Power Connection Acceptance Protocol Template: Seeking a Resource for Wojciech
_Wojciech_ 43238 5
  • #1 7982548
    _Wojciech_
    Rate: 31
    Hello!
    I need a template of the Power Connection Acceptance Protocol. The horror is not on the net :(
    If anyone has a pattern - please include a link.
    Regards,
    Wojciech
  • #2 7982629
    jurkuc
    Help: 146
    Rate: 315
    There is no universal formula for such a protocol. Each electricity supplier determines the content of such a protocol himself.
    However, the protocol for technical verification of the connection usually includes (quoted from the SEP forum):
    - Recipient's declaration that he has legal measurement results and
    documents approving the internal installation for operation + application for
    connection to the network,
    - technical data of existing devices,
    - technical data of connected devices,
    - situational sketch
    - confirmation of technical inspection of the connection (type, numbering of poles,
    length of a connector, line spans, type of apparatus, lightning arresters, resistance
    earthing, cross-section number of conductors, others, if not included in the PT connection),
    - command to install the measuring system,
    - confirmation of the first control of the measuring system,
    - confirmation of the Recipient that the seals of the Office of Measures are intact.
  • #3 7982772
  • #4 7982775
    _Wojciech_
    Rate: 31
    What about an example in PDF?
  • #5 7985542
    sq9jjh
    Electrician specialist
    Help: 95
    Rate: 271
    Example? You're welcome: Link :D
  • #6 7985742
    _Wojciech_
    Rate: 31
    Thank you.
