Power Point 2010 - how to extract text from Power Point and save in Word
deniswisn86 26784 3
  • #1 16468000
    deniswisn86
    Rate: 16
    I have such a case. I want to copy text to Word from a Power Point presentation and print it. Power Point does not have the option to save to Word. Can it be done?
  • #2 16468362
    LA72
    Help: 648
    Rate: 1661
    In version 2007 there is: Main menu> Publish> Create information materials ....
  • #3 16468449
    Zdzisław1980
    Help: 122
    Rate: 178
    In 2010:
    File -> Save and send -> Create information material -> Create information material -> Now select: Outline only you press OK.
    After a while, it opens Word with the text pasted.
  • #4 16468526
    deniswisn86
    Rate: 16
    Approx. Thanks. It's just that it works with one presentation and doesn't work with another. Strange thing maybe the presentation is somehow secured. Can it be done differently yet? I care because I have to study some of these presentations for the exam. I check the option create consumables and then "only outline" works in one case and all the text from the slides appears in a new doc. and you can edit it and with another presentation this option only the outline does not work. After selecting Outline Only, an empty Word document opens
    And I will only add that I have PowerPoint 2013 not 2010
