Switching from Store to Home Mode on LCD TV Samsung LE40B650: Step-by-Step Guide
kacper230681 102504 0
  • Re: Samsung LE40B650 How to turn off store mode?
    Problem solved. For others who have this problem:
    First, press SOURCE on the remote control, select the TV source, then enter MENU-SETTINGS, then select Plug & Play, enter the PIN, which is 0000 by default and there we will be able to switch the store mode to home mode.
    NOTE: All settings will be reset and you will have to re-adjust channels after this operation, as well as other settings, e.g. sounds, etc., really works.
    kacper230681
    kacper230681 wrote 2 posts with rating 44. Live in city Bartoszyce. Been with us since 2010 year.
