Checking for GPS in Your Car: Identifying Built-in Navigation Systems & Speed Limit Features
młody2066 113097 11
How can I check whether my car has a hidden GPS tracker or navigation system installed?
To check for a hidden GPS tracker, look for extra electronic boxes under the dashboard and in the engine compartment; the GPS part only receives signals, so the actual device usually also has a GSM transmitter that sends data out [#12669605][#7873303] A spectrum analyzer up to 2.5 GHz can help you locate it by detecting activity in the L1, L2, and GSM bands [#7873324] You can also use a cheap GSM detector or a sensitive radio with headphones and listen for periodic transmission bursts from the locator [#12673776] A car computer/diagnostic connection will not show whether a GPS tracker is present [#12673334] If you tried a GPS jammer, it would stop the tracker from seeing the car’s position, but it would also break any in-car navigation that uses GPS [#12669605]
  • #1 7870924
    młody2066
    Help: 34
    Rate: 394
    Hello, I have a question because I am not sure if I have a GPS in my car or not. My colleagues at work say that it probably is and the boss also says it is. But I am not sure if it is or not. Mainly, I have a speed limit and I can't go too fast and sometimes you really have to.
  • #2 7871009
    eltron
    Help: 36
    Rate: 161
    You hide your car somewhere with GPS coverage and call your boss that they stole it from you. If it finds, it means that it has GPS, if not, it means that it does not exist. Simple isn't it? :D And when it turns out you have a problem with alcohol and sometimes you forget where you left it.
  • #3 7871030
    witek271
    Help: 19
    Rate: 174
    Good!!! I will sell it to my friends because they are afraid of the boss and they do not know whether they have GPS or not
  • #4 7871129
    młody2066
    Help: 34
    Rate: 394
    If I wanted to joke, I would write a joke and not, I ask my colleagues seriously, I'd rather avoid problems with the boss and the situation sometimes forces me to go faster. I do not believe that there is no simple logical way to check it.
  • #5 7873303
    yaaro
    Help: 195
    Rate: 1083
    You mount the gps jamming device and you spin, the gps does not emit a signal, it only receives it, only some gsm is installed to send data to the control panel.
  • #6 7873324
    Sady
    Help: 115
    Rate: 373
    All you need is a spectrum analyzer up to 2.5Ghz - and you can check where and what is this "tracker".
    Because if it is good equipment, it has L1, L2 and GSM bands.
  • #7 12669421
    Setita
    Rate: 33
    Hi
    My ex dealt with mounting GPS in cars, he has been following me for some time, it is a cause of great stress for me. How can I check if I have a GPS connected somewhere? I'm from Gorzów Wlkp. My car is a Honda Jazz.
  • #8 12669605
    NdYAG
    Help: 11
    Rate: 28
    Setita wrote:
    Hi
    My ex dealt with mounting GPS in cars, he has been following me for some time, it is a cause of great stress for me. How to check if I have a GPS connected somewhere? I'm from Gorzów Wlkp. My car is a Honda Jazz.
    You have to carve the whole car to find the electronics. The first place is to check and look for additional boxes under the desktop and in the engine compartment.
    Look for "GPS jammer" on the Allegro, put it in the cigarette lighter socket and it interferes with the GPS signal - if you have a hidden GPS receiver, it will not see the car's position. But the navigation in the car will also not work.
  • #9 12673211
    Setita
    Rate: 33
    Will the computer connected to the car show something that may indicate the presence of GPS?
  • #10 12673334
    LoLek85
    Help: 86
    Rate: 303
    Not.
  • #11 12673776
    damdam
    Help: 274
    Rate: 950
    on a popular auction site you can buy a GSM detector for a small amount of money, or use an ordinary radio with good sensitivity and headphones.
    Max. the transmitter in the locator must say something every few minutes. Characteristic sound as if you touch a GSM phone to a radio.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #12 16741916
    młody2066
    Help: 34
    Rate: 394
    I don't work there anymore.
The discussion revolves around identifying whether a car has a built-in GPS system and the presence of speed limit features. Users suggest various methods to check for GPS, including using a GPS jamming device, spectrum analyzers, and GSM detectors. One user mentions the difficulty of locating hidden GPS devices in a Honda Jazz, recommending a thorough inspection of the car's electronics. The conversation also touches on the limitations of car computers in detecting GPS systems. Overall, the responses highlight both practical and technical approaches to ascertain GPS presence in vehicles.
