Bosch SMV58L60EU Dishwasher - Persistent Water in Tank and Increased Noise Levels
marta2101 8181 5
  • #1 16835693
    marta2101
    Hello, I have a problem with the dishwasher. It was bought in July. I do not know home appliances, but when changing kitchen cabinets, I noticed that in the tank on the left side of the dishwasher there is still water halfway (photo of the tank borrowed from a forum on another topic, I could not do my own today). After switching on the dishwasher, the water fills up completely, after which it goes down again only halfway and it stays that way. Added to this is the noisy operation of the dishwasher. She worked quietly after the purchase. I am asking for help, I do not know what to do, call the service, is it normal and just fooling around?
    Piotr2608
    Help: 851
    Rate: 4487
    Spend about 1600 PLN and play "Mr. Handyman" instead of calling the service and repair the dishwasher under warranty - congratulations on the idea.
    ZimTech Piotr Zimny
  • #3 16835733
    marta2101
    I understand that this water should not be there?
  • #4 16835746
    Piotr2608
    Help: 851
    Rate: 4487
    This should not be used to unscrew the equipment under warranty and water should not be there either.
    ZimTech Piotr Zimny
  • #5 16839658
    marta2101
    There was a service technician today. He claims that there should be water in the coat. And that it will always be. And if I want to drain it while the dishwasher is running, I can turn it off and press reset until it manages to draw water. Please answer how it is.
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    The service technician is right. This dishwasher is designed so that it uses this water at various stages of work.
