Bosch SRS45T62EU / 13 - Leakage from the bottom of the dishwasher
SHREK912 14562 9
Why is my Bosch SRS45T62EU dishwasher leaking from the bottom, and how can I disassemble it to find and fix the leak?
Remove the side panels and the front service panel, dry the dishwasher, run it, and watch exactly where the water starts dripping; in this case the leak was from the seal under the turbine in the washing pump [#16538688][#16538864][#16542979][#16622862] The most likely culprit is the washing pump gasket, though one reply also mentions the hydrostat chamber as another common leak source; if water appears out in front of the dishwasher, check the door seal instead [#16538705][#16539992] To repair it, pull out the pump, unscrew the turbine, open the additional housing underneath, and replace the gasket in the middle; the original seal was said to cost about PLN 60 [#16540209][#16542979]
  • Request for disassembly guidance to find leak source
    #1 16538650
    SHREK912
    I have a problem with the dishwasher, there has been a slight trickling of water from under the dishwasher for several days. After removing it and turning it aside, water flowed from many places from the bottom plate. My question / request is whether anyone has had a similar problem with such a dishwasher and knows how to disassemble the dishwasher so as not to damage anything and fix the problem?
    Thank you in advance and best regards.
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    You have to disassemble the sides and service panel at the front and look at where the water drips.
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    Generally, as a colleague wrote, you have to undress, fire and look.
    Most often it leaks from the hydrostat chamber or washing pump. If it flies before the dishwasher to the floor then you need to check the door seal
  • #4 16538780
    SHREK912
    I did as you wrote and something like that appeared to my eyes Bosch SRS45T62EU / 13 - Leakage from the bottom of the dishwasher
  • #5 16538864
    h jaworski
    Help: 466
    Rate: 717
    The picture does not explain anything (except that there is a leak) you need to draw water into the dishwasher and look where it drips.
    Lodxx
    Help: 105
    Rate: 245
    The washing pump gasket is probably damaged and leaks from there. Wipe everything dry, turn and watch where it flies from. However, I bet on the pump because of the rusty and rusted body.
    zielinskii
    Help: 20
    Rate: 111
    It's 100% leaking. Take, pull out this pump, it stays on one compressor at the heater. You need to disassemble the pump and remove the gasket from the inside. The cost of the original PLN 60. You will have some fun, but maybe you will succeed.
  • #8 16542492
    SHREK912
    Is this a gasket on the housing?
    zielinskii
    Help: 20
    Rate: 111
    No, but you're going well. Unscrew this turbine yet, deny at the back of the pump something that does not turn. If you take it off, there is one more housing underneath and there is a gasket in the middle and if you look under the bottom of the housing you will probably see a leak under the gasket.
  • #10 16622862
    SHREK912
    Thank you so much for your help, the leak was exactly from this seal under the turbine in the washing pump. I did as you suggested and the dishwasher was whisking. Thanks again and best regards.
The discussion revolves around a leakage issue from the bottom of a Bosch SRS45T62EU dishwasher. The user reports a trickling of water and seeks advice on disassembly and repair. Responses suggest checking the hydrostat chamber, washing pump, and door seal as potential sources of the leak. Specific guidance includes disassembling the sides and service panel, inspecting the washing pump gasket, and looking for leaks under the turbine gasket. Ultimately, the user successfully identifies and resolves the leak from the seal under the turbine in the washing pump.
