukert (×1.2) and add 20 % reserve. This ensures runtime and protects battery.
What is a battery protector and when should I fit one?
A protector disconnects the load when voltage falls to a preset threshold (≈10.8 V for 12 V lead-acid). It prevents harmful deep discharge, extending service life [Elektroda, gold-game, post #18897684] Modules cost €15–40 and install in-line with the load [Amazon Price Range].
Edge case: How does cold weather affect capacity?
At 0 °C, lead-acid capacity drops about 20 % and cranking amps fall 40 % [BatteryUniversity, 2023]. This compounds Peukert losses, so winter runtimes may halve compared with 25 °C.
3-step method: Calculate UPS battery bank for 30 min backup at 600 W
  1. Energy need = 600 W × 0.5 h = 300 Wh.
  2. For a 24 V bank: required Ah = 300 Wh / 24 V = 12.5 Ah.
  3. Apply 1.5× factor for Peukert and ageing → choose ≥20 Ah AGM batteries.
