Inserting & Animating GIFs in PowerPoint 2007: Step-by-Step Guide
dingo148 109578 2
  • #1 7939088
    dingo148
    Rate: 16
    As the topic.
    I take the insert, as if it sticks but the picture does not move :( . How to do it ?
    PP 2007 version.
    pzodr
    RadekDK
    Rate: 12
    When you have a new PowerPoint document open, to insert a picture / gif you have to click on the "insert" tab and then on "image".
    A new window will open in which you have to find the picture you are interested in,
    select it and then click "insert".
    The picture will appear on the card
    PowerPoint.
    It will be marked with "stamps" which, after "grabbing" with the mouse, allow for possible reduction or enlargement of the image.
    However, if you hover the mouse over the center of the photo, holding the left mouse button you can freely move the photo and change its position on the card.
    You have to remember, however, that the objects you insert will be "movable" only in the preview of the slide show or after saving the project.
  • #3 7939381
    dingo148
    Rate: 16
    That's what I meant! Thank you very much!
    pzodr
