SmartGPS SG730 - Unlock? A final solution to the mass of understatements?
HONDA1969 7086 3
  • #1 16530121
    HONDA1969
    Rate: 27
    Hello, I am the holder of the SmartGPS sg730 navigation. I want to unlock it ... I have read half of this forum and found nothing specific. Or someone writes and then go on the path (not saying which one) and change this or that there. I managed to unlock 3 navigations as I am a driver and I need this equipment but I really get lost. I know you have to install Mort Script that everyone mentions and describes. Everywhere is described what file to look for where to upload. The only problem is that in 10 topics there is something else that in any case in the final phase does not work. Here is a annoying menu that I would like to change to some that can handle 2 maps because in this I can only one and which can be closed but I have no drink as it looks built into the system ... Apart from that I paid for the license to automapa half the money that I spent for navigation, this menu does not yet allow the use of 2 maps, and getting to the explorer borders on a miracle because the files have different names than the people describe. Can someone help me like a layman? Just where to look and how to recognize it :(
    I kindly ask.
  • #2 16534528
    japycz321
    Help: 92
    Rate: 141
    Buddy, if someone writes what above, you expect him to know where you have a map or panel?
    Let Mortscript's colleague let it go, without experience, rather nothing good will come of it and you need to spend some time grasping.
    HONDA1969 wrote:
    Here is a annoying menu that I would like to change to one that will handle 2 maps because in this I can only one
    In summary, has a colleague the ability to change the path to the navigation program?
    If so, it doesn't need any unlocking. All you need is a simple panel containing two buttons for starting one or the other map, with the appropriate paths for these maps. The factory menu does not move. The device manufacturer also states that it is unlocked.
    So the question of solving the problem itself: you need to find, e.g. on a hamster, a 480 x 272 panel (colleague's resolution of the device), there are a lot, they differ in appearance, number of icons, etc. Set the path correctly in the panel configuration file for both maps, e.g. for automapa on the card memory can be:
    "\ SDMMC \ AutoMapa EU \ wceAM.exe"
    If the map is in a different location, the path must be modified accordingly. After all, in the navigation path of the device we choose our panel. I recommend to disable autostart of this panel at the beginning
  • #3 16543999
    marek216
    Help: 1077
    Rate: 932
    If you bought AM then from what I remember in the installer there is an option for SmartGPS. Then, after installation, you automatically have two icons for navigation programs - maybe not on the main screen, but as a submenu.
  • #4 16544015
    koala106
    Help: 471
    Rate: 1240
    Not in this model - the Smart add-on works on old smartphones without selecting the navigation program in the menu.
