[Solved] Difference Between Double Switch & Candlestick Switch: Connectors' Roles Explained
MATHIASS222 22200 7
  • #1 17841740
    MATHIASS222
    Rate: 12
    Is anyone able to explain to me the difference between these connectors because after reading the Internet knowledge, I still do not fully understand why they are divided into two things that really fulfill the same role?
  • #2 17841767
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3532
    They differ in the function they fulfill by interrupting the power supply to lighting receivers.
    The rest on Wikipedia.
  • #3 17842690
    serafindamian
    Help: 8
    Rate: 26
    The candlestick switches only 1 wire to the lamp and the double wire switches 2 each separately.
  • #4 17842703
    GBW
    Help: 123
    Rate: 293
    The candlestick is double, while it is bipolar, which has one key and connects two poles, i.e. the double one is activated simultaneously.
  • #5 17842715
    serafindamian
    Help: 8
    Rate: 26
    Who will understand it?
  • #6 17842728
    GBW
    Help: 123
    Rate: 293
    What's the problem.
  • #7 17842744
    serafindamian
    Help: 8
    Rate: 26
    Because the candlestick is double. I wrote badly about the candlestick earlier.
  • #8 17842941
    MATHIASS222
    Rate: 12
    Candlestick switch - It has at least functional keys to light points of light, it can control separate circuits, eg. In the living room we have 4 lighting fixtures, with one button we can turn on two of them and the other with the other.
    Double switch - otherwise known as a two-pole switch, it has one button that turns on the lighting, you can connect several lighting points to it, but we can no longer control them as in the case of a candlestick.
The discussion clarifies the differences between double switches and candlestick switches, both of which serve to control lighting circuits. A candlestick switch typically has multiple functional keys, allowing control of separate lighting circuits, such as turning on different fixtures independently. In contrast, a double switch, also known as a two-pole switch, operates with a single button that can control multiple lighting points simultaneously but does not allow for independent control of each point. The candlestick switch is described as being able to manage two circuits separately, while the double switch connects multiple fixtures without individual control.
