Series Candlestick Switch vs Group Switch: Differences & Usage in Catalogs (Connectors)
bestler 65062 6
  • #1 7925571
    bestler
    Help: 254
    Rate: 895
    Gentlemen, what are the differences between these two connectors ??
    One is named in catalogs as a series candlestick and the other as a group one. Sometimes there is one of them in the catalog, and sometimes both. What are the differences between them.
  • #2 7925677
    darek_wp
    Help: 119
    Rate: 193
    The chandelier switch has 1 power point which separates it into 2 circuits controlled by separate buttons, and the group switch is in other words several independent switches in one common housing (each has a separate set of connection terminals). You can make a candlestick out of a group connector - the other way around.
  • #3 7925702
    bestler
    Help: 254
    Rate: 895
    Okay, and how does this symbol relate to a colleague?
  • #4 7926290
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    1- If I remember correctly from my school days (I'm not sure), this is the hotel link. It operated on the principle that it was connected to two groups of lamps. Only one group could be enabled. Never two at once.
    remik_l
    Help: 144
    Rate: 325
    With the candlestick switch you switch on circuit A or B as well as A and B
    With the group (hotel) switch, you connect only A circuit or only B circuit
    With the double-pole switch you switch on circuits A and B simultaneously
    I think I explained it understandably :)
  • #6 7929080
    bestler
    Help: 254
    Rate: 895
    Ok, the topic is exhausted - we are closing.
    Paul
  • #7 21329815
    marcinwionczyk
    And what would a 4 button candlestick switch look like? Because I have some associations :) .
The discussion clarifies the differences between series candlestick switches and group (hotel) switches as found in electrical catalogs. A series candlestick switch features a single power input that controls two circuits, allowing switching either circuit A, circuit B, or both simultaneously. In contrast, a group switch consists of multiple independent switches housed together, each with separate terminals, enabling control of individual circuits independently but not simultaneously. The group switch, also referred to as a hotel switch, permits activation of only one circuit group at a time, never both simultaneously. Additionally, a double-pole switch can switch both circuits A and B on simultaneously. The candlestick switch can be constructed from a group switch, but not vice versa. Symbol representations of these switches were also discussed, highlighting their operational differences in circuit control.
