Extract and Rotate Graphics from PDF Files: Diagrams, Vertical Layout, Graphics Program
Remeknapr 62331 8
  • #1 3269062
    Remeknapr
    Help: 138
    Rate: 183
    How to extract a graphic from a * .pdf file? It is, for example, about diagrams. The pdf has a vertical layout, which is inconvenient to read. I would like to draw such a drawing and rotate it in some graphics program.
    Remeknapr
  • #2 3269173
    wiesniak
    Help: 231
    Rate: 52
    in adobre reader you have a tool like the snapshot tool (next to the "handle" and "select text"). you select them, select the desired area and it lands on the system clipboard. you paste it into some graphics program and do what you want.
    the second option (I haven't tested it, but I think it is possible) is to use an OCR program that will allow you to select the appropriate fragment as an image. You let him digest this pdf, and save the results. The image should be in the saved file.
    I suspect that using some pdf editing program would also allow you to extract the image.
  • #3 3269437
    Remeknapr
    Help: 138
    Rate: 183
    > snapshot tool (next to the "handle" and "select text"). you select them, select the desired area and it lands in the system clipboard. you paste it into some graphics program and do what you want.
    I know this way, but it's not good. This way, you can only get what you see on the screen. The result is that if the graphic in 100% magnification does not fit on the screen, then after reducing it and downloading to the clipboard, you get less detail and not much can be done further. The remedy is to increase the resolution of the monitor, which means that the data is taken from the graphics card. My point is to somehow programmatically extract the full graphic data from the pdf. I have never tried OCR and I do not have it on the disk, and I would not like to experiment blindly. In this regard, I have a request from someone already experienced for advice.
    Remeknapr
    paweliw
    IT specialist
    Help: 710
    Rate: 229
    I played a little with the free program Tomahawk PDF + 2.7.5 pl and without much problem I was able to extract (and save as jpg) from pdf a graphic file (diagram) in a quality comparable to the quality in the original pdf.
    You use the menu Tools-> Extract PDF-> PDF File-> Execute (while waiting - Working-> Finished) -> View Images. The Image Manager program is launched and there you "adjust" the magnification (zoom - it does not affect the actual size of the image, it's only a preview), vertical and horizontal flips, 90 degrees (Flip, Rotate), compression format, etc. and save the selected file / files (Save / Convert).
  • #5 3271219
    Remeknapr
    Help: 138
    Rate: 183
    Thanks. I'm already trying it.
    Remeknapr
  • #6 3272706
    Remeknapr
    Help: 138
    Rate: 183
    > Tomahawk PDF + 2.7.5 en
    Unfortunately, that was not what it was about. This program extracts all * .jpg, * .gif etc. from PDF without asking, but it cannot handle schematics. Then they are not graphics and I asked the question wrong. Is there any way to draw schematics?
    Remeknapr
  • #7 3273727
    paweliw
    IT specialist
    Help: 710
    Rate: 229
    I'm sorry I didn't help you much.
    Indeed, the file checked by me were scans of images converted into pdfs without the use of OCR ... Tomahawk cannot cope with typical "full" pdfs (or rather pictures in them).
    So there is probably only Acrobat in the full version ...
  • #8 3276531
    Remeknapr
    Help: 138
    Rate: 183
    > Expose this file to Rapidshare.
    It is not about one file, but about a large database of diagrams. And it would be good if I did not have to bother someone with another scheme. And if it is possible, another question: Can pdfs in RequiresAcrobat6_IE.pdf format be converted to a lower version? The "Six" is a muddy "cow" (at least on my equipment) and I don't want to install it.
    Remeknapr
  • #9 7001797
    krriv
    The best way is to install Adobe Illustrator (even in the Trial version).
    Then you open the PDF file with AI. Once opened, you have the full option to edit the file, export graphics, etc.
✨ The discussion revolves around methods to extract graphics, specifically diagrams, from PDF files with a vertical layout. Users suggest various approaches, including using Adobe Reader's snapshot tool to copy images to the clipboard, though this method may result in loss of detail if the graphic does not fit on the screen. Alternatives mentioned include using OCR software to extract images and utilizing PDF editing programs. A notable recommendation is the free program Tomahawk PDF + 2.7.5, which allows users to extract and save graphics in high quality, although it struggles with schematics. Adobe Illustrator is also suggested as a robust solution for editing and exporting graphics from PDFs. The conversation highlights the challenges of extracting detailed diagrams and the need for effective software solutions.
